Question about Acer (91.AB264.016) Internal 24x CD-ROM Drive
HP / Compaq nc2400 Otical drive will not work correctly after OS install, will not spin fast enough
I have several HP / Compaq nc2400 ultra small laptops. About two weeks ago I took one off the shelf and inserted a XP Pro 32Bit CD and it launched and installed the software and I went on to update all of the drivers. Later I decided to add another program using a CD and the Optical Drive (DVD/RW) will not spin up to full speed, it just kind of surges for a few times and then quits trying. I have tried other CD's so that is not the problem. At the time I just I had a bad Optical so I went to the next nc2400 and it did the same thing. So, I thought two bad Optical drives? It turns out that this problem is consistent over several of these that I have done and I cannot figure out why. It sees the drive within Windows, and it allows you to attempt to boot from it at start up, it just won't spin fast enought to read. Has anyone run into this before? Why do they all run fine during the install of the OS, even as the OS restarts the computer during setup, but then it quits after windows is installed? Thank you
SOURCE: Windows XP Unsuccessful on Start Up
when i turn on my pc the screen just goes black and doesnt load or do anythink what is my problem
Posted on Feb 09, 2008
BobbyR1234
  • 173 Answers
SOURCE: Having problem installing Windows XP on My Acer Aspire T650 Computer
Before you did the install did you make sure that you set your CMOS setting to check for a cd disk first before booting straight to the hard drive? When you do an install, you must make sure that the computer knows to look for a bootable disk otherwise it will look for an operating system to boot to first. If this is the problem, after you have installed your operating system you must go back and reset your CMOS settings to look for a hard drive or operating system. Hope this help and if it doesn't let me know for further assistance.
Posted on Jul 04, 2008
map9966
  • 2351 Answers
SOURCE: Computer will not boot with Pioner Blu-Ray BDC-SO2 installed.
Hi stokarek,
With respect to SATA drives. All are master drives. As you mentioned if there is a fight between drives the trouble can be settled in the bios. I gather the WD160GB drive holds windows on it & the WD is connected to SATA 1 port. Enter you're bios & go to the Boot section. Open you're manual to section 2.6 boot menu page 2-32. Make sure you're WD is the only hard disk drive listed. After you add the Blu-Ray (To SATA 2 port), (its pin setting should be set as master. Than go back to the boot menu & make sure the Blu-Ray drive is listed under the WD drive.
Keep in mind for the future that if you want to boot to the Blu-Ray drive you'll need to press the F8 key at boot up. Windows select boot device window will open & high-light the Blu-Ray & press enter so the Blu-Ray will boot. Windows should no longer stall. If this does not work try switching the pin on the blu-ray to slave. (I'm not sure there is even a pin setting on the blu-ray drive. Never the less the bios boot order is the boss.
Link to Asus main driver site for ASUS M2N8-VMX
http://support.asus.com/download/download.aspx?modelname=M2N8-VMX&SLanguage=en-us
Good Luck stokarek!
Mike
Posted on Jul 08, 2008
  • 9 Answers
SOURCE: No CD /DVD Drive Icon
I checked the specifications on the Acer 9410Z, and verified that it ships with Microsoft Windows Vista Home Premium.
This is actually a very common problem in Windows Vista and tends to occur for a few different reasons. One notable issue is anti-virus and anti-spyware programs that perform a system scan and remove any instances of viruses and/or malware.
Without going into too much detail there is quick fix available from Microsoft at: http://support.microsoft.com/kb/314060
Scroll down to "Fix it for me", and just click "Fix." This will run a quick installation, and then ask you to restart your computer. If it doesn't ask you, then restart it manually.
Your CD/DVD drive should now show up in My Computer, and should be recognized by all programs.
Hope this helps!
- Joshua
Posted on Jun 09, 2009
HEMPYODA
  • 168 Answers
SOURCE: driver cannot read blank disc
I recently installed a dvd writer for my neighbor. they used a top brand dvd-r / rw and never had any problem. but after the new install they had the same problem . after visiting the manufacturer's website we found that that certain brand of dvd were recommended. check the manufacturers site for dvd recommendations.
