Question about Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125
Luke warm water
Our Bosch 125HX LP water heater used to work fine. Now the water out is luke warm. The pilot lights, the burners come on, but the flame is only about 3/4" high. I replaced the rod assembly in the water valve (we have very hard water), but to no avail. Any suggestions?
  • tbroberg Aug 10, 2013
    After rebuilding the water valve, because it has been a few years and we have *seriously* hard water here, I couldn't think what it would be short of a gas supply issue, which is out of my league.
    Sure enough, the gas regulator was bad, resulting in low gas pressure house-wide.
    Thanks to all for your thoughts on the issue.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 43 Answers
Is the water temperature dial turned up? or even functioning?
Posted on Jul 28, 2013
  • 25 Answers
SOURCE: Bosch AQ125BNG gas water heater
First thing I would do is clean and rebuild the watervalve. The watervalve on this heater mandates everything. This watervalve has a maintenance schedule in the manual. She be rebuilt every 3 years. Also sounds like the diaphram in the watervalve may be damaged.
Posted on Jan 19, 2009
co7196
  • 3433 Answers
SOURCE: no hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
Posted on May 06, 2009
gary1121
  • 332 Answers
SOURCE: bosch hot water service 16p burner shuts down
a tankleess water heater doen's have a piliot? but check the vent outside make sure nothing is blocking it, if it detects the exhaust thru the cold air intake it will shut off and over heat, other then that it would have to be the control board
Posted on Jun 06, 2009
co7196
  • 3433 Answers
SOURCE: The Pilot burner flame is large & yellow
the pilot is getting too much air and is an indicaiot of dirty or air/ fuel ratio imbalance. The pilot is wimpy and the thermocoupler has alot to do with the gas . Make sure your thermocoupler is on the tip of the flame. You may end up replacing it. because it is showing signs of eminnt failure. When it fals your curners won't fire up. Good luck.
Posted on Jun 09, 2009
mrhotandcold
  • 248 Answers
SOURCE: we have a 3 year old Bosch GWH 425 HN tankless LP
suggest you complain to Borch sometimes lemons get through best of luck
Posted on Oct 30, 2009
My gas shower is either luke warm or very hot whats wrong
If all the other faucets work, then the problem is the mixing valve in your shower. You will need a new shower fixture.
Apr 10, 2012 | Bosch Water Heaters
I have abosch 1600 ps aquastar 4.3 gpm indoor when i turn hot water on it all fires up but no hot water comes out only luke warm water why
Water heater is heating water but only luke warm water arrives at faucet.
Open TP valve and confirm that hot water is available.
If water at TP valve is hot, then problem might be plumbing-related, for example crossover.
http://waterheatertimer.org/Crossover.html
Aug 15, 2011 | Bosch 1600PS NG Aquastar 4.3 GPM Indoor...
Water is luke then warm then turns cold. it never gets hot.
Before calling service technician, open following links for Bosch troubleshooting resources and information that might help narrow down the problem(s):
No error code indicates that first suspect is a plumbing problem.
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Bosch_Overcoming_fluctuating_temps.pdf
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Jun 24, 2011 | Bosch 2700ES-LP Propane Tankless Water...
Water not reaching proper tempreture before cutting out . it is only luke warm
What setting do you have the temp dial set at? The biggest problem I find on RV water heaters because they sit unused for long periods of time, are spider webs in the burner or dirt dauber nests restricting burners and not allowing it to fire properly, causing intermittent flame or flame outage.
May 15, 2010 | RTO Atwood Water Heater - 6 Gal LP
Hot water tank shuts down after 5 minutes pilot is on water is luke warm
turn up the thermostat,, if that don't work, you need to replace the thermocoupling
Jul 12, 2009 | RTO Atwood Water Heater - 6 Gal LP
Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
Jun 09, 2009 | Bosch AquaStar Propane Tankless Water...
No hot water, pilot light lights but no burner ignition
May 05, 2009 | Bosch & Tankless LP Hot Water Heater
Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125 Logo
131 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
