Question about Garden
Drive belt Need a diagram for a drive belt or a craftsman Gt kohler command 20 v twin. Model number 917272950
  • 24 Answers
Should be on your deck somewhere or look it up on line
Posted on Jul 29, 2013
2 Suggested Answers
  • 376 Answers
SOURCE: Belt Diagram needed on Craftsman Kohler Command 20 Hp RidingMower
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter your model #, click enter, then scroll down to the sudcomponent list and click on 'Mower Deck' if it's your blade belt you need to see or 'Ground Drive' for your transmission belt. Hope that helps. Dwain
Posted on May 15, 2009
Part # for drive belt craftsman gt 3000
http www searspartsdirect com model part 3000A 0736 1509200 WL000217 00005... Lawn Mower Variable Speed Belt Part Number 754 0280 GUARANTEED FIT from... Belt 715 0 Part Number 754 0370 GUARANTEED FIT from Sears PartsDirect
Here are 3 links to Sears. The first is a diagram of the drive system of the gt3000. They show 2 belts. One looks to be the drive belt and the other is for the blades. Those are the other links. Hope this helps
Jun 25, 2015 | Craftsman Garden
Drive belt diagram craftsman
if you can provide the model number (usually under the seat), I might be able to pull up a diagram.
Aug 27, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Need a belt routing diagram for a 15.5hp craftsman kohler command model #917259542
With the model number you have you can search for craftsman parts and go to sears and enter the model number and select the deck and find the replacement belt routing sticker for your deck. It goes on the top, left, front.
The belt comes from the motor pulley in between the pulleys in the middle and around the back of them, then out to the front side of blade pulleys, around the outside and straight across the back from blade pulley to blade pulley. Not a hard routing. If looking down on the deck from the seat it will look like an inverted T. Watch out for the belt keepers that help keep the belt aligned in the pulleys, may need to gently retract them to get belt in the pulley.
Jul 07, 2011 | Craftsman Garden
Where can i fine manual for engine replacement
TO REMOVE THE PULLEY FROM THE CRANKSHAFT END:
Remove the blade belt and, if needed, the deck to give yourself more room to work. Apply your brake pedal and lock it down, this will relieve the tension on the ground drive belt.
If you have an electric blade clutch, find the plug where the wire goes over from the clutch to the frame and unplug it.(Electric clutch will be heavy when unbolted so be ready for it.)
In the center of the pulley or blade clutch you will find a long bolt (most likely a 5/8 head on it) You may need a deep socket to reach it depending upon the type of stack pulley on it, remove this bolt and the pulley should slide freely on the crankshaft. slide it downward and slip off the belt on the top of the pulley then remove the pulley the rest of the way
Oct 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Belt diagram craftsman 917 2733100
Assuming your model number is 917.273100, go to ... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number, hit search then scroll down to Ground Drive
Jul 27, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Jul 02, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
May 15, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
We need to remove the belt
Hello ttourek:
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left. Select the Dround Drive for a View of the Belt and Other Related Components.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 09, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
88 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
