Question about Frigidaire Washing Machines
How could test this motor directly??
How could test this motor directly?. The part number is C67PXEKE-4429 p/n 134156400. Thank you very much.
  • Cesar Cortez Jul 28, 2013
    Spanish if they can respond better. If not, I thank whatever on what can help me.
Where is the power window relay located on a 1964 Pontiac GTo with AC.
I believe those older cars used circuit breakers, not relays, for the power window systems. By using a test light, you don't know if battery voltage is present at the window switch. Maybe the voltage is reduced, somehow.
I would first check the switch's power with a voltmeter. If the motor is getting battery voltage, I would say the motor. If the voltage is low,
you had better find a wiring diagram, Dave, to trace it out.
Oct 25, 2014 | 1967 Pontiac GTO
No power at the Blower
Have you actually tested any of the fuses or relays for power ?
Fuse number 2 is hot from the key switch and powers the blower relay. Fuse number 12 is a 40amp fuse that gets power from the battery and powers the blower motor thru the relay.
Are both fuses hot with the key on ?
Jul 12, 2013 | 2004 Dodge Ram 1500
C67pxeke-4429
how could test this motor directly?. Thank very much.
Oct 11, 2011 | Frigidaire Washing Machines
Wfw8300sw05 Duet Sport Washer does not fill. Hoses have water, are attached correctly, not clogged. Replaced inlet valve. Still not filling. Dispenser motor does not seem to run. In manual diagnostic test...
Hello, Thank You for using FixYa. I will be helping you today.
The F30 code refers to a failure of the dispenser motor.If you bend an upward arch on part number 7 in this diagram sometimes it fixes the issue or you may have to replace number 8 http://lookup.bellparts.com/diagramenlarge/whirlpool/47215/00000753
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Washing Machines
Agitator wont agitate
Thank you for choosing FixYa and welcome. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter. Thank you very much for reading this tip and thank you for using Fixya
Jan 21, 2011 | Kenmore 22642 Top Load Washer
Im trying to troubleshoot a non-funtioning blower
To test the blower motor run a jumper wire from the hot side directly to the hot terminal on the battery. If the motor is in good condition it should come on. If it comes on that may indicate a bad resistor pack. Since the resistor is an electrical part which is self-contained would probably be easier to change than to test. You should do the resistor pack first (before the switch) because it is the easier of the two to change out. If replacing the resistor pack does not fix the problem then you will need to replace the switch.
Jul 23, 2010 | 2000 Isuzu Trooper
The turn table does not turn.
Hi.
If the microwave is heating , but the turntable is not turning then the only parts that may be responsible are the turntable motor, or the turntable motor coupler (the gear underneath the plate).
The turntable motor is tested energizing the motor directly. The operation must be done by a technician.
If the motor is defective, the motor must be replaced.
If the oven is not heating at all, or not starting at all, then the situation is different . In that case the magnetron, the door lock, and the control board may be responsible. More parts as diode and capacitor must also be tested.
If you want to get a quote on repair or verify warranty status, please call the number listed on the owners manual.
If you want to find parts you can enter the model number here.
Regards.
Dec 03, 2009 | Sharp Microwave Ovens
Machine won't spin
Motor part number is 8529936 about $200.00 any appliance parts store can order it. You can replace it your self. Also replace the direct drive coupling when you change the motor.part number 285753. Be sure to inspect your wiring harness and check the motor wire continuity before you put $200.00 into it.
Mar 27, 2009 | KitchenAid KAWS850L Top Load Washer
Letters and numbers appear in the display
I really need to get my CD case out to make sure the code is the polygon motor, not a good sign, could need a new laser assbly.
Jan 23, 2008 | Sharp AR-M205 Copier
Washing Machines Logo
64 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
