Question about Dehumidifiers
Fedders sfpmb07f2a Need owners mannuel
How do you hook up a drain hose to a Fedders dehumidifier?
Personally I would contact fedders and ask them ( their experts) that is
Oct 14, 2015 | Fedders Dehumidifiers
I need to replace the power board crcfd2514-040 but cannot find a source. Do you know where I can order one?
Unfortunately, Bill, your model was manufactured by the original Fedders Company, which is no longer in business. Major parts for any of their products are almost nonexistent, which is the case for the power board you're looking for. In addition, according to my supplier, there is no substitution available for that part. This not only affects Fedders dehumidifiers, it also affects many Maytag dehumidifiers that were =made for Maytag, by Fedders.
I'm sorry, I wish I had news for you. Thanks for choosing FixYa.
Jul 26, 2011 | Fedders A7DH45B2A Dehumidifier
I have a Fedders dehumidifier Model A7DH45B2A REV-A. The nipple on the float broke off. Where can I buy a float? Do you have one? How much is it?
Although Fedders, as you knew it is no longer in business, some parts are still available.
Here is a link, with an explodes view of your model's parts.Locate th epart you need and then enter the part number, to see if it's still available. FYI Maytag Dehumidifier parts are interchangeable with Fedders. Fedders made the units for Maytag.
http://www.appliancefactoryparts.com/dehumidifiers/fedders/a7dh45b2a.html
I hope this helps you find what you need.
Jun 19, 2011 | Fedders A7DH45B2A Dehumidifier
Coil is freezing up.rusted coil sensor bracket. i need a new freeze switch sensor for the front coil. i guess it turns the compressor on and off so the coil doesn't freeze solid. can't find the...
Buck, as you seem to be aware, Fedders no longer exist as the Fedders you may have been familiar with 8 years ago. Finding manuals and parts, is like looking for a needle in a hay stack. However, the new company Airwell-Fedders may be able to help you. There Customer Support Dept 866-829-2440, is who you need to contact.
There is one other possible source, as some parts are interchangeable. Appliance Factory Parts
http://www.appliancefactoryparts.com/airconditioners/fedders/ does carry some of the older Fedders Parts, as well as Maytag. So, that may be worth a try.
Hope this helps you find the parts you need. Good luck and please let me know how it worked out for you. Thanks.
Jun 11, 2011 | Fedders A7DH45B2A Dehumidifier
Fan blew apart.....need a new one.
You can purchase them directly online from Fedders or from Sears Parts Central. Fedders makes dehumidifiers for Sears under the name Kenmore.
Apr 25, 2011 | Fedders A7DH45B2A Dehumidifier
Where do you find replacement parts when they are discontinued? I need a regulator for my dehumidifer a7dh45b2.
Fedders also made identical dehumidifiers for Maytag. Their model numbers are almost identical, and their parts are the same. So, try finding the parts you need thru Maytag.
Mar 26, 2011 | Fedders A7DH45B2A Dehumidifier
After the first year of owning this product it trips the breaker every time I turn it on. I have tried plugging it in to a different circuit and does the samething to that breaker also. What should I...
From what you described there is an electrical short or overloading problem within the dehumidifier.You should also check the cord and the plug from the unit, to be sure it's not worn or cracked. Look at the prongs of the plug. Are they damaged or bent?
To really attempt in-depth troubleshooting, you will need your Owners Manual , which hopefully would show a wiring schematic and a multi-meter circuit tester. I can tell you this, your humidifier was not manufactured by Maytag, It was manufactured by Fedders for Maytag.
The easiest thing you can do yourself, is check the the above, as well as filter (Does it need cleaning?) Remove the bucket and inspect the trigger mechanism for wear or damage. And if all else fails, contact Bob McIvor, Service Technician, 609-662-5323 for the Fedders Company. If you have your Proof of Purchase, there may be some warranty coverage left for parts, if needed.
Mar 19, 2011 | Maytag M7DH65B2A Dehumidifier
Dehumidifiers Logo
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
