Question about Summit Appliances 2.9 cu.ft. Medical Two-Door Refrigerator/Freezer w/ Combination Lock &
AEG S 75348 KG9
LEAKING
My 72640 AEG washing machine continually leaks even though the filter cap is tightly in place. What could be the problem please? Kate Comins
you have a hole in the rubber boot seal and need to change it,also i've seen a buildup of detergent and hair stuck on the bottom side of the front door,when the door is closed the water was traveling down the pieces of hair and leaking through the bottom of the door,but if it's leaking under where the pump is and it's not the pump or hoses it's the boot seal.open the door and pull open the boot seal and run your fingers all around until you find the hole
Jan 23, 2011 | AEG Lavamat 72640 Front Load Washer
Aeg sensorlogic 50700 first showed c2 message; we drained & cleaned filters 3 times; worked half cycle and now showing error message c3?
Error message C3 is most likely indicating the flood switch is triggered. This means water is leaking from under the sump. The C2 error is linked to drain problems which you cleared.
Dec 29, 2010 | AEG Dishwashers
How can i solve the error C6 in a AEG Lavamat
c6 is indicating a fault in the water level sensing . either pressure switch defect. leaking pressure tubes or blockage in pressure chamber that the tubes connect to,
May 03, 2010 | AEG Lavamat 88840 Front Load Washer
AEG 6200 Washing machine punping water out of the
Please have the mechanical seal at the bottom
replaced. It is already leaking.
Sep 23, 2009 | Washing Machines
Can I use hot water supply only on my AEG Lavamat W 1159?
A valid point but unfortunately your machine is programmed to take both and will register this as a fault.
This is probably not what you wanted to hear but please dont shoot the messenger.
Jan 22, 2009 | AEG Lavamat W1450 Front Load Washer
Drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Aeg washing machine
you may have blockage in pipe from drawer to tub but more likely the soap drawer is clogged. take it right out and clean thoroughly
Mar 21, 2007 | AEG Lavamat W1050 Front Load Washer
Washing Machines slowly fills with water over a few days
could be leaking inlet valve or if drain is plkumbed in unbder sink, could be filling thro drain pipe when you emptyt sink
Mar 17, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Summit Appliances 2.9 cu.ft. Medical Two-Door Refrigerator/Freezer w/ Combination Lock & Logo
Top Summit Appliances Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Summit Appliances Science and Laboratory Expert? Answer questions, earn points and help others
