110.45087 need the spider attached under tub
Hello.i need a help,my whirlpool 6sense washing mashine 9769b when spining do horible and loud noice! I try to find bearing but i dont cnow did my washing mashine have one.
Any front-loader machine will have a shaft and two bearings supporting the tub. You may need to remove the back to find it. Also, check to make sure that whatever supports the tub (spider attached to the tub and bearing shaft) is still intact. Some models have reputations for this spider corroding and failing in as little as 2 years.
Apr 12, 2016 | Whirlpool Washing Machines
Will not spin
We need a little more information, Im afraid. If the problem is that it wont spin, what you might need to do is check and make sure that the Spider arm is not cracked and broken- which means disassembling it. That is what happened to us. It's actually attached to the tub itself which is covered under lifetime warranty, so they sent us a whole NEW tub for free, but that means you have to take it apart and install it yourself or find someone else who can. This may or may not be the issue. Is there an error code or does it just beep long and not spin?
Aug 16, 2013 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Interior ring deteriorating
I suspect it's the aluminum spider arm that spins the back of the tub. The moist environment and the ionizing laundry detergent causes a chemical reaction that corrodes this easily and it breaks. It is covered under a lifetime warranty, so call Whirlpool and ask them to send the whole tub unit (the spider arm is attached via machineshop). You will need c-clip pliars to DIY or have a serviceman install it, and be sure to label the clips for when you put them back. This happened to us. The seal is part of the tub unit. Good luck!
Jan 25, 2013 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
LG WM-1832 Awful noise - Spider in broken - How to fix ?
Seems like you need beaucoup parts and with what they charge for parts you just might be better off getting a new machine.
If you go to the attached link you can find out the part numbers and prices of the parts you want - if you ask them your question they will have the answer for you right there. http://www.appliancepartspros.com
Mar 24, 2017 | LG WM-1832C Front Load Washer
I have a GE front load washer ( model wcvh6400j0ww ) the tub is loose i checked the pulley and bearings have no movement . the parts diagram i have dont show the back of the tub, so i cant tell how the...
that sounds like a broken spider that's what holds the drum i think that model is a sealed drum so you cant get to put a new one on if you want to take the lid off and if you can see bolts screws or clips holding the plastic drum together if it has any of them the it can be stripped down to take the drum out but you will find if its just a spider then its going to cost around 50 to 60 pound if its a sealed drum where the spider is pop rivet to the drum then you will need to by a drum complete with spider big job i'm not joking OK if you need more help get back to me OK
Nov 07, 2012 | GE Washing Machines
Bangs and sqeels during high spin cycle, also there are plastic shavings in sink
This could be an easy fix if the counter weight came loose from the top of the tub shell which is a common problem causing banging. Unplug the unit and pull the unit out from the wall disconnection the water hoses after turning of the water. Remove the back panel to inspect the counter weight, spider pulley and belt. If the counter weight is not broken you can reattach it to tub shell and retighten the bolts. If it is broke it is about $30.00 plus shipping. Inspect the spider pulley which is attached to the tub with the belt around it. If it is not broken, you can turn the pulley by hand to check the tub bearings for free movement. Make sure the belt is in good shape and attached to the motor spindle and spider pulley. If the spider pulley is broken you may have to order a new pulley. If you have to remove the spider pulley you may want to use a gear puller from an auto parts store to remove the pulley. If you turn the pulley by hand you should not hear scraping. If you do in could be the bearings or a screw is rubbing against the shell. If you have to replace the outer tub shell (approximately $300.00 for parts only). I would unbolt the bolts holding the shell and find where the tub or screw is rubbing so you do not have to replace the expensive shell.
Feb 23, 2011 | Frigidaire ATF6000ES Front Load Washer
It sounds like the spring in my washer has broken. It made a loud sound during a cycle and now the basket is completely off balance and barely moves. I was wondering if the spring is worth fixing or if...
This could be an easy fix if the counter weight came loose from the top of the tub shell which is a common problem. Pull the unit out from the wall and removed the back panel to inspect the counter weight, spider pulley and belt. If the counter weight is not broke you can reattach it to tub shell and retighten the bolts. If it is broke it is about $30.00 plus shipping. Inspect the spider pulley which is attached to the tub with the belt around it. If it is not broken, you can turn the pulley by hand to check the tub bearings for free movement. Make sure the belt is in good shape and attached to the motor spindle and spider pulley. If the spider pulley is broken you may have to order a new pulley. If you have to remove the spider pulley you may want to use a gear puller from an auto parts store to remove the pulley. The belt is easily replaced once you know the below procedure:
1. Place the belt around the center of the motor pulley stretching the belt to the spider pulley leaving no slack in the belt.
2. Keeping the slack out of the belt, place the belt on the outside rim of the spider pulley as much as the belt tension will allow you to do so.
3. Keep the tension on the belt and slowly rotate the spider pulley counter clockwise until the belt is completely on the spider pulley.
Rotate the spider pulley several times to make sure the belt stays in the center of the spider pulley. If the belt is not centered after several revolutions you need to remove the belt and reinstall it after moving the ribs of the belt on the motor pulley in the direction which centers the belt. If it was my unit I would fix it unless you have to replace the outer tub shell (approximately $300.00 for parts only).
Feb 18, 2011 | Stainless WSXH208AWW GE Extra-Large...
I have a Kenore Elite 110.45992400 and it is thumping when it spins and the drum feels loose when you try to move it around. I've been reading, I gather this is the tub/bearing assembly? What is the spider...
The drum bearing is located at the back of the drum, and it is held by a drum spider.
This is the drum spider:
The drum spider is attached to drum on one side, and on the other it has the drum bearing.
See here a general diagram: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
See also
how to mend it .com - Replacing a Drum Spider
Apr 17, 2009 | Kenmore Washing Machines
Terrible noise on spin cycle, stainless drum is loose inside plastic tub, wore the front half of the plastic tub down due to friction. Took washer completely apart, found the spider arms cracked. It...
Just had the same problem 1 month ago. My Whirlpool Duet front load made that terrible noise. 2 of the 3 spider arms were cracked. I hade a new hole tub with the spider arm and the shaft , because it is 10 years limited waranty . But if it is not under waranty it costs about 270$ for that tub you can buy it from many appliance parts web sites on the net. Good luck, huge job to all remove that thing
Dec 03, 2008 | Washing Machines
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
