Question about Amcor CF14000 14000 Btu Portable Air Conditioner AC CF14000E-SILVER-RB
CF14000E Need duct parts for ac
C2002 Dodge Ram 1500 AC control only works on highest setting. Need new control?
Probably the resistor pack for the blower motor. It should be behind the glove box. Two screws hold it in place to the ac ducting. As long as you don't have digital temperature controls they only run about $25 at any parts store.
Aug 25, 2016 | 2002 Dodge Ram Pickup 1500
Ac blend actuator location?
It is located deep inside the AC air ducting between the AC evaporator core and the heater core. The dash must be removed to access the part in most cars and trucks. You never say make, model information or year so it is hard to more precise..
Jan 09, 2016 | AC Cars & Trucks
Cleaning AC vents and ducts
If you are in the market for an air duct cleaning check out Air Duct Cleaning.
Mar 28, 2014 | angieslist.com
Does not blow air through ducting
sounds like duct damage or restriction in duct work.
Sep 02, 2012 | Dometic 457915 Duo Therm Brisk Air...
Need a service manual (not a user's manual) for Amcor CF14000E
THEY WENT BELLY UP TWO YEARS AGO.WwHAT TYPE OF INFORMATION ARE YOU LOOKING FOR ?
Aug 26, 2011 | Amcor Heating & Cooling
We do not have a window in the room this need to be installed in. Does the window installation kit allow us to install the pipe that goes outside through our exterior wall of the house? Like a dryer vent...
I think you probably could. As most manufacturers of portable AC units allow for this. It's what called a semi -permanent installation . The dryer duct idea will work if the shaft part of the dryer duct is the same diameter as the window mount duct and the shaft of the dryer duct is long enough to go thru the wall and leave enough for the AC Exhaust Duct to hook to. Be sure that the flap door of the dryer duct moves freely and will not get stuck in the closed position. That could be a big problem if it does.
Keep in mind, you will not be able to add any length the AC duct hose. It must remain the same.
Hope this helped answer your question and things for choosing FixYa.
Aug 01, 2011 | Sovereign Royal 9000 BTU Portable Air ...
How do i remove entire dash from a 1987 chevrolet astro to reach the ventilation system ducts and air box? including removing guage cluster speedometer cable. Goal remove non-ac parts and put AC parts from...
the ac evaporator goes into the heater box under the good on the right hand side. Most everything else can be installed just by removing the doghouse.
Oct 13, 2009 | 1987 Chevrolet Astro Cargo
COLEMAN MACH 3 MOUNTING ON INSIDE OF CAMPER NOT ALIGNING WITH MY
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Jul 01, 2009 | Coleman Heating & Cooling
Amcor CF14000 14000 Btu Portable Air Conditioner AC CF14000E-SILVER-RB Logo
15 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
