Question about Toys
Need to reprogram a Polar Start remote # PS-4600 TW to the command unit
I ordered a new remote as the old one simply fell apart. I was given a process that did not work to pair the remote to the command unit. Any hints would be appreciated please.
  • 518 Answers
SOURCE: samsung air conditioner remote ruined--need new one
You're going to need the model number. It may be under the front cover.
Geno
Posted on Mar 10, 2008
SOURCE: changing remote command mode for sony rdr-hx525 without remote control
Hold the "Enter" button along with the numeric button for the command mode you selected in Setup. This will reset the remote to work in the command mode you selected (also lets you get back into System Menu to try other command modes). If you pick a different command mode, you'll need to do this again to reset the remote to the selected mode. Found this info courtesy our friends on the Internet - no thanks to Sony's manual...
Posted on Aug 16, 2008
SOURCE: Need code for universal remote Sylvania LC320SL8
We bought a Sylvania LC420ss8 HDTV.
Our current universal remotes would not work, I followed the advice on this site and got a Sony
RM- VL600 Sony Untergrated Remote Commander, use page 16 in the manual to teach the new remote off of the remote that came with the TV. It really works. I am happy with the tv and remote.
Posted on Sep 17, 2008
  • 1214 Answers
SOURCE: garage door will not reprogram its remotes
Did you actually go to the power head and push the program button, then the remote button?
Is there a small wire hanging down from the power head? It's the antenna wire.
Posted on Jan 28, 2009
SOURCE: My infrared remote does not work. I have an Audi A6 1995
Do you have memory seats as well? If so follow these steps I am going to refer to the keys as A and B as you have 2 of them
1) Unlock car with key A
2) Turn ignition into ON position with key A and roll down the window
3) Point Key B at IR Sensor and Click twice (perform both clicks under 5 seconds)
4) Turn off ignition and pull Key A out
5) Turn ignition into ON position with Key B
6) Point Key A at IR Sensor and Click once
7) Turn off ignition and Pull Key B out
Key A should be programmed as the Master Seat Program and Key B should be programmed for the Secondary seat program
So when you set your memory seats Key A is for Memory Position 1 and Key B is for memory position 2
if you don't have memory seats then you only have to point the receiver at the sensor and click once. That should just sync the IR Frequency and Codes
Posted on Mar 08, 2009
I have a 2006 jeep commander that came with the cool start remote start system and it dont start unlock lock or nothing but the blue light works on the remote?
remote may need a new battery despite the light coming on. It could be the remote needs reprogramming. Do you have the user or alarm manual? you'll still need a spare key fob to get you into the vehicle?
Jan 04, 2013 | Cars & Trucks
My panasonic dvd recorder / remote control is not working On pressing button on remote I get dvd2 on recorder screen but no other response. I have tried reset without effect
Try reprogramming the remote itself; i.e. point remote at unit (while on), press and hold the [2] and [ENTER/OK] buttons together for 5 - 10 seconds, then release. The remote's command should now match that of the unit (DVD 2) (the unit should now recognise the remote). Failing that, remove batteries from remote, replace with new ones (just in case) and repeat the above suggestion. You should not need to reset the main unit.
Whenever the batteries are replaced in Panasonic remotes, in some cases, a remote command reprogram is often required to ensure that the remote commands the unit fully and correctly. You may find this procedure outlined in your instruction manual. Hope this helps a tad.
Aug 14, 2011 | Televison & Video
Took apart a polar s150 watch to change the battery. I went too far and 2 little springs fell out and a small black rubber donut. I don't know how/where to put these back. The two springs appear to...
Hello Clintsanders,
I am sorry to inform you but there is no way that you can repair the unit yourself, you will need to return the unit to Polar to be repaired. Here is a LINK to Polar and all of there service centers and the numbers and procedure that you need to follow in order to return your unit for repair.
Sorry but this is not a DIY item.
Thank you for choosing FixYa.com
Justinbur167
May 16, 2011 | Polar S150 Heart Rate Monitor Wrist Watch
Changes to fios and have motorola 7100 program my harmony 880?
If you have changed your hardware setup, you must reprogram your Harmony 880 using the Logitech software. You should be able to simply step through the 'interview-like' process and enter the new make and model number of the new hardware. It is usually recommended to add the new device first and then associate the new device with your existing Activities. Once your Activities have been mapped to use the new device, you can delete the old one. Once everything has been completed in the software, update your remote through the USB connection. Hope this helped!
Jan 12, 2010 | Logitech Harmony 880 Universal Remote...
