Question about Car Audio & Video
Kenwood kc-x1 thx preamp: lights are on but nobodys home
I bought a kenwood kc-x1 and km-x1 preamp and tuner set. The preamp has no output to the amp. when I look at the volume setting and turn the volume control, no matter how far I turn the knob the numbers change 1 or 2 +/-. I was wondering if this was a common problem and what could be done to rectify it. I do not have the remote and the amp works just fine.
5 Suggested Answers
KaeZoo
  • 156 Answers
SOURCE: No Sound - boat stereo
Assuming that the four speakers are connected to the amplifier, then the amp is the most likely problem component. Does the amplifier show a power light when the system is turned on? Note that there is probably another fuse in the amplifier power wire, near the battery.
Posted on Mar 16, 2007
SOURCE: kenwood control amp KC-206
Sounds like a low voltage to the front panel as the indicators are there such as control window illumination is dim and the remote does not function.
The remote sends an invisible signal to a detector just behind the front panel and if the signal from the remote is nice and strong from your new batteries in the remote then it must be the panel electronics.
I have found that if you clean the output panel of the remote with a damp cloth and the same to the front panel glass you may be lucky. Just Damp please not dripping in water!!!!!
If ypu keep the amplifier system very clean then this wont be the problem...But this action has worked on TV's with remotes...
If this doesnt work then a service is due....sorry....no quick fix..
Cheers YOU BEUT
Posted on Nov 03, 2007
SOURCE: Kenwood stereo control amplifier KC-206 doesn't work
I was able to use an universal remote control that I have, a Radio Shack Kameleon 6 in one remote control which I was able to program to run the audio portion of the Kenwood KC 206 control preamp. By adjust the remote sensor volume to max, I was able to get maximum volume out of the unit and drive the power section very nicely. Now I have to get up and manually turn the manual volume control for addition volume adjustment.
Hopefully Ken can find a remote that he can control the Kenwood control preamp the same way I did. Good luck here.
Posted on Dec 02, 2008
SOURCE: Volume turned up, kenwood shuts off briefly...
does it keep cutting in and out?
if so i think you have your polarities crossed
make sure you have negative to negative positive to positive
Posted on Jan 28, 2009
Pertaining to my Kenwood stereo control amplifier kc-206
Turner password was activated by remote.
Try downloading using the model number the deactivating password.
Oct 23, 2016 | Audio Players & Recorders
How can i hook up my kenwood stereo control amplifier KC-105 to my GPX home stereo system?
If the GPX has an headphone output you could use the a stereo headphone jack to two phono cables lead. Connect them to the "aux" socket of the amp, or another suitable - not a phono or deck - socket.
You would have to keep the volume level low on the GPX unit, but apart from that all the functions should work.
Aug 04, 2015 | Kenwood Audio Players & Recorders
Kenwood KM-X1
I suggest build new non-powered woofers with cabinets.
If you really get serious with your sound you'll need a workshop
for customizing it all. A converted garage is nice.
See mine in photo for an example:
Oct 13, 2017 | Audio Players & Recorders
What is the idle current or voltage?
Idle current is a small amount of current that is flowing through the output stage of the amp with no signal applied. If this current is too high, it could lead to the amp overheating and eventual failure. If it is too low, it will cause distortion in your audio output.
Jul 01, 2013 | Kenwood Km-106 Km-206 Amp Instruction...
7.1 preamp output
called onkyo and kenwood they explained in detail how to hook up.
Jan 06, 2010 | Onkyo M-282 2-Channel Amplifier
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Am trying to hook up an older kenwood home stereo system and dont know where all of the wires go. There is a model #kt-87synthesizer, km-207 amplifier, double cassette kx-77cw, stereo control amp kc-207...
Okay you are going to need 5 sets of RCA cables of 3 foot lengths. Ensure the KM-207 is adequately ventilated unless you want to burn up the KM-207. Next you will want to place the KC-207 near the KM-207 and connect the "Output to Amp" from the KC-207 to the "Input" to the KM-207. Now you may stack the KX-77CW, the DP-M97 and the KT-87 Tuner in no particular order. I tend to place them sideways so I may access them just in case I don't like how it is set up. Unless I can access them from the back. "Output" or "Play" from the DP-M207 goes into the "CD Input" in the back of the KC-207. "Output" or "Record" on the KC-207 "Tape 1" goes into the "Input or "Record" on the KX-77CW. "Output"or "Play" on the KX-77CW goes into the "Input" or "Play" on the "Tape 1" of the KC-207. "Output" on the KT-87 Tuner goes into the "Tuner Input" on the KC-207. Here is a trick to help you new stuff uses color codes such as White or Blue RCA cable ends, and Red RCA cable ends to indicate White or Blue for Left channel and Red for Right channel. Now you didn't indicate how to hookup speakers so I will not assume you are concerned about anything but using headphones for listening. I hope this has been of assistance.
Aug 29, 2009 | Kenwood Audio Players & Recorders
Kenwood installation manual help?
Click HERE for Kenwood support and manuals.
May 15, 2008 | Kenwood Audio Players & Recorders
Reciever
Since Kenwood makes a lot of amps, I can't be specific. Check to see if speaker (A/B) is switched on. Make sure "mute" switch is off. If useing tuner, make sure to hook up AM/FM ant.
Apr 14, 2008 | Audio Players & Recorders
How to turn on Kenwood KM-Z1 amp with SL16 input
Have you plugged the amp into the AV9000. Check if the outlet you are using is switched or unswitched. Changing the outlet will most likely do the trick.
Jan 12, 2008 | Audio Players & Recorders
Car Audio & Video Logo
103 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
