Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Zts 7500 cranks but wont start,dont have a spark,have a new plug
    Novelist:
  • 212 Answers
Sounds like your coil is bad. Fortunately they are fairly cheap and fairly easy to install. I would replace the coil.
Posted on Oct 22, 2013
SOURCE: My zts 7500 turns over
This is usually caused by the wire coming off of the coil (smaller one not connected to the spark plug) getting shorted to ground. This wire goes to the ignition switch and when the switch is off, the wire gets grounded. If it gets grounded while running, the coil will not spark. Make sure the wire is not rubbing against any sharp metal edges and disconnect from the ignition switch. If you still don't get spark, then good chance that the coil itself is bad. Before you replace the coil, try another spark plug first, just in case.
Posted on Dec 22, 2010
  • 202 Answers
SOURCE: I have a 7500 zts 50
I would suggest taking an old blade to a home hardware store or a Sears store to match up.
Posted on Oct 25, 2009
  • 394 Answers
SOURCE: My craftsman zts 7500 will not start.
The problem may be one of the safety switches. Make sure the blades are not engaged. The clutch pedal needs to be pushed all the way down, and there is another one that needs weight on the seat. Look around those areas for disconnected wires. Some even need to be in neutral. Lots of safety features.
Posted on Mar 27, 2010
  • 8 Answers
The first thing to check is the fuse,it should be located underneath the battery.
Posted on May 18, 2010
H2_Brad
  • 425 Answers
SOURCE: have a craftsman zts 7500 it misfires and skips
I would thoroughly disassemble and clean the carb before replacing any more parts.
Posted on May 18, 2012
How o you change the lift assembly on a craftsman ZTS 7500 mower ?
Should be relatively simple. There are 4-5 cotter pins that connect the mowing deck to the bottom of the mower. Pull the pins, push the metal rods out, and remove the deck!
Jun 17, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Gp 800 will crank but wont start
Hi, most likely the trigger coils near the flywheel, it will still have spark but the timing may be off. Try new plugs first as they may have spark outside the cylinders but not when under compression. Regards Phil
Jul 01, 2012 | Yamaha Boating
Have a craftsman zts 7500 it misfires and skips
May 18, 2012 | Craftsman Garden
My zts 7500 turns over but has no spark.
Dec 14, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
95 honda civic ex wont start cranks over but wont start
DID YOU HAVE SPARK IN THE SPARK PLUG WIRES WHAT YOU CAN DO IS TAKE OFF ONE OF THE WIRES FROM THE SPARK PLUG AND PUT A FLAT SCREW DRIVER INSIDE THE WIRE AND PUT IT CLOSE TO THE METAL SO THE WIRE GETS GROUND AND HAVE SOME ONE TO CRANK THE ENGINE AND YOU GOING TO SEE THE SPARK IF YOU DONT SEE SPARK SO THAT IS YOU POBLEM
Jul 26, 2009 | 1995 Honda Civic
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Craftsman zts 7500 will not run with levers engaged
Cody,
Yes, I am sitting when I do engage the blades on my craftsman zts 7500. All you do is pull/push the engaged button to your left well you are seated.
Apr 05, 2009 | Craftsman Garden
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
56 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