Pump fell apart - inner piece fell out
On these newer pumps, the plastic piston comes apart, and to fix it a new part is in order. Without looking at it, I think that is what might have happened. Bicycle pumps are almost throw-away items these days. In the old days you could buy all sorts of pump parts, but not anymore. Good luck
Jan 05, 2010 | Cycling
Logitech Harmony One remote is controlling 2 TiVOs at once.
Please try learning the some commands from one of the original remotes for thr tivo. If this fixes the problem, i suggest that you learn all commands from that remote.
Launch the Logitech Harmony Remote software and login to your account
1. Click on the Devices tab
2. Click on the Learn IR button for the device you want to learn command(s) to.
**NOTE: When learning new commands, there are three different options available:
-You want the Harmony Remote to learn a single command that is already listed in the software
-You want the Harmony Remote to learn more than one command at a time
-You want the Harmony Remote to learn a new command, which is not listed in the software
a. Click on the Learn button next to the command you want to learn - Proceed to Step 5
a. select one or more commands by clicking on the check box next to the command(s) you want to learn and then
b. click on the Learn Selected Commands button
c. Proceed to Step 5
You want the Harmony Remote to learn a new command, which is not listed in the software:
a. Scroll down to the button of the page
b. In the Learn a New Command box click on the text MyNewCommand
c. enter the name of the command you would like to teach.
d. Click on the (Learn New Command) button
e. Proceed to Step 5
5. Follow the onscreen directions for learning commands, plugging in your Harmony remote when asked and lining up your original remote to the Harmony as illustrated on the screen.
6. When a command is successfully learned, a check mark will appear next to it. If learning more than one command, the software will then prompt you to learn the next command.
7. The commands that were learned should now be identified as from "Your original remote" and highlighted in turquoise.
8. When you have finished teaching the commands, click Done button to save your changes
9. Click on the Update Remote button to update your remote
If this does not work, try :
To teach commands for your Device that did not work properly in normal mode:
1. Click the Devices button on your home page.
2. Select the Device you wish to learn commands to.
3. Select Learn Infrared Commands.
4. Click Custom. The page will reload.
5. Select the boxes for commands you would like to teach, and click Learn Selected as Raw.
NOTE: When teaching each command, press the button on the original remote for as long as required to control the device. The commands will be learned with the exact format that is sent by the original remote.
If you have any trouble teaching the commands in RAW, complete the following steps:
1. Verify you are pointing the original remote at bottom end of your remote, and are holding the remotes 2-4 inches apart.
2. Minimize the amount of light that could interfere with the learning process by covering the distance between the remotes. Block out sunlight, or turn off the lights.
3. Check that you have installed new batteries in the original remote you are trying to use to learn commands. If the batteries are low, the signal coming from your original remote may be too weak for the remote to detect.
4. Be sure to hold down the button on the original remote for at least 1-2 seconds, otherwise the signal may be too short for the remote to process.
5. If you continue to have trouble teaching the commands, start with the remotes 2 inches apart. Then try again with, slightly increasing the distance each time (2.5 inches, 3 inches, etc).
6. Vary the angle at which the original remote is pointing at the bottom of the remote.
7. Ensure the device's original remote is sending infrared (IR) commands.
NOTE: The original remote is sending RF or UHF commands from the original remote if it will control the device from another room, through a wall).
Oct 04, 2009 | Logitech Harmony One Advanced Universal...
Panasonic DMR-EZ28 won't talk with remote
hi you need to reprogram the remote to fit with the unit there have 3 codes for remote 1 or 2 or 3 to reprogram your remote with the code indicated on your display press and hold the [3] and [ENTER/OK] buttons together for approx 5 to 10 seconds, then release
Jun 24, 2009 | Panasonic DMR-EZ28K DVD Recorder
Remote got wet
you can try reprogramming the remote to the remote start but if that doesnt work you will need to purchase a new one.
Dec 06, 2008 | Crimestopper EZ-95FM EzeeStart 2-Way FM/FM...
Sony STR-VX550 does not obey remote commands from "optional" Sony RM-S750 remote commander. RM-S750 is working properly and communicates all commands to my other STR-VX550. Receiver appears to be...
You appear to have reprogrammed your remote. Remotes can work with other units made by the same company. But the keys will pass out different signals to each unit. You need to find the correct code for your unit.
This could involve selecting a combination of keys on the remote and possibly some controls on the unit. Then entering a numbers on the remote.
It could be that the unit has the option of selecting a remote mode 2 also. So you will need to select it back to one or whatever it is supposed to be.
Jul 09, 2017 | Sony Audio Players & Recorders
Reprogramming my universal remote
try contacting Philips Customer Support: (800) 722-9377
there is a way to try to autoprogram but i cannot find a manual
hope that helps
Jan 27, 2008 | Philips PM3S Remote Control
Toys Logo
110 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
