Question about Radio Communications
I need to find an antenna and/or bnc connector
I bought a universal ducky antenna but it doesn't connect right. Do I just need a bnc connector, and where do I find the correct type?
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
Radio shack
Posted on Oct 28, 2013
2 Suggested Answers
pincer
  • 377 Answers
SOURCE: antenna alternatives
1702026301208080_1.jpgCar Floor Mount Kit for Cobra Uniden Radio Shack Ge Cb $19.95
Posted on Mar 23, 2008
Antenna GPS Tram 1655 is compatible with GPS FURUNO?
If the Furuno unit you're referring to uses a GPS antenna with a coax (i.e. GP31/32) then the Tram antenna will work but the connector is wrong. The Tram antennas usually come with BNC connector and Furuno uses a TNC. Will need an adapter.
Oct 14, 2013 | Furuno GPA019S GPSDGPS HField Antenna...
I want to connect a 6 pin s video to a bnc monitor and cant find a connector
SORRY YOU CANT DIRECTLY CONNECT A S-VID CONNECTOR TO A COMPOSITE BNC VIDEO INPUT , THEY DO MAKE CONVERTERS FOR THIS (GOOGLE IT) BUT IT'S BEEN MY EXPERIENCE THAT COST OF NEW/CORRECT MONITOR IS LOWER/SMALLER THAN THESE DEVICES
Jan 31, 2013 | Lorex Home Sentinel Wide Angle Security...
Need antenna
This radio has a standard BNC antenna jack. Radio Shack does now offer an antenna with a BNC connector on the end that you can use with this radio.
Dec 03, 2012 | Uniden Bearcat 855 Xlt 50 Channel Scanning...
I have tried to adjust my squelch but all i hear is loud static in between transmissions
  • Hi, I can help.
  • If your getting transmissions then the receive is working.If your squelch is not adjusting out then it is possible your antenna, or the connector, is not working right. Hand held scanner antennas are the same across the board as for frequency use. The connector your antenna uses is a standard BNC connector. So your antenna is really universal which mean you don't have to go to Uniden and pay top dollar for their antenna.
  • Now it is possible the squelch knob is giving you trouble. but I would see if you can borrow an antenna just to try from anyone you know that has a hand held scanner. As long as their scanner works well with that antenna it should on yours too. If it don't then check the connector for the antenna on the scanner and make sure it is not loose. You can open the scanner and just eyeball the connections and make sure no soldier joints are not cold.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 17, 2011 | Uniden BC72XLT Handheld Scanner
Need an replacement antenna for my radio shack pro-508 scanner. Radio shack does not carry them anymore
Hi.
Check on eBay. You need a standard BNC connector antenna for this scanner. Radio Shack scanners are made by Uniden so a Uniden BNC antenna will fit your unit.
Here's a link for an antenna on eBay:
http://cgi.ebay.com/UNIDEN-DESKTOP-SCANNER-ANTENNA-BNC-SCAN-3-/220734104369?pt=LH_DefaultDomain_0&hash=item3364c72331
Feb 08, 2011 | Radio Shack Pro-2018 Scanner
I am look for a Antenna for a cobra model no is HH35
Any "Rubber ducky" antenna for a CB radio will work. It has to be one that is designed and tuned for the 27 mhz CB band.
Here is one.
You can also just google the phrase "cb bnc rubber ducky" and it will bring up lots of options.
Oct 18, 2010 | Cobra HH 38 WX 40-Channels Handheld CB...
Standard Horizon HX 471. Antenna is to long to fit in Dive Canister. Can I removed antenna or replace with more flexable antenna?
Yes, as long as it is the right length and impedance, you can use a piece of wire! ... If you can get a smaller "antenna" and it fits, it will work fine. You could try disassembling the "Old" antenna, inside, you will find that a it can then be bent or such, use heat shrink to seal it, when modified.
Feb 26, 2010 | Standard Horizon HX471S (824 Channels)...
I want to use an external antenna. Is the antenna
There is a kit available which contains the antenna, mag mount, coax, and connector. OR if you already have your antenna, mag mount and coax, the connector alone is available. You should be able to get these from your local Motorola dealer.
best regards.
Dec 04, 2009 | Motorola Talkabout Distance DPS (10...
Can't find satellites
The internal antenna BNC connection (the little steel bayonet that the secures the antenna or extender cable) is a common failure on these units. The threaded retaining ring on the outside of the antenna BNC comes loose when installing/removing the antenna connection, and eventually the BNC rotates and the solder joint inside fails. This happened on mine recently, if you are handy fixing small mechanical parts and a good solderer it is pretty  easy to fix. Remove the batteries, remove all six outer case screws (but not the one with the oval metal plate) and gently pull the housing apart. Check the solder connection of the coax wire to the BNC pin & shield. If it's broken and the BNC is loose in the GPS case, tighten the outer BNC retaining ring VERY tight, add a drop of thin super glue (Hot Stuff or Permabond CyA, etc) to keep the ring/BNC/case mated, then repair the coax solder  connection. Replace all the screws and test it outside. If it's an aviation GPS you would of course have this done by an FAA licensed avionics specialist. Wink wink.
Jun 14, 2009 | Garmin GPS III
My scanner
You may have lost your antenna connection.. Is the connection point loose (rotates a little) if you remove the antenna?
If yes, they you need to open it up and repair the connection, and re-tighten the BNC connector..
Jun 21, 2008 | Uniden BC60XLT Handheld Scanner
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
