Question about Bose Lifestyle 40/50 Music Center Used Condition
Lifestyle 50 not responding
The music center does not communicate with the multi-room interface. It keeps flashing "NO RESPONSE". I tried holding the mute button for seconds and it beeps but without establishing the connection. I even tried disconnecting the main power for days and turned it on without success.
  • 34 Answers
Reconnect the Bose link connection at the Multi room interface and at the Acoustimass Module.If this doesn't help,change the remote control batteries.If the it still display "no response",it means either the interface or remote is bad
Posted on Apr 24, 2014
My lifestyle 50 M1 interface is displaying "No response". I have tried all the standard reboot options but apparently I need to replace the capacitors. Can anyone tell me the values of these?
Terry,
I have had the same issue with LS50 for some time and stumble last night on the blog: https://blogteramod.wordpress.com/2015/05/18/lifestyle-50-no-response-quick-repair/
It is written in German though the detail worked perfectly for me this morning.
Bottom line is that they suggest you replace on the P1 unit 4 x caps (C9- 47uF 16V, C10-47uF 16V, C17-10uF 25V, C18-10uF 35V).
I did the work on my unit this morning and all is good - remote now connects immediately to P1 (as it did when new).
Hope that's useful.
Glen
Jan 27, 2016 | Bose LifeStyle 50 System
Bose system (Lifestyle 50)
Did you try leaving it unplugged for a few hours?
Feb 24, 2008 | Bose LifeStyle 50 System
Remote shows no response
I have just had a major problem trying to get the handheld (touch screen) music centre to communicate with the multi room interface. It took over a week to sort out by trial and error, but here is the solution :
1. Disconnect everything from the multi room interface apart from Room A and the CD player (blue connector).
2. Turn off the electricity supply at the wall (turning off any in line extension lead is not good enough - it needs to be at the wall socket). Leave turned off for at least 2/3 hours.
3. Turn back on and then leave it again for 2/3 hours.
4. Touch the music centre and you should find that it has now registered with the interface unit.
5. Connect the other rooms and input sources with the power switched on (contrary to instruction manual which advises you connect everything before powering up).
6. Test each input systematically as you connect them.
Hope this helps. I was on the verge of buying another multi room interface (I have 2 music centres and neither worked so assumed in was the interface at fault), at a cost of £200, so now glad I persevered with resetting the system !
Mar 03, 2014 | Bose LifeStyle 50 System
Bose lifestyle 50 "no response"
You can find a bose M1 on amazon already refurbished
Apr 13, 2013 | Bose LifeStyle 50 System
CALLER ID
Negative, the SX 50 does not support CID. You can upgrade the Mitel or use a CID Multi line interface to a PC. Here is one such model.
http://www.callerid.com/
If you go to the bottom of the page on the right, click on how it works. Hope this hlpes.
Jan 15, 2009 | Uniden 5.8GHz Cordless Phone
UK Systems - Scrolling Message Please Wait - Starting Up
Hi, I have a LifeStyle DVD Home Entertainment ctr model # AV 48 Media. The speaker connections in the living room around the center are connected, and working ok. The problem is with the remote connection to other speakers in other rooms. I am using 240 voltage. Please advise how the connections should be.
Hoping to have your response soon,
John Luggya. jluggya55@yahoo.com
Thanks
Oct 20, 2008 | Bose Lifestyle 48 System
Lifestyle 50 "No Response"
The remote problem is same with me and need to repair.
I gots information from Bose Service Center, PCB transmitter and receiver not working well.
maybe this information helpful for you.
tq.
Aug 18, 2008 | Bose 023795 LCD Touchscreen Remote Control
Lifestyle 12 by Bose
No sound ? Make sure the audio input cable is connected to the music center FIXED outputs, the black connector is fully seated in the music center SYSTEM CONTROL 1 jack, and the multi-pin connector is firmly seated in the Acoustimass module jack. ? Turn the music center off for ten seconds, then on again, to reestablish communication between the music center and the speakers. ? Check the connections for any external components. Make sure to select the correct source for the desired input. ? Check the speaker connections. ? Be sure the CD is placed correctly, label-side up, in the music center, and the cover is closed. ? Increase the volume. ? Check to see if MUTE is lit in the display. Press the MUTE button on the remote to unmute the sound. ? Disconnect any headphones. ? Connect the FM and AM antennas , and last but not least. Make sure there is power going to the remote speakers or the unit will not communicate with them. Good Luck
Jun 14, 2006 | Bose Lifestyle 12 System
Bose Lifestyle 40/50 Music Center Used Condition Logo
320 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
