Ev-c100 ejects on rewind
Many times when I try to rewind a tape from my Sony EV-C100 8mm deck the tape will eject. Many times I can either keep trying and it will work or I will fast forward for 1 minute of tape then try again and it works. I'm skilled enough to fix it if I knew why it does this. Thanks in advance for any help.
  • 5,259 Answers
Try cleaning or replacing the mode switch.
Posted on Jul 29, 2013
Testimonial: "I'm looking at the service manual now. I will give this a shot. Thanks."
4 Suggested Answers
phil_frye
  • 295 Answers
SOURCE: loads tape then stops - won't play rewind fast
Way to go. Usually if you use anisotropic Alcohol with a few Q-tips works well I've found.
Try cleaning the other tap path items like the capstan that the pinch roller get's pushed up to also with this Alcohol. The cleaner the better the tape goes through. Much better picture.
Blessings,
A/V Media Guy
Posted on Nov 19, 2009
Testimonial: "saved the deck - I was going to replace it! fast response too! Thanks"
gopakumarg43
  • 74634 Answers
SOURCE: ev -c100 accepted cassete and
Hello
Accepting casette, and not ejecting is purly mechanical problem. In sony sets, all loading and unloding process is done by capstan motor itself. There is a belt connected from capstan motor to loading unloading mechanism. If this belt gets loose, this type of fault will occur. In some sony sets, this is a fiber type flat belt having teeth on it, and called as timing belt. It is not flexible one like rubber. There is liver mechanism connected with this belt to tight it, bey loosen a screw and an adjuster.Just open your VCR, and locate this belt. If it a rubber based one, replace it. If it is a fiber based one tight it. This will solve your problem. As far as intake is OK, the there is no wheel fault, Ejecting casette needs more force than intake. Do it with cofidence. If you need anymore assistance, feel free to get me through fixya. OK.
Posted on Jan 23, 2011
SD Tech
  • 14553 Answers
SOURCE: Tape isn't retracted into cassette upon eject on Sony EV-C100
l would sacrifice a old or bad tape here, remove all the tape inside a cassette and tape off the small sensor holes on each side.
That way no tape to damage and you can insert it to see what is happening.
What likely is the issue is when stop it, it or if the tape does not fully load against the drum with heads, when the arms retract that pull the tape out of the cassette the mechanism is not switching to rewind it back into the cassette.
Usually this means a belt is slipping or the idler unit is not working---belts can break or stretch or even come off---belts will get slopply or bad from NO use and it is common.
Posted on Dec 10, 2012
How can I fix my 2002 Honda Civic cassette player from ejecting cassettes. I tried a cassette deck cleaner and that gets ejected the same.
The auto-eject feature is normally triggered by the tape reaching its end. This causes the tape to tighten and then activates a trip lever that starts the eject cycle. Most auto tape decks that are not auto-reverse eventually have this problem. It is not usually the deck's fault, but it is with the tapes themselves. After many plays the tapes get wound too tight on the reels and drag, causing the auto-ejection. This is especially true with the thinner, larger tapes found in the C-90 and C-120 varieties. Try taking the tapes to a regular tape player and then fast-forward them from one end to the other and them a full rewind as well to loosen the tape on the spindles and re-distribute the tension. Hopefully this will work.
Sep 25, 2015 | Audio Players & Recorders
Dec 09, 2012 | Sony Video Hi8 Ev-c100 Ntsc Video Cassette...
I have taken a rarely used Sony EVS2000 out of the closet to transfer some 8MM tapes but after loading the first tape I can't get any motor functions to work. No play, FF, Rewind or eject will function....
sounds like the mechanic is stucked. this happens because due time the used grease is loosing its viscosity. cleaning mechanic and regreasing will help. btw change of old rubber parts are recommended also.
Feb 27, 2011 | Sony EV-S2000 Hi8 VCR
Unit accepted cassette, won't eject
It is likely that either the drive belt has broken or is slipping. Because the unit is still in "play" mode, the mechanism won't let the door open up. If you have not opened up these units before, do not attempt it now. This unit should be taken to an experienced tech for repair. Where are you located?
Dan
Apr 08, 2010 | Sony EVC100 Hi8 VCR
Can't eject tape from deck
On Sony DSR-80P error 02-221 and 02-291 is a problem with the tape pull-in or eject. Mostly the tape stickers are bad situated over the stripe-cover at the top, which should be moving freely!
Remove the stickers from the tape or put them lower on the case. If the tape is already inside the machine is unable to reject the tape - disconnect the machine from electricity to open it or call service...
greetings from berlin, matt.
Jul 05, 2009 | Sony HVR-1500 HDV VCR
Tape won't eject,tv keeps shutting off
sounds like your tape is jammed try turning the tv on and ejecting the tape while using something to try to lift the tape up and out good luck.....
Dec 19, 2008 | Emerson EWC1301 Combo
Code 3L117C ???
None that I could find. Trash time for this Sony
Dec 10, 2007 | Sony SLV-798HF VHS VCR
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Electro Med Services...
