Question about Baxter Ovens
Backfire The oven is not lighting. we have the proper ignition sequence but the burner is not lighting I hear the click of the gas.and ignition sparkle, try to go on but cough on and off the model # is ov210G-M2B from 1999
  • carlos fraga Jul 28, 2013
    I replace the ignitor and nothing same problem
    i replace the ignitor and have same problem
  • 43 Answers
Possible bad ignter .The glow or spark may not be hot enough for the electronics to to realize it's trying to lite.problem related to ignition and or ignition control module.ask your parts dealer about these parts.
Posted on Oct 20, 2013
2 Suggested Answers
  • 245 Answers
SOURCE: oven not lighting
replace the ignitor. these will get a hairline crack in them and will not show proper resistance to allow the valve to turn on and let gas start flowing.
Posted on Jun 24, 2009
Oven ignitor intermittent spark, oven wont light, emits gas.
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Mar 13, 2015 | Ovens
KENMORE GAS STOVE OVEN , how to check if power is coming to the ignitor
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Sep 07, 2014 | Kenmore 24 in. Gas Self-Clean Single Wall...
I have a 5 burner gas range and cooktop one burner on cooktop won't start
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Apr 12, 2014 | Kenmore Elite Stainless Steel 40" Dual...
NATURAL GAS OVEN WONT COOK PROPERLY
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
ELECTRIC OVENS:
Apr 06, 2014 | Frigidaire Ovens
Frigidare gas oven wont ignite
ELECTRIC OVENS:
Feb 07, 2014 | Frigidaire Ovens
Stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven not lighting
Jun 24, 2009 | Ovens
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
Ovens Logo
73 people viewed this question
Top Baxter Ovens Experts
Owen Barnes
joneable
Level 1 Expert
Jerry Kramer
Jerry Kramer
Are you a Baxter Oven Expert? Answer questions, earn points and help others
