Question about Hasbro Nerf N-Strike Stampede ECS Blaster
Where can i find spare parts?
My son has had his chain magazine stolen and the gun will not work without it. I cant find spare parts for this gun anywhere. Can anyone help me?
Will a Marlin model 60 magazine tube fit a Marlin Glenfield Model 99G? I'm looking for a tube for my sons 99 Thanks
I'm guessing 'inner' tube. Maybe this link will help. Doesn't show the 99G but has the lengths listed as 20 13/16" and one at 17 something.
$30. Talk with them and see what they say if you don't feel confident in just picking one out and buying it.
Search Numrich Gun Parts
Oct 12, 2017 | Optics
Nails fail to feed
Without knowing your model number here are some things to check, in order of difficulty:
1. First make sure you're using the proper nails for your gun. If your gun isn't specifically listed on the box of nails as compatable make sure they are seating in your gun properly. Some brands of angled nails are a couple degrees off from others and won't work in competetor's guns.
2. Check the entire feed path of the nails in the magazine all the way up to where the driver catches the next nail. Sometimes dirt builds up in the track or there could be a peice of nail stuck in there preventing the nails from getting under the driver. Also the spring on the feed shoe should have strong pressure on the shoe all the way up to the head and the shoe has to ride freely in the magazine.
3. If the gun is making holes in the wood the driver isn't broke but it must be straight and true and the tip square. If not it will miss or slip off the nail before driving it. The only way to check the driver is to remove the head on the gun and take the driver out. The piston & driver should travel from the top to the bottom of the cylinder without binding anywhere. Correct any problems you find or replace any damaged parts and your gun should work.
Feb 13, 2012 | Porter Cable 16 - Gauge Finish Brad Nailer...
My 8 year old grandson brought home his ner n-strike raider CS-35 and without reading instructions promptly shoved the drum magazine directly into the main gun body without first inserting the drum...
unscrew the entier gun... all nerf guns are screwed together. you can practically cut the gun in half by unscrewing it. just make sure to put everything back how you found it. good luck to you.
Mar 29, 2011 | Nerf Toys
I recently bent my magazine on my magnum air framing gun. I was wondering where I would find the magazine to fix it or if it would be better to replace the gun?
depending on how bad it is bent the magazine is usually rather expensive. The way we used to "straighten" some is to take a block of wood and strike the end of the magazine against it to pull a slight bend out of the magazine so it was usuable. Put the end of the wood on the ground and hold it in place with your feet and hit the end against it, checking for the best alignment. This only works if the bend is not severe. If you give me the exact model and brand I will try and find a source for the part also. Let me know if you need more assistance.
Mar 15, 2011 | Magnum Air 8 10 Gauge Framing Nailer
Staple gun jammed after falling into water puddle
Remove the magazine and shake out all excess water from the tool. WD-40 is merely for Water Displacement, hence the name WD-40. You need to lubricate with shop grade oil. Inspect the driver head to make sure the surface is flat and free of dings or nicks. In order for your tool to work properly it needs to be able to feed without interruption, and the driver head needs to be able to move back to **** and forward to fire without hinderance. After insuring that all parts are in proper working order, reassemble, load, and fire. This should fix your problem 90% of the time. If not, then check the magazine spring to make sure it is delivering a strong drive to the loaded staples or nails, if not, you need to either use more of either to put more pressure on the spring, or you need to replace the spring all together.
Mar 02, 2010 | Stanley TR250 H Heavy Duty Heavy Duty...
Model 9422M 22Mag gun was stolen aprox. a year ago police returned it today. large amount of rust and magizen tube missing.
You can try to clean the rust with toothpaste and a lot of rubbing with a soft rag. Have a gunsmith order a magazine tube for you and install it. This shouldn't be expensive. hope this helps you
Oct 30, 2009 | Winchester (026196062448) (20 - 60x70 mm)
My magazine for my m10 swat aeg airsoft gun is loaded but i cant get the pellets to feed into the gun without tipping the gun upside down. how can i fix this?
you will hav to open the gun...or u need a new mag for m10.
if you find something when u open it try to put it back or ull nee to buy a new part for the gun.
Jun 05, 2009 | Sport & Outdoor - Others
Spray gun tips
RECOMMENDED SPARE PARTS FOR EACH GUN * Air nozzle, needle and tips * Packing and gaskets * Hoses and fittings * Gauges * Proper lubricants * Filter screens * Diaphragms for pressure regulators
Aug 27, 2008 | Grizzly H7670 Mini Hvlp Spray Gun,...
B@D CHAIN SAW DN301H5
go to the shop and buy a drive gear
Apr 07, 2008 | Black & Decker 5700 Powershot Forward...
Hasbro Nerf N-Strike Stampede ECS Blaster Logo
26 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
