Question about Garden
Engage blades on john deere gt 225 and mower shuts off
Mower was running fine,shut off and next time I tried to cut grass shut down when engaging blades. runs for a few seconds and shuts off. checked filter and made sure nothing was jammed around pullys
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere gt 235 electric blade engagment but
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
Posted on Mar 21, 2010
SOURCE: I have a 15.5 HP Sears Craftsman 42
I'm betting that you need a new safety kill switch - probably the one underneath the seat (the spring-loaded plunger switch that won't let you use the machine without your *** in the seat). Could also be the one behind the "dash" that is associated with the blade engagement mechanism.
I know that the under-seat-switch cannot be bypassed or it will disable the machine in the exact way that you described. Why do I say this? Because I just tried to bypass my own "***-in-the-seat-safety-switch" on my very own 15.5 HP, 42" Sears tractor, and it responded by punishing me - the absense of the switch caused the motor to cut out when I tried to put the machine in gear AND/OR engage the blade. It seems to have some measured capacitance - the absense of same seeming to interrupt the ignition timing enough to shut the motor down when you attempt to get anywhere past neutral or engage the blade. These "safety" switches may be needed by a very few who prefer to be drunk while they mow lawns on steep slopes that their tractor mowers were not designed for, but I find these items to be troublesome and enfuriating. My trees shed a lot of sticks in high winds, and I can't stand shutting the machine down and restarting it EVERY SINGLE TIME I have to dismount to clear sticks or other obstructions out of my mowing path. This is an obnoxious, "nanny-design" feature that desparately needs to be discontinued. It also makes both jump-starting the tractor and electrical troubleshooting much more difficult than they should be. The tractor should let you dismount without shutting down, as long as you have disengaged the blade and shifted into neutral. It should also let you jump start with jumper cables - impossible to do with your rear end in the seat. By the way, call Manufacturer's Supply, Inc. at 1-800-826-8563. They may have a replacement - their item number 31-9664 might do it, but talk to them first. I'm calling them tomorrow. Good luck.
Posted on May 17, 2010
Testimonial: "VERY THOROUGH - THANKS"
SOURCE: Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Posted on Nov 24, 2010
I have a John Deere riding mower LA 110 automatic. When I engage it to cut grass, it just dies like a safety measure. What could be causing this? Happen while in the middle of cutting the lawn.
how thick/tall is the grass ?
when was it last serviced ?
if dying or shutting down while operating
could be an electrical / safety kill switch connection
or engine/ governor spark issue
before next startup do a visual
have a look to see everything is free and working under the cutting platform
Jun 17, 2016 | John Deere Garden
I have a 2002 GT 225, it won't move in reverse. The pto shuts off in reverse and it is engaging reverse but moves very slowly if at all. It was working fine until I tried to cut very long grass.
I am happy to tell you that about 6 mos. ago I bought a John Deere 300X. The first thing I did, even before I mowed, was to disable the cautionary reverse silliness. It involved simply running a wire (not too heavy gauge) from one connection to another connection. I don't remember exactly which ones or I'd tell you. I assume that this will work for many brands, and if it will, you can find it on the internet. I found a video that showed me exactly what to do. You should do the same.
May 12, 2016 | Garden
Why does the engine slows down when engaging the blade
check fuel filter and pump pressure starving for gas
Jul 02, 2014 | John Deere Garden
The blades on my John Deere GT 235 will engage but when lowered to cut the grass they stop. Any suggestions will be helpful.
you may have a bad belt. when engaged it could be slipping or the belt has jump off of idler which keeps the belt tight on the rest of the pulleys
Jun 30, 2014 | Garden
My john deere keeps shutting down when I try to engage the mower blades.
well first off be sure the throttle is all the way up secondly check to be sure the blads turn freely could be the belt is pinched or off one of the pullies and causeing to much friction for the motor to turn it
May 04, 2014 | John Deere Garden
John deere d170 hit rock and mower will not engage
well if you READ your owners manual its tell u how to reset it or fix it...
May 15, 2017 | John Deere Garden
Blades stopped can't restart now engine won't turn over
Check battery voltage should be 12v or above. Battery could have gone bad or charging system bad. Voltage draw of electric clutch pulled battery down.
Sep 25, 2017 | John Deere 420,1020,2010,2020,2510,2520...
John deere gt 235 electric blade engagment but mower dies when you try to engage
Mar 20, 2010 | John Deere Garden
Garden Logo
134 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
