Mp3 not working at all
Mp3 not detected by windows, not charging, not able to switch on
    New Friend:
    Problem Solver:
  • 13 Answers
Take it back in and get it fixed
Posted on Jul 28, 2013
This divise canot connect to pc it is only in charging mode
at my experience the mp3 player if connect to computer will at charging mode and at windows explorer will detect as removable disk like pen drive
at this state you can copy/paste file from computer to mp3 player or from mp3 player to computer
if your computer did not detect mp3 player as removable disk it mean your need to install mp3 player driver to your computer first
Mar 17, 2011 | Samsung YP-K3 MP3 Player
My pc cant detect my samsung mp3 player, but it is charging.
MP3 player is still charging because the battery and other components are still working fine.
The memory storage could have gone bad. You may try to connect the player into different computer to see if you'll get the same problem. If you do get the same problem, you need to check the Disk Management to see if the player will be detected or not. Here's how:
1. Connect the player to the computer.
2. Right click "My Computer" and select "Manage".
3. Click on Disk Management and a window will appear.
4. Write down the drive letters that you will see in that window.
5. Without closing the Disk Management window, unplug the player from the computer.
If there's a drive letter disappears, then that is your player. But if nothing disappears, then the computer is no longer detecting your player.
You need to contact the manufacturer and have them replace the memory storage inside the player, and reload the program.
Thank you and good luck!
Jun 15, 2010 | Samsung YP-U3 MP3 Player
My PC (windows XP) doesn't detect Sansa e250 MP3 player
Turn the player off before you plug it in and if it doesn't find it then turn it on while plug in.
Jul 30, 2009 | SanDisk Sansa e250 MP3 Player
Usb is not detected
Try to charge with power switch to ON position
Jul 11, 2009 | Transcend T SONIC 630 MP3 Player
Cannot detect quantum mp3 player QHM-5021
before connecting mp3 player switch it on then connect it to pc/laptop............but i have a problem that my ipod is charging but it does not working......
Mar 29, 2009 | Audio Players & Recorders
PC not detecting mp3player and also not able chage
First, make sure the hold switch is not engaged. Then:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Dec 04, 2008 | Philips GoGear SA3125/37 MP3 Player
Hello dear
If u can open your mp4 player then open it. and after change the crystal
detecting problem will be slove.
thanks
Sep 08, 2008 | Philips SA5125/37 MP3 Player
Trouble getting the player to take a charge
Make sure that hold switch hasn't been flipped again. Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 07, 2008 | GPX MW3837 MP3 Player
Not detected by computer - cannot recharge battery
yay I found a solution! so I kept getting the error about an MTP device, so I did a big search. I am running vista on a 32 bit processor. what you need to download is the MTP installation programme from windows. so click on http://support.microsoft.com/kb/939211
and then just select what processor speed you need. should do the trick! I also downloaded http://www.microsoft.com/downloads/details.aspx?FamilyId=A2E73160-E862-4F19-BB26-C0CAFE798955&displaylang=en initially, but it didn't appear to work. hope that you all get to the bottom of this frustrating problem :)
Dec 18, 2007 | Samsung YP-U3 MP3 Player
12 people viewed this question
 Grubhead
Grubhead
