Question about Microwave Ovens
Schematics for singer microwave model SGM-25
URENTLY NEED THE SCHEMATICS FOR A SINGER MICROWAVE MODEL SGM 25CS PLEASE. ERNESTO CUADRA KINDLY ATTACHED IT TO MY QUESTION BEFORE BUT UNFORTUNATELY IT IS A BLOB AND CANT BE READ OR PRINTET KINDLY MAIL me desere@multinetgroup.co.za with the schematics
  • Desere Bouillon Jul 29, 2013
    Ernesto samswebsite is saying its not their diagram they can not assist with schematics. As you tried to attach it please please just mail it to me.
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
Go to www.samswebsite.com and get it. or go
God bless you
Posted on Jul 28, 2013
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: where can i get schematics for singer microwave model SGM-25CS
see the diagram attached. God bless you
Posted on Jul 13, 2013
Schematic or SERVICE manual for control panel pcb of Samsung microwave model MS123SCE
Most manufacturers will not provide schematics or service manuals unless you buy them. U might try to google for the service manual or the specific problem for the specific machine and read the hits for help.
Aug 27, 2015 | Samsung Microwave Ovens
Schematics for kitchenaid model kemc307
see the information attached for fix it. Merry Christmas
Dec 16, 2013 | KitchenAid Microwave Ovens
Singer convection microwave oven
see this steps and fix it. God bless you see the picture attached.
No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
3. Open thermal protector or thermal fuse.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).052d2556-c90b-4f50-a4d7-344516db8003.gif
Jul 13, 2013 | Microwave Ovens
NO HEAT FROM MICROWAVE
use the common sense,clearly, logically, and fix it .God bless you
can take some time. This is where you must be able to read a wiring diagram and do some "live" checks on parts. First easy check is to make sure power is coming off your control board at the MW relay. Make sure of the wires and test here, if you have 120 volts at this point, you have ruled out a lot of parts that could be the problem. You have now ruled out any switch problems, control board problems, or a thermostat or 2.If you do not have power from that MW relay on the control board, you must trace the wiring back to see if the proper voltage is going through your switches, any thermostats, and arriving at your control board. Your wiring diagram on your sheet will show you where and what to test. Below is a general switch test troubleshooting guide.
mwswitchtest.jpg mwswitchtest2.jpg If the proper voltage is coming into your control board and you are not getting voltage at the MW relay, then you need to replace the control board. If voltage is interupted by a thermostat or switch from your testing to the control board, then replace that part.Now, testing from the MW relay on to your transformer, high voltage capacitor, magnetron, and diode. Do not do any voltage reading from the secondary side of the transformer on, this can be a deadly microwave oven repair if you do not follow directions. This can result in electrocution and the "blowing-up" of your voltmeter, only do OHM testing with the power off and the capacitor discharged. Someplace in this circuit, usually before the transformer, you will have another thermostat to test. It is usually mounted on the magnetron. Do a quick OHM test to see if it is open or closed.
Now to test either the transformer, high voltage capicitor, magnetron, and diode, you must test each part separately. A good rule of thumb, if your capacitor is bad, change the diode also. Another note, if you are working on an OTR model and you have determined to be one of these "heating" circuit parts, you can not test these parts until you take the unit down. If you don't have the parts with you and you have to order them, order the magnetron, capacitor and diode and you will have a 90% chance of solving the problem. If it is an older microwave, order the thermostat also, most times you can return un-used, un-opened parts. Check with your parts supplier. This way you only have to take the unit down once.
To test these parts, scroll down this page and you will see a chart with component tests. Follow the instructions to find which part(s) are defective in your microwave oven repair.
Aug 02, 2012 | Kenwood Microwave Ovens
I have a Singer Juice Giant II but no instruction manual. Where would I find the instructions?
HELLO.
Way out to the problem.
The best place to get the microwave oven manual guide is to visit the manufacturer website to order for the manual stating the microwave model number and give our house detailed address.
However microwave manual guide can also be purchase at any microwave oven authorized dealer around your local area with the model number for compactibility(easy use).
Thanks.
Sep 19, 2011 | Microwave Ovens
Bulb replacment for GE Microwave Model JE1540wv002
There should be a very helpful "mini-manual" hidden inside the unit behind the control panel. It has wiring, schematics, and troubleshooting info.
Yours will be found as JE1540WV02 (instead of 002) here: http://www.tinyurl.com/gv383
Nov 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
275 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
