Question about DeLonghi Heating & Cooling
Mold mildew smell
There is mold growing in the front of my ac is there anyway to take it apart and clean it?
SOURCE: ac odor
clean the coils the front and the back with coil cleaner and leave it in the sun until it dry. Do not turn it on whe is weat.
Posted on Aug 05, 2008
  • 351 Answers
SOURCE: My Whirlpool Duet front loading washer has mold
yes they are very good for that... and for the bad news it is almost impossible to get it out.... sorry for the bad news but all of them do it
Posted on May 02, 2009
mpcheeseman1
  • 1400 Answers
SOURCE: my goldstar air conditioner has a lot of mold
Air condition and coil cleaner,can be found at your local hardware store.
I have used simple green full strenght,cleans and kills mold.
Posted on Jan 19, 2010
Testimonial: "thanks "
  • 79 Answers
SOURCE: How to clean mold and mildew build-up on unit fan?
there is a alum coil cleaner works good its a acid be carefull. or try sound good elbow grease. bleach and water.mean green, 409, blade type? or sqiurl cage type it would be best to take it off to clean. i hope this helps you
Posted on Apr 15, 2010
shastalaker7
  • 1515 Answers
SOURCE: I see mold growing inside the cabinet where the
Hi, carefully remove the control knobs first. Then behind the knob you should have screws.to remove, Some units the front just un snaps and comes off, but do be careful as you can crack it. The mold is coming from the coil behind it. You will need to give it a good cleaning. They make a coil cleaner, but you can use 409, of a mildew cleaner. Best of luck,
Shastalaker7
Posted on Jun 14, 2010
The cab in my 2007 GMC Sierra 1500 smells, does it, or does it not have a cabin air filter? I see conflicts all over the web, but major parts stores are willing to sell me one...
The smell is not from the cabin air filter, it is mold and mildew that is growing in the ducting and AC evaporator core, it needs to be treated with special chemicals to kill the mold and mildew, contact your local dealer or an AC repair center near you. Your vehicle shows that it DOES NOT have a cabin air filter.
Oct 11, 2017 | GMC Cars & Trucks
Why am I getting a stale smell from ac
Often times in the summer, mold and mildew will grow in the ducts. You can try some sprays made for car ac systems, or other air fresheners. Make sure the drain is open to let the water out onto the ground. Also try running the ac on "fresh" instead of "max or recirc" much as possible.
Jul 31, 2012 | BMW 530d Cars & Trucks
My car is smelling musty when I burn my ac or heater. What could that be?
This is caused by mold and mildew growing in the moist environment of the AC air ducting and on the Evaporator core, this moisture condenses from the cooling of the air stream. To temporarily cure this problem spray Lysol disinfectant into the Air intake of the system which is in front of the windshield on the passenger side, set the blower speed to high and soak the system with the spray, then let it run a few more seconds and shut it down, this stops the smell for a few months and then it must be repeated.
Aug 03, 2011 | 1998 Pontiac Grand Prix
Hi, i would like to know why when i run the a/c ,the next day i get that steal smeal from the vents. i changed the cabin air filters ,but still the smell remains. please help. AD
This smell is caused by mold and mildew build up in the AC air passages and on the heater and the AC evaporator cores in the dash, u can spray LYSOL mold and mildew remover into the system at the air intake in front of the windshield with the blower turned to max, use about 1/4 can, then turn off the system and let it sit for an hour, then turn it back on with full heat, let that run to dry out the chemical, this will cure the smell short term until the mold and mildew grow back, it is a fix we did often in the shop, the wetter the climate u live in the worse the problem
Oct 27, 2010 | 2004 Hyundai XG350
Awful smell! I drain it every cycle, I use the washer cleaner, everything! I am so sick of my towels smelling awful.
Sounds like the little flexible apron just in front of your washer drum has mildewed. Take a look and see if it is holding water, and look for mold while your'e at it. Use a good bathroom mold and mildew remover to kill the mess and deodorize it.
Mar 24, 2010 | LG WM-2277HW Front Load Washer
What is the issue with mildew and how do I address it? My laundry never smells clean
Any washing machine will grow mold & mildew when there is moisture in it and the door is shut. When you do a load of wash, the smell transfers to the clothing. To eliminate it, run a load just water & chloring bleach. This will kill the spores. Adding a little color safe bleach to each load or leave the door open when not using the washer will keep the problem from coming back.
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Stale odor in machine and on towels and clothes. I have used the affresh, Bleach, baking soda, use powder HE detergent, no liquid fab softner, I am at the end of my rope with this stinking machine ready to...
Towel mildew smell is being transferred from the washer. The washer must be cleaned first. The problem is not "brand specific" all clothes washers have mold growth to a certain degree. Bleach or vinegar will kill the mold inside your washer but won't remove it or the residue it grows on thereby making the situation worse because it leaves a "base" for more detergent to collect on and more mold will grow.
Washing machine mold / mildew odor is caused by:
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet front loading washer has mold and mildew growing even though I clean it out often. It makes the laundry room smell.
May 02, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Mildew on rubber gasket around door.
This happens when you keep the door shut. Run an empty load with extra chlorine bleach to kill the mold spores. Keep the door open to prevent mold or mildew from growing again.
Mar 18, 2009 | LG WM-2277HW Front Load Washer
Heating & Cooling Logo
57 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
