Iomega lphd120c I cannot connect to my laptop. When I turn on the backup drive, it beeps a couple of times, and that is it. the light is still on, nothing shows up on the laptop. I know the backup drive still works because I have used it on a PC.
SOURCE: ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
I had 3 beeps, pause, 3beeps, pause and so on.
Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
Posted on Nov 20, 2008
SOURCE: iomega external hard drive not reading
Check out following resource that may help you to find solution:
http://free-tips-tricks.blogspot.com/2009/01/hard-drive-not-recognized-found.html
Posted on May 19, 2009
Crankstart
  • 696 Answers
SOURCE: My Iomega hard drive (MDHD-UP) not working, only beeps
Hi, Generally the HDD inside the shell can handle about a 6' drop when it's off and about a 1' drop if it's active. The beep is most likely coming from one of the shell components. Take the drive to a pc store and ask the techs to move the HDD into a new shell and test it for you. Most likely it's ok and you can just buy a new shell/enclosure for it. If that doesn't work it may have been actively reading/writing when it toppled and as the drives are a lot more delicate during that process you may need the help of a recovery pro. If that's the case comment back here with your country/state/city and I'll pass on a recommendation for a nearby facility that can assist you in retrieving the files. Chris
Posted on Jun 09, 2009
SOURCE: PC not recognising Iomega Prestige 320gb usb portable hard drive
Does the drive show in Device Manager? Right click on 'My Computer' and select properties, the open device manager.. Navigate down to Disk Drives or Hard Drives, click on the plus sign and see if your drive is listed. If it is, then right click on the drive name and open properties for the drive. Click on the 'Volumes' tab and hit the 'Populate Button'. It may be the disk just needs initialising, then reformatting before you can use it. If it does need initializing, a wizard should appear to guide you through the process!
If this doesn't solve your problem, try using a different USB cable and/or USB ports on your computer, and ensure to unplug all other USB devices other than keyboard & mouse.
Posted on Mar 08, 2010
SOURCE: Iomega Screenplay Pro HD Multimedia Drive works on PC but not on
If the blue light continues to flash after the screen goes black, then you need to reinstall the firmware. Look at http://screenplayprohd.wikia.com for information about getting the firmware and installing it.
If the blue light goes solid after the screen goes black then you probably just need to switch the NTSC/PAL selection. Press that button on the front panel several times, waiting a few seconds inbetween in press. If it continues to be invisible, plug the drive into another TV using the composite cables instead of HDMI to confirm if the menu comes up at all. If it does, reinstall the firmware.
Posted on Apr 06, 2010
No connection to data on Iomega Desktop Harddrive Hi-Speed USB2.0
Try connecting Omega hard drive into another computer to recover/backup your data.
Jun 07, 2012 | Iomega Computers & Internet
Instructions to backup my PC to my Iomega HDD 80 gb USB external hard drive
Start>All Programs>Accessories>System Tools>Backup>enter This will bring up the Backup/Restore Wizard.which you will choose Backup. In the next window you have options as what to backup. Make your choice and go to next window. Next window is where you choose where to backup and you will then pick your Iomega HDD 80 gb USB external hard drive. Click on next. Good Luck!!
Apr 28, 2011 | Computers & Internet
My iomega external hard drive just beeps when ever i turn it on. How can I fix this?
ummm, i fixed my problem i had with a iomega 500gb external hard drive, it was beeping at me also, so what i did was i knocked it on its side, switched it off, by its own panel, then switched it back on, it came back into life and was recognised again!!
so try it with yours!
I think what what happens is, when you accidentally drop it, or knock it from time time(accidentally), the needle inside the hard drive goes out of place, and the hard drive will beep, or something to that effect. knocking the case itself again, might fix the problem, or maybe not, thats if the hard drive itself is more severely/inherentally faulty.
Apr 11, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
How can I copy my computer files on to Iomega eGo portable hard drive 250gb
Connect your drive then just copy and paste or
perform a backup, designating your Iomega drive as the destination.
May 02, 2010 | Iomega (33090) 250 GB Hard Drive
Beeping noise and hard drive doesnt work
RAM problem. Please remove and try fixing it for couple of times. Try changing some other RAM modules.
Jul 29, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Beeping noise when i turn ext hard drive on
The beeping is the hard drive telling you its going bad needs to be replaced.
You can try a data recovery service to get the data back but more than likely its too late sorry to say :(
Jul 10, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Iomega Prestige 1.5TB external hard drive won't start-up properly
Try replacing the power supply. Especially if all you get is a beep and no drive motor noise. The power supply is 12 V, 1.5 A, center positive polarity. Iomega may even replace it for free if the drive is still under warranty. But don't use the phone. Use their free chat-live service. Again, assuming the drive is still under warranty, which is a year, I think.
May 15, 2009 | Iomega 1.5TB Desktop USB Hard Drive
Performing a backup
windows has a back up utility in the programs-accessories-system tools that works ok..
Oct 27, 2008 | Iomega HDD External Desktop (32660) 80 GB...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
