Bauknecht wa 7775
Have a error code F06
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
  • 1525 Answers
SOURCE: error code f06
hello fo6 means drive motor techometer error check wire harness connections between the drive good luck
shaun
Posted on Mar 22, 2009
jsrock516
  • 5911 Answers
SOURCE: Error code f06 model 11045089404
"F6" is a Motor Speed error problem. It is commonly attributed to either a broken or slipped drive belt, defective Drive Motor, bad Motor Control Unit (MCU), and/or the interconnecting wiring. The following link explains:
http://www.fixya.com/support/r3608706-f06_error_code
First, remove the back panel of the unit and make sure the drive belt is not broken, or has not slipped off the drum pulley.
Then, remove the top panel of the washer and check all the connector plugs between the Drive Motor, MCU and Central Control Unit (CCU). Check for loose connections and then unplug each connector and plug them back in (one at a time) to ensure they are snug and making good contact. The top panel comes off by removing the three screws that hold it in place in the rear of the washer. With the screws removed, the panel will slide back, then off.
NOTE: You only need to check the connectors that affect the drive motor and MCU circuitry.
The MCU has a tachometer mounted on it. If it is determined to be the cause of the problem, it is considered part of the MCU and cannot be replaced separately. The MCU is not serviceable and will require replacement.
Next, check the motor windings to ensure they are reading the proper resistance. Followed by continuity checks of all the interconnecting wiring between the drive motor, MCU and CCU. You should not need a service manual because each one of these washers comes with a technical data sheet.
For more in depth troubleshooting tips refer to your tech sheet located inside the washer behind the lower toe panel. You will need to locate and remove the screws under the bottom front edge of the toe panel. Once removed, the panel will drop down, then come off. If the tech sheet isn't located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all error codes, test points, diagnostic procedures and helpful illustrations to assist in troubleshooting and repair of your washer.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, or require additional assistance, please let me know. I hope you find this information helpful.
Posted on May 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: English manual
www.diplodocs.com
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
ginko
  • 19396 Answers
SOURCE: Parts list for Bauknecht WA
Hi.
All parts for Bauknecht WA3108 are listed and available on this seller website.
Regards.
Ginko.
Posted on Nov 17, 2010
Xerox Error Codes 7775
did you RTM?
only 1 quarter mil hits on goggle, is that hard?
https://www.google.com/search?site=webhp&q=+Workcentre+7775+errors&oq=+Workcentre+7775+errors&gs_l=serp.3...145016.150679.0.150919.10.9.1.0.0.0.162.1020.0j9.9.0.cshsj%2Cj%3Dtop%2Cjnum%3D2%2Cjlen%3D3%2Cjprob%3D-14...0...1c.1.25.serp-shj..2.8.756.3xT1x4bfjRg
Sep 26, 2013 | Xerox Made In Japan - 4 Toner Refill ...
Flashes error code F06
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its a faulty CCU that needs to be replaced. Here is the part.
Oct 19, 2012 | Sears Kenmore Elite 4.2 cu. ft. Front-Load...
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
BAUKNECHT WA 709 SC
my BAUKNECHT WA 709 709 SC washing machine doesn't work what should I do? no one could fix it
Aug 27, 2012 | Washing Machines
Error code F13 Bauknecht washer front loading
error codes washer machine bauknecht f13
Nov 15, 2011 | Washing Machines
Don't understand the pictograms describing the washing cycles...
Type the model and name into a search engine..Some Bauknecht machines are also sold as Whirlpools...Check the website for them as well....Good luck...Nomess
Apr 18, 2010 | Washing Machines
English manual
www.diplodocs.com
Feb 28, 2009 | Washing Machines
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
