Question about Westinghouse LTV-30W2 Television
Black screen My westinghouse LTV30w2 will work perfectly for about 7 minutes then the screen goes black but the blue power light stays on
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 43 Answers
Check to see if the sleep timer is engaged
Posted on Jul 28, 2013
4 Suggested Answers
  • 10 Answers
SOURCE: westinghouse LTV30w2 has blank screen and audio
What you have is a darfon V144 board (junk). it's a simple fix if you know how to use some basic tools and a soldering iron. Get an led (i used digikey's PN: L10041-ND) and solder it from pin 10 to pin 16 on the OZ960 chip on the inverter board. If you need the chip layout type "OZ960 pdf" in google. Hope this helps.
Posted on Dec 31, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Westinghouse LVM 37w1 Screen goes
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Posted on May 18, 2011
Slinteriors
  • 8617 Answers
SOURCE: My Westinghouse LTV-30W2 when i turn it on the screen comes on and go's black my power blue light still stays on with sound what is wrong with it?
Thats usually an inverter board issue. Replacing the inverter should solve the issue in most cases. You can get the replacement inverter board from www.tvcircuitboards.com
Posted on Dec 12, 2012
TV shuts off after about 7 minutes
RGARDEZ DANS LE MENU SI LE TEMPS N EST PAS ACTIVER A 7MINUTES
Jul 28, 2013 | Westinghouse LTV-30W2 Television
Dec 12, 2012 | Westinghouse LTV-30W2 Television
Tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Jan 23, 2010 | Westinghouse SK-32H240S Television
Westinghouse LTV30w2 has blank screen and audio only - I've tried cable and RCA inputs, still only audio. My TV flashed the picture and would immediately go to black. I unplugged the TV and when I...
Dec 31, 2009 | Westinghouse LTV-30W2 Television
Monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
Jan 31, 2009 | Westinghouse L2046NV Monitor
Westinghouse LCD picture goes out after about 10 minutes
Check for swollen capacitors in the power supply. They should be flat on the top, not domed.
Jan 16, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
Picture flashes for 1/2 second then is gone...sound continues
power supply if led ligth stays blue and then after a few minutes changes to orange is your power supply.if light color goes to a purple that is your mainboard $$$$$$$$$$$
Oct 14, 2008 | Westinghouse SK-32H240S Television
Westinghouse LCM22W2 shows a display then turns off after half a second
I have the same problem and have traced it down to a potential power supply issue.  I bought mine at Best Buy in '06 and was told today that they will test the power supply for free.  It may range from $50.00 to $100.00 depending on where you can get it.  This does not include labor for those not qualified to work with electronics.  Hope this helps you.
Aug 13, 2008 | Westinghouse LCM-22w2 Television
Westington LTV-27w7 HD black screen
ICheck the power supply connections make shure tht the plugs are seated correctly. The power supply isreplaceable as a complete uitand you have to return a repairable unit.
loumargo
Allied electronics
loumargo@verizon.net
Dec 25, 2007 | Westinghouse LTV-27w7 7 in. LCD HDTV
Televison & Video Logo
74 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