Posted on Sep 13, 2009
What is valve gap on 18 hp briggs and stratton
This might have the valve gap:
http://outdoorpowerinfo.com/engine_specs/briggs_valve_gaps.asp
Here is a link for the Briggs website about common small engine issues. I hope it helps at least a little.
4 Common Small Engine Problems How To Fix Them Briggs Blog
Nov 21, 2017 | Garden
How do i replace a cmos battery in my hp compaq nc2400
I was unable to locate your specific laptop this might ge you some in sight in what to look for and how to remove cmos battery remember some cmos batteries are soldered in
RTC battery replacement procedure on Compaq HP Mini 110 netbook & clear CMOS http://www.youtube.com/watch?v=P_cxAireIsw
Feb 26, 2013 | HP Compaq nc2400 Notebook
HP d220m will not boot from hard drive, have tried several but nothing happens.
Hello, can it be your cd or cd rom that is the problem? I sugggest that you try with a other cd rom and make a copy of your cd and try to install from the new one. Plz post your exact error here.
Apr 05, 2012 | HP Compaq d220M (829160054797) PC Desktop
Compaq nc2400 no video
nc2400. (circa , 2007 made) and still supported at HP (we arent HP)
another old., pc dead. value is $20 (see ebay solds? yes)
so it less dead like this.
here are the steps,
main battery out, ? work now,
that is correct, BIOS works , with no battery, AC PACK good, 19vdc = good.
and hdd out , cd out.
ever heard OF CCFL ?
2010 then ended, so I first check this , yours being 2007
BINGO CCFLs, they are short lived lamps back lamps.
so use a flash light.
btw the externa VGA jack needs Fn+F4 pressed to work!!!
per manual below.
your SM is here
http://h10032.www1.hp.com/ctg/Manual/c02012281
now the test, acid test on CCFL.
with bios hot keys hammered, per book above.
then the magic flash light trick, (posted here now 300 times)
look ma, no blacklight.. but gee see the data., BINGO.
http://www.pcdied.com/monitors.html#flashlighttest
Sep 28, 2017 | HP Compaq nc2400 Notebook
Ethernet driver missing on hp dc7700cmt computer. I have tried to use the drivers form the HP download site but the driver still comes up missing. I can't connect the computer to the internet to let...
Open the Device Manager (you can do a Windows search for it if you don't know how to open it).
Look in the Network Adapters section.
Remove your Ethernet device. Right-mouse-click it and make sure it's not disabled. If it's disabled, enable it and you should be fixed.
Otherwise, click it to highlight it and press "delete" to remove it. Then right-mouse-click on "Computer" (at the top) and "scan for hardware changes." Windows *should* install the correct driver.
Otherwise you'll need to go to the HP support site on another computer, save the driver to a flash drive, external hard drive, or CD or whatever, and then install that on your computer.
Jan 03, 2018 | HP-COMPAQ DC7700 CMT C2D/2.4 2GB-160GB...
My Compaq Presario 1700T will not play DVD anymore. It worked before. Now when I insert a DVD I can hear DVD spin for about 2 seconds then it stops spinning momentarily, then it spins for another 2...
IT'S 16 years old, there is no support for it now. sorry.
we get these here all the time, and no OS stated
why post with out stating what OS this is,
?w98, w2k, XP, VISTA,W7,W8, w8.1 W10.?
nor showing the DVD model there, it has s specific model name
and number (vast types used and sold)
DVD from store, or one you made or others made by hand.
home made or factory made store bought DVD?'
did you try this?
did you try other DVD movies? or look for the VOB files on them?>
Testing 123, easy to harder,
1: try a music CD first. store bought not home made.
2: look for files on any install CD, using the local file manager.
my computer, this computer, or what ever ms calls it this year.
we look to see if the PC can see the files on a real CD. first.
even the HP install CD, or other CD that are not for music or movies, if it cant read a CD, and see fails drive is bad.
or its drivers are missing or corrupted,(virus or?)
3: if this fails open the control panel, (start , CP) then look in device manager (on XP it tricky to get there so tell us if it's XP)
no OS stated, so....no operating system stated.
if the Device manager fails to show the DVD DRIVE,
this means :
A: bad. drive.
B: drivers for the drive are missing (hp has them if still HP DVD drive)
C: the OS is corrupted.
