SOURCE: screen shows ERR. I changed batteries and tried
You're right..This happens often when one changes the battery.Here's what to do :
The ERR message can only be corrected by holding in the DISP/MENU and STOP buttons for two seconds, which results in ALL the material on the recorder being erased. It will say (FOR) for a few minutes while it is erasing everything, then will work again.
Solution found at http://www.amazon.co.uk/Olympus-VN-2100-Digital-Recorder-microphone/dp/B000V3NTEU
SOURCE: My printer shows Never ERR: 0x960F What does that
Hi there
I cant see much about this error you have the only thing I see about it is it could be the software driver or your windows need updating just try re installing your driver you may need to unsiall the driver first. All the best
SOURCE: 2005 pt cruiser cd player rejects cd and shows err
Either it's a bad CD (format, or scratches), or you have a faulty CD Player. If the CD player is bad, it is likely much cheaper to just buy a new one, than to fix the factory one.
