Question about JVC AV-48WP30 48" Rear Projection Television
No Sound problem was with the convergence replaced the STK392-110 chips fixed the convergence and now has no sound I checked all the connectors on the chassis did not find any loose ones any one have this problem before ?
    Champion:
  • 317 Answers
Check the solder side of the speaker plug. john
Posted on Sep 12, 2007
SOURCE:
Red light keeps flashing on toshiba theatre. How can I fix it?
on the older sets it is a short and usually in the convergence circuit, the way to know is located the convergence chips and unsolder both from the board (18 pins each) and if set then comes on (WILL LOOK BAD) one of the two chips is bad and both need to be replaced----should be stk-392=110 chips.
May 22, 2012 | Toshiba TP55F80/81 55" Rear Projection...
Power board has been replaced with a new one. Power light comes on and then just blinks. No picture or sound from the TV. This set belonged to my daugther and it just quit working. She got a new one and I...
Hi jblake4900,
First, please double check if the part/board no. (SSR-9010A-M2) is the same as the original one. If yes, then other parts gone bad also aside from the power supply board. This is caused by faulty convergence chips (STK394-250) on the deflection board (part no. SSR-2510A-M2). Your unit used two convergence chips that is mounted on the large aluminum heat sink behind the flyback transformer.
I would advice you to replace both the convergence chip.
You need to prepare the following :
1. Necessary tools and test instrument2. Soldering Iron3. Desoldering pump4. soldering lead5. Thermal paste.6. 2 pcs STK394-250
Soldering Tutorial
How to desolder parts on the board
Let the unit unplug from the outlet at least 1 hour to drain the voltages from the power supply board. Familiarize all connectors (take a picture of it if necessary to guide you replacing the connectors).
Please let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Jdvillanueva
Nov 21, 2011 | JVC AV48P777 Television
I have sound but no picture
I have fixed many rear projection TV's with this problem. It's most likely the convergence chips/board. Which would require either you to replace them (About $75) or call in a repairman to fix it. (It can get real steep, real fast! About $350)
Check this manual to see if you can test your convergence:
http://www.p4c.philips.com/files/4/43pp8545_69/43pp8545_69_dfu_eng.pdf
Aug 10, 2010 | Philips 46PP9302 46" Rear Projection...
My convergence chips need replaced but it seems my sound has gone out too. well replacing those fix this also?
No,After convergence fix,unplug,replug the set for awhile to reset the factory setting.Some setting it wrong,not getting sound.
Dec 12, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Magnavox 55" rear projection tv
It is probably your convergence chip.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site http://www.TvRepairKits.com . They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Hope this helps,
Jul 28, 2008 | Philips Magnavox 55P9271 55" Rear...
MAGNAVOX MODEL#51MP392H/17 NO PIX NO SOUND MAKES CHIRPING SOUND
Thats usually a sign of a bad flyback and or HOT being open due to the Flyback. If you need to know where to get parts with free instructions let me know, But respond to this post so I have your model number.
Jun 23, 2008 | Televison & Video
Convergence problem then no power up after replacement
Check to ne absolutely certain that all the wires are plugged back in correctly, also if the wires are correct check the resistors near the convergence ICs one or two of them are likely open as well.
Mar 11, 2008 | Samsung PCL6215R 62" Rear Projection...
No power after replacing convergence chips
Check the pins on the convergence ICs to make sure the solder isn't bridged between any two pins. You will need a magnifying glass to make certain.
Jan 19, 2008 | JVC AV-56WP74 56" Rear Projection...
Hitachi 43FDX01B
You likely have a fuse bad on one of the supplies to the convergence output IC's.  check EP96 and EP97.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Sep 27, 2007 | Hitachi 43FDX01B TV
JVC AV-48WP30 48" Rear Projection Television Logo
23 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