D: running XP , the Dead OS, with out SP3 service pack 3 will be very bad experience in all ways. it has DVD driver in said pack.
E: not running the HP drivers, that hp has. (but HP does not support 16 year old PCs at all) so getting them now is super hard.
the users manual mentions windows 98.
omg is it that old?
the same manual says , only select models has DVD drive.
to make DVD work , special software from HP was installed.
From HP, not MS.
there is a free manual for your PC
https://www.manualslib.com/manual/428472/Hp-Compaq-Presario-Presario-1700.html
Oct 17, 2017 | HP Compaq Presario 1700T Notebook
Graphics card
Desktop Casings are lower enough that can't be closed when inserting Cards like your Graphics card. Change your desktop casing to Tower Casing so you can freely install your Graphics card to the graphics card of your motherboard.
Jan 14, 2009 | HP Compaq d530 SFF PC Desktop
I can't format my 32gb pen drive.Window unable yo format it
Try to use this program to format it.
Utilityfor formatting and creating loading USB Flash (it is supported NTFS,FAT, FAT32). It works with the devices through port USB 2.0. For theload from flesh in BASIC INPUT-OUTPUT SYSTEM Setup it is necessary toestablish as the first loader USB-HDD Device. m_right_m.gif banner_header m_right_m.gif VERSION: 2.1.8 Rev. A
DESCRIPTION:
This SoftPaq contains a Windows-based format utility for the HP Drive Key or
DiskOnKey USB 2.0 device.
PURPOSE: Routine
SOFTPAQ NUMBER: SP27608
SUPERSEDES: SP27213, SP27135
EFFECTIVE DATE: May 17, 2004
CATEGORY: Driver - Storage
SSM SUPPORTED: No
PRODUCT TYPE(S):
Desktops
PRODUCT MODEL(S):
HP Compaq d220 microtower: All Models
HP Compaq d230 microtower: All Models
HP Compaq d240 microtower: All Models
HP Compaq d248 microtower: All Models
HP Compaq d330 desktop: All Models
HP Compaq d330 microtower: All Models
HP Compaq d330 slim tower: All Models
HP Compaq d338 microtower: All Models
HP Compaq d530 convertible minitower: All Models
HP Compaq d530 small form factor: All Models
HP Compaq d530 ultra-slim desktop: All Models
HP Compaq d538 convertible minitower: All Models
HP Compaq d538 small form factor: All Models
HP Compaq dc5000 microtower: All Models
HP Compaq dc5000 small form factor: All Models
HP Compaq dc7100 convertible minitower: All Models
HP Compaq dc7100 small form factor: All Models
HP Compaq dc7100 ultra-slim desktop: All Models
HP Compaq dx2000 microtower: All Models
HP Compaq dx6100 microtower: All Models
HP Compaq dx6100 slim tower: All Models
HP Compaq dx6120 slim tower: All Models
HP d325 microtower: All Models
HP d325 slim tower: All Models
HP RP5000: All Models
N/A: All Models
OPERATING SYSTEM(S):
Windows XP Home Edition
Windows XP Professional
LANGUAGE(S):
Global
ENHANCEMENTS:
New Windows-based interface. (For DOS-based interface, download SoftPaq
SP27214.)
FIXES:
- Allows creation of a FAT32 volume larger than 32 GB.
- Fixes installation issue where installation process stopped after the earlier
version of software was uninstalled and the new software was not automatically
installed. The installation process now restarts automatically to install the
new software after uninstalling the older version.
PREREQUISITES:
- Requires an HP Drive Key or DiskOnKey device plugged into a USB 2.0 port.
HOW TO USE:
1. Plug the HP Drive Key device into an available USB 2.0 port.
2. Download the SoftPaq .EXE file to a directory on your hard drive.
3. Execute the downloaded file and follow the on-screen instructions. If
prompted to overwrite any files, answer Yes to all to continue installation.
http://www.maxiwarez.com/2007/12/21/hp_usb_bootable_format_tool_v.2.1.8.html
Dec 30, 2008 | Kingston Technologies 512MB DataTraveler I...
Hello
you may need to have usb enclosure for your dvd rom to make it external and you can use it.
Dec 05, 2007 | HP Compaq d530 Ultra Slim PC Desktop
Computers & Internet Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
