How do i hook up my sony sa wmsp75 subwoofer
I want to hook it up to play with my pc or my home theater system
SOURCE: Hi folks!!!
ho2 error. no disc (but the disc is on) what to do??
Posted on May 18, 2008
tech48
  • 624 Answers
SOURCE: Panasonic home theater system pt760
Make sure you have put the transmitter for the wirless speaker in the slot on the back of the reciever, it is a slim white device that is about 3 to 5 inches long?? and maybe half an inch thick. and make sure it is put in the right way.
Then make sure the wireless speaker is plugged in to the wall outlet.
If this does not work for you it may require being taken in to an authorized panasonic service center. when one part of the wireless system fails (transmitter or reciever) they both must be replaced. they are not interchangable from one panasonic to another.
They have a code in each unit that lets the wireless speaker that came with it only work with the reciever it was sold with.
I have even seen times where the store that sells them swapped the transmitters of two units and then they had two customers very mad at them because the wireless speakers did not work for either person.
Let me know if I can be of any more help.
Posted on Jun 19, 2008
tech48
  • 624 Answers
SOURCE: PANASONIC HOMETHEATER SYSTEM TO PLASMA TV
Some where on the back, bottom or sides of your plasma tv you will find input jacks for the audio and video. You must know what type of inputs you want to use.
Most have have 4 types
HDMI (audio and video signal combined)
Component (red, blue, green RCA jacks for video only)
Composite (yellow RCA jack for video only)
S-video ( larger round black jack with video only)
The Panasonic should have all of those also. I am certain it has HDMI and Component.
Connect the HDMI cable into the output HDMI jack from the Panasonic into the HDMI input jack on the TV.
Then using your remote for the TV make sure you select the HDMI input for viewing.
If you use any of the other video outputs on the Panasonic just connect it to the same type of input jack on the TV. Once again check the owners manual for more detailed instruction if you need them.
You must always be sure to have the proper input selected on the TV to be able to view it.
You can also respond back with more questions if you have any.
I am happy to help.
Dave
Posted on Jun 27, 2008
olhonda
SOURCE: Panasonic home theater SA-HT940
I have an SA-PT960 that came up with the same error.
I unplugged it and plugged it back in after 30 seconds.
Seemed to solve the problem.
Posted on Jul 25, 2008
How to improve poor bass
WWW WELECTRONICS COM SONY MHC WZ80D WZ 80D 80 HOME THEATER MUSIC SYSTEM...
Sony 12 Single Voice Coil 4 Ohm Subwoofer with Enclosure
Adding a subwoofer to your system will enhance the bass response. Sony lists the SA-WZ80 as an optional add on subwoofer for your system, I could not locate it on the web. I added another one of Sony's subwoofers that may work with your system. I suggest you go to an electronics store with the Sony MHC-WZ80D System manual and ask about subwoofers for your system. It does not necessarily have to be a Sony product. Best Buy may be able to help you.
May 19, 2014 | Sony MHC-WZ80D System
I hooked up the Panasonic sa-ht800V Home Theater Audio System SA-HT800V to an old tv the only hook up is the coaxial cable i turned TV to channel 3 and i get picture from the dvd is the a setting a need to...
Look at Page 12 if your TV only has RF coaxial antenna input...
http://www.retrevo.com/support/Panasonic-SA-HT800-Home-Theater-Systems-manual/id/312bh741/t/2/
Add in the Video cable (included) if the TV has an input for it and you'll be able to manage the SA-HT800 through the TV.
Make all the other necessary selections prescribed in the manual.
Jan 23, 2011 | Panasonic sa-ht800V Home Theater Audio...
How can I hook my alternate DvD player to SA-HT700 subwoofer without a cable ?
Without a cable? You probably can't unless wireless DVD is out.
http://www.retrevo.com/support/Panasonic-SA-HT700-Home-Theater-Systems-manual/id/312bh731/t/2/
If you want to use a wired DVD player, you would have to settle for just audio (analog stereo or optical digital) from it since this unit doesn't accept any video IN.
Jan 12, 2011 | Panasonic Audio Players & Recorders
Can i hook up my SA-WM20 subwoofer to my sony DAV-S500 home theater
As long as your sony reciever has a sub out connection you should be able too. This powered sub you have has a rca sub input which should coincide with the receivers rca sub out.
Aug 04, 2009 | Sony SA-WM20 Subwoofer
Need connector to a sony sa-va1 right and left speakers
Are you looking for connectors on speakers or need wires that hooked in speaker and home theater system?
Please intimate model number that is written on main home theater system to provide you info about speaker wires.
Jul 11, 2009 | Sony SA-VA1 Rear Speaker
Panasonic SA PT560
MY model is not in the site of panasonic, what is the problem? SA_PT560 a home theater with 4 standed and a subwoofer and a center speake, but as i said my model is not in the site! what's the problem?
Nov 26, 2008 | Panasonic Home Theater System System
No picture
on tv select corect input ok video 1 ect make sure cable out from dvd is in right spot yellow out and in the video in yellow on tv ect
Jan 24, 2008 | Panasonic sa-ht930 Home Theater Audio...
136 people viewed this question
 Grubhead
Grubhead
