Question about Furniture
Aficionado HVT18DFBB WINE COOLER HEATS UP INSIDE
bobotfel
  • 236 Answers
SOURCE: Wine cooler gets too cold (freezes)
Check your thermostat setting, if the setting is ok then something wrong with your thermostat control.
Posted on Jan 21, 2008
  • 27 Answers
SOURCE: U-Line 15WC Wine Cooler Problem
Cheak The Compressor relay is fault
Posted on Jun 21, 2008
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
  • 286 Answers
SOURCE: uline wine cooler 2075wc doesnt work, light goes on ????
If nothing runs but the light is on then change the thermostat. #2767-1 and you can find a part from a distributor. To find one visit www.u-line.com and under customer service you will see parts locator
Posted on Jun 15, 2009
  • 286 Answers
SOURCE: u-line 75WC wine cooler - rust on inside back wall
This happens when the racks get too close to the evaporator. Or bottles. You can try to use hot water but usually you will need to buy new racks for the unit.
Aficionado wine cooler 18 bottle
It low on 134a or has a dirty coil or the fan has stopped workin or is dirty. If there are no electrical or mechanical problems then its the refrigerant.you can get more at the auto store but you'll have to get a retrofit peirceing valve to check and recharge it.
May 30, 2013 | Furniture
The door light in wine fridge will not turn off when the door is fully closed..
There is a switch for the light. If it isn't a mechanical switch where the drawers slide in, it will be a magnetic switch in the edge of the drawer
Dec 27, 2012 | Haier Aficionado 26 Bottle Wood Trim...
Aficionado hvt18dfbb is running but NO TEMP CHANGE
There is no compressor on these units. These units use a Peltier cold/hot module where the cold side faces the heat sink and the fan exhausts the heat side. Another fan sends the cool side into the frig. I have the same unit, I am experiencing the same issue. I was looking to change out the Peltier modules (about $7 each) and try that. I did find a replacement Control Board is about $45 and if the Peltier change doesn't work this may be my next step.
Nov 08, 2012 | Haier HVA052ALL-8S 52 Bottle Aficionado...
What is a thermoelectric cooler?
A thermoelectric wine cooler contains a cooling node. When an electric current passes through the node the outside of the tile heats up and the inside of it cool down.
Aug 14, 2012 | Furniture
Where is the main power relay?
the current is running in the wrong direction here is a site that shows how thermo cooling works.http://www.activecool.com/technotes/thermoelectric.html
Apr 22, 2012 | The Cellar : Thermo-Electric Wine Cooler -...
The bottom compartment of the Aficionado wine cooler doesn't cool. Are there replacement parts available?
Check to see if there's some hazzle in the bottom compartment. Things that are may block the cool air in lower compartment will cause that. Also dirty, spilled liquid can cause that.
Check it out, clean it and it will cool again.
Good luck.
Jun 12, 2011 | Refrigerators
I have a Aficionado refrigerator and the compressor will not start. I hear the starter clicking
The clicking is the sound of the Klixon (overload). It sounds like the compressor isn't starting for some reason. This is common if the unit's cycle was disrupted (such as a power disruption) as the pressure in the high and low side takes a little while to equalize. A hard start kit could be installed which adds a capacitor to the starting circuit of the compressor might help temporarily.
Jun 21, 2010 | Haier HVA052ALL-8S 52 Bottle Aficionado...
Frig won't chill. can hear it click off & on when plugged in.
HAVE YOU CHECKED THE SWITCH ON THE COMPRESSOR OR THE FUSE ? AND IF THE COMPRESSOR IS KICKING ON CAN YOU HEAR THE BLOWER FAN KICK ON ? IF ALL IS GOOD THEN YOU HAVE A BAD CONDENSOR THAT WILL BE THE NEXT THING TO CHECK
Apr 11, 2009 | Haier HVA052ALL-8S 52 Bottle Aficionado...
WINE COOLER
hello jelani372,
Happy you assist you.
You asked,
WHERE MIGHT THEY BE LOCATED I AM A ROOKIE I DO HAVE THE BACK COVER OFF ALL HELP IS APPRECIATED THANKS I HAVE THE HVT18DFBB MODEL
I believe this is the web site you asked for!
http://www.haieramerica.com/en/
Bless You,
Please rate me as solved, before you sign off please. Thank You!
Jun 22, 2008 | Haier HVT12ABS Compact Wine Cooler
Furniture Logo
29 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
