Question about Epson Stylus CX5400 All-In-One InkJet Printer
Printer error says to release transportation lock before turning on but can't find this lock
  • Epson Master
  • 419 Answers
Lift the scanner lid and you'll find it on the left side.
Ref: http://www.manualowl.com/m/Epson/CX5400/Manual/75434?page=2
Posted on Jul 31, 2013
Mon imprimente pixma mp810 donne un code erreur 5020 et demande de deverouiller le scaner
This correction is listed on the Canon website. Lock Switch Make sure to unlock the scanning unit before turning the machine on.
  1. Lift the document cover open.
  2. Slide the scanner lock switch to the release mark.
    Caution : Make sure to unlock the Scanning Unit (Printer Cover) before turning the machine on.Before transporting the machine, always lock the Scanning Unit (Printer Cover) by moving the Scanner Lock Switch towards the lock mark.
  3. Close the document cover.
  4. Press to turn off the machine.
  5. Wait approximately 5 seconds then press to power back on the printer.
Mar 27, 2011 | Canon PIXMA MP810 All-In-One InkJet...
I am having a problem with my printer. When I turn it on the copy light is on and the feed switch light and the alarm light and it says in the screen release the scanner lock switch and turn the power off...
Issue: ERROR LCD: Release the scanner lock switch and turn the power off and back on.
Solution: Unlock the scanner lock switch
The scanner must be unlocked before turning the unit on.
Turn off the power.
Lift the document cover.
The scanner lock switch is on the left hand side of the underside of the document cover.
Slide the scanner lock switch to the release mark (an open padlock icon).
Lock the switch before transporting.
Turn the machine on.
If machine still is not working repeat the power off / on cycle waiting 5 seconds in between.
Jan 25, 2011 | Canon MP830 All-In-One Printer
Scanner error occurred please see documentation
turn the printer off, lift the scanner, make sure the transportation lock is in the unlock position, if it is in the lock position, toggle it to the unlock
Feb 11, 2010 | Epson Stylus Photo RX620 All-In-One InkJet...
My cx3200's control panel reads scanner error. I unlocked the transportation lock, turned off, turned on. It stayed off for about 2 minutes then came right back on. While the error light was off tried to...
The only things that can cause a scanner error on this unit is a complete scanner harware failure or the scanner lock. With the unit on lock the transport lock and unlock it a few times quite forcibly. Then leave it in the unlocked position and power off and on again. If the light returns then at his point I think a new printer will be needed.
Jan 18, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Printer ar168D Error L1-00
The L1-00\r\n error indicates the scanner didn't return to it's home position or is locked and can't leave the home position. There is a lock switch (designed to lock scanner into place for safe transport) located to the left of the copier and just under the scanner. It's a plastic dial that needs to be turned to the "unlock" position. Once done, your problem should be fixed.
Nov 12, 2009 | Sharp AR-168D Copier
Once the np 6050 is turned on it displays error code E010 switch off and on again
E010 code is main motor lock. Open front cover, Release Transport/Fixing Unit tray. Pull the tray out untill it stops. Try rotating the larger knob to see if Fixing unit will turn...if not, raise the exit/stripper assembly to check for jammed paper. If no paper present and the Unit turns freely, reinsert Transport/Fixing tray into copier. Latch into place. Close front cover. Power on machine.
It is possible that the main motor has failed, but not likely.
Jun 19, 2009 | Canon NP 6050 Copier
Epson Rx620
The user's manual said: "Turn this product off, and then back on. Then make sure the transportation lock is released. If the error message still appears, contact your dealer."
If you open the lid, there is a transporation lock on the lower left. Make sure you unlock it before you turn on the machine.
Hope this helps.
Jun 17, 2008 | Epson RX620 All-In-One InkJet Photo...
Installation
An error occurred when you set the transportation lock to the lock.gif locked position. To clear the error message on the LCD panel, set the transportation lock to the unlock.gif unlocked position, and then turn on the product again or press the fontx1.gif B&W Start or fontx1.gif Color Start button to restart the scanning job.
You can find the transportation lock on the left hand side of scanner when you lift/tilt ADF up. Hope this helps...
Apr 05, 2008 | Epson ACULASER CX11NF All-In-One Printer
The red light is on and the message scanner error. tried turning it off and then on again after a few seconds the red light comes on again. Also check to see if the system was locked released that. Tried...
Try flicking the transportation lock (on the left side under the scan lid) on and off. It has a picture of a pad lock shown locked and unlocked. Flip it back and forth and leave it in the unlocked position.
This worked for me. Good luck!
Oct 15, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Scanner error
Oct 07, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX5400 All-In-One InkJet Printer Logo
168 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
