How do i get my Sharp 9850AV stereo to play sound
Sharp sound problems no sound
Just check if the audio signal cable is getting into the Sharp panel. If you are using HDMI then select the audio in to HDMI. I am unclear if your audio was previously coming in from the stereo or the cable box. If you have removed the stereo then you need to ensure the audio signal to the panel is stored. Not sure if this helps.
Aug 02, 2014 | Sharp LC-70LE632U - 70 Aquos Edge Lit Led,...
No sound thru pioneer equaliser from quatrron tv
There are two way to do this.
1. Connect all your devices individually to the Pioneer receiver. Doing this allows you so have different sound settings for each input. A reason you might want this is that your DVD will need a DTS or Dolby sound setting so that you get the best audio from your DVD, whereas your TV may only be outputting stereo audio. In this case you would set your Pioneer to a stereo setting.
2. Connect your devices to the Sharp display, then connect the audio output of the Sharp to a free audio input on the Pioneer.
Your Sharp LED TV has two ways to do this: a. If you have a digital capable Pioneer sound system, connect using the "Digital Audio Output". You will need a Toslink (Optical) cable for this connection. b. If you only have analog capabilities in your Pioneer sound system, you must use the 3.5mm (1/8 Inch) analog audio output from the Sharp TV to stereo RCA (red and white plugs that are most commonly supplied with home theatre product).
Oct 27, 2012 | Sharp AQUOS Quattron 60 Class LED 1080p...
I have burned cd and my sharp cd-c444 wont play it. why
Check what format you burned the songs from. Some formats, like MP3, mpg, among others will not play on all stereo systems. When you burn the songs, make sure that MP3 is not the format for the Sharp system, and that in fact, mpg is. I hope that solves your problem.
Sep 27, 2010 | Sharp CD-C444 Shelf System
I have a Sharp LC-52SB55u. IF THE TV SIGNAL IS
do you have left and right audio plugs connected?,if no,t you will hear stereo(as it will play threw one lead,but if in mono,you wont hear anything unless you plug the other lead in instead...
Aug 31, 2009 | Televison & Video
Mono sound only
I have an LC42D64U with firmware U0709111. This is an 11 month old unit. It was working fine until I lost power one day, then I couldn't get any sound. It always showed up as Audio: mono. I tried every setting and nothing (although XBOX via HDMI still played though the onboard audio, so I knew it wasn't a HW issue).
After searching around for a method to change the mono/stereo I resorted to the Fred Flintstone's fix and simply pulled the plug on it. Immediately after turning it back on it worked.
This is hardly a fix but it worked for me.
Nov 20, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Mar 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sound won't play thru stereo from t.v.
take the main tv digital opti outto sterio ok on ch or from dish box to sterio on a ch
Feb 02, 2008 | Onkyo TX-SR605 Receiver
Sharp (friendly series)
1)Stereo==stereo sound 2)SAP=second audio program,i.e.alternate language 3)Mono=all the sound,left side & right side, no stereo effect Hope this is helpful--let me know.
Oct 04, 2007 | Sharp 27C-240 27" TV
Mini sharp stereo
Try pressing the play button on the remote. If it works correctly, the play button on the unit may be defective.
Sep 04, 2007 | Sharp CD-BA150 Shelf System
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
