Question about Dryers
Blowing Fan Not - Dryers
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 43 Answers
Did you plug it in?
Posted on Jul 28, 2013
My A/C is not blowing but the lights are coming on. What does this means?
Does the fan blow warm air or is there no fan working at all? If blowing warm air, suspect a low AC freon charge. If not blowing any air, suspect a blower fan/resistor/wiring issue. You can try slapping the glove box area with the palm of you hand while the fan is turned on to see if it will start working again. If it does, the fan motor will need to be replaced. If still not working, electrical diagnostics will be required
Jul 19, 2015 | 2012 Dodge Avenger
Air conditioner isn't blowing cool air and it's not coming out of the vent very fast
Check to see if air is blowing out the back side of condersor,outside ,maybe fan not blowing on outside, or freon low.
Mar 17, 2015 | Goodman Heating & Cooling
Fuse for cooling fan keeps blowing
check to see if the fan spins freely if it is sluggish or stuck replace the fan motor as it is drawing excessive current and blowing the fuse.
Dec 29, 2013 | Chrysler Pacifica Cars & Trucks
Car overheats while idleing fan not turning on ac not blowing
Check the Fan switch at the bottom of the radiator, if you disconnect it and have a power feed to the switch then it isn't a fuse.Bridge the terminals and if the fan comes on then the fault is probably the switch.
Jul 01, 2012 | 2000 Jeep Grand Cherokee
I was cleaning me pc and forget what way the 2 fan go inside one blowing in and the outside is blow in to and my friend is telling me that the one on the outside sould be blow out not in what way...
Generally the purpose of a chassis fan on a desktop is to cool the machine. If there was only one fan it should be blowing out. If you have 2 fans then at least one should be blowing out.
(Assuming that the second fan that is blowing in is not allowing dust into the chassis of the computer.)
Hope this helps
Mar 16, 2011 | Systemax Tiger (SYXS-DC-1000) PC Desktop
My ac/heater fan stops blowing then it blows sometimes? The air is still cold just not blowing out. when it does blow it is cold.
replace fan speed resistor block if this only happens on lower fan settings if it happens on high fan speed also, replace blower fan
Jan 20, 2011 | 2001 Isuzu Trooper
The freezer is freezing just fine but the fridge is not getting cold at all
make sure the fan is blowing and the return vent is not blocked. if the fan is not blowing, see if it is blowing in the freezer. if not, replace the fan. also see if the evaporator coils are not frozen up.
Nov 10, 2009 | GE Refrigerators
HEATER NOT WORKING IN 2001 LEXUS RX 300
you most likely have a bad airmix servo. this happens alot on these. they are expensive to replace too.
Sep 10, 2009 | 2001 Lexus RX 300
Fan blowing while car is off
If the A/C knob is not set to 0 at the time ignition was off, the fan could run for a little and then off itself.
May 17, 2009 | 2002 Volvo S60
Fan not blowing air.
theres a small toggle switch on the fan
that switch is to change direction on the way the fan is blowing
one direction for downward blowing
the other direction is for upward blowing
depends on the area you have to determine which is the best, but i doubt area restriction will hamper force air blowing, air will flow regardless, the area might be big so you dont feel it.
as being living in the attic, HOT AIR rises, so you might want to invest in some installation for the ceiling, because whent he sun hit the roof, it will create an oven effect, in your living area. the hot air is always present, you should have a ventilation fan blowing the hot air out, like thru a small window, the more hot air you blow out, the better.
not sure if this make sense. not sure how big the room is, as FANs are NOISY by nature.
Aug 16, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
13 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
