Question about Panasonic DP-C322 Copier
Error code e04 48 fuser f9 dp - Panasonic DP-C322 Copier
3 Suggested Answers
  • 18 Answers
SOURCE: error code E04-01
You should be able to open the front cover and close it. This should rest the warm up low temp. code. If not sounds like you have a blown fuse or thermal lamp. Are you able to see the heat (bright orange)lamp turn on at the exit side of the machine. or does the copier feel a little warm at the exit before indicating an error. Hpe this helps. Please leave + feed back
Posted on Nov 27, 2008
  • 990 Answers
SOURCE: Where's the fuser unit on a Panasonic DP 3000
Hello sir;Cleaning the fuser unit not thing to do with the error code E4-01, but there is the way to reset just followinf the steps;
1, press and hold down following 3 keys by order "function", "original size", "3".
2, enter 9, press print,enter 04 press print.
3, press following two keys at same time "function", "'clear".
Posted on May 16, 2009
The lcd display an error code ....E04-01...and i need to get into service mode to clear the message..thanks help please
Did you make a repair or replace the fuser and need to reset the code?; Because if you didn't fix the problem, you'll still get the same low fuser temperature error code.
Press <function>, <original size (ledger)>, <3>
to enter service mode, go to F9-05-04 (RAM Initialize, fuser reset, power off/on)
If the E4-01 error code returns you have a defective thermistor/thermostat.
Nov 22, 2013 | Panasonic WORKiO DP-C262 Printer
ERROR E04-01 SHOWN BY THE MACHINE
reset code fuser error...press at the same time "original size" + 'function" + "3"
F9 mode, 06 (ram initialize) sub code 04 to reset fuser code
Jul 12, 2011 | Panasonic DP-8045 Grayscale Copier
Panasonic 3510 E04-02 error code Can you tell me how to correct this please? Thanks
You most likely have a blown thermal fuse or thermostat in the fuser assy. After replacement, you have to enter diagnostics and perform an lbpr fuser reset. That's in F9-6
Jun 15, 2010 | Panasonic Workio DP-3520 Copier
Panasonic dp 2000 pm error code e04-01 need help
this is fixing error
enter the service mode
f9
enter
Apr 02, 2010 | Panasonic Workio DP-2000P Copier
DP 2500 displaying E04-01
You have a failure in the Fusing Unit:
E4- 01 Fuser warm-up temperature
1. Fuser Thermistor is dirty.
2. Thermistor position is incorrect.
3. Fuser temperature is low.
4. Thermistor is defective.
5. Fuser Lamp connector is disconnected.
6. Fuser Thermostat is defective.
7. Fuser Lamp is defective.
8. HTC PCB connector (CN716) is disconnected
You can try resetting the error by using this key sequence:
enter simulation mode by pressing keys ''Function + Original Size + 3 ''
go to f9 mode ,06 (ram initialize ) sub code 04 to reset fuser error.
If the code comes back you will need a service technician to diagnose which part is bad.
Oct 20, 2009 | Panasonic Office Equipment & Supplies
E04-02
E4-02 is a fuser error, thermistor or thermal fuse blown, it can only be reset in service mode F9 mode
Oct 19, 2009 | Panasonic Workio DP-3520 Copier
E 04-1 Error code What I do Reset?
the best thing that u do first is to clean the fuser unit, esp. the thermostat located there. then you may go to service mode, (function+orig.size+3), F9, look for ram initialize, then look for LBP FUSER RESET.
it will reset all e4 machine error.
Sep 11, 2009 | Panasonic Workio DP-3030 Printer
DP 3530 error code E04-02
Hello sir; You have to look at heating unit you havv paper jam over there!
Aug 23, 2009 | Panasonic Workio DP-3530 Copier
Panasonic dp c-264 error e04-34
Fuser code, reset in service mode F9 -06-04, continues to come back new fuser required
Aug 05, 2009 | Panasonic DP-C264 Copier
Dp-2010e code e04-01
E 4-01 is a fuser error that only can be reset in service mode F9 reset fuser
Jun 26, 2009 | Panasonic Office Equipment & Supplies
Panasonic DP-C322 Copier Logo
47 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
