Question about De Dietrich Ovens
De deitrich double oven.
My De Dietrich double Oven has developed a fault in the Main Oven. The Clock indicator led's are dead and the oven will not switch on. There is a power indicator to the upper right of the Oven thermost position switch which comes on when switched, but the thermostat and timer do not show any sign of life. I have slipped out the oven to look under the top lid and can see a White plastic cover under which is a pcb board and on it are relays etc. This feeds the digital clock which is also dead. The unit started to give problems back in May but has now stopped responding altogether. This Oven is 16 years old, but i am loathe to dump it for the sake of a relay or something silly. Model NO. FX4827E33. Not sure if the "8" is not a "3".
  • De Dietrich Master
  • 5,323 Answers
1.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Posted on May 04, 2015
SOURCE: De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
Posted on Sep 26, 2008
jumptrout51
  • 3361 Answers
SOURCE: Oven blows main switch
There is a short circuit between the lower oven control and the lower element.
Disconnect the lower element. Put electrical tape on the loose terminals and turn the lower oven on.
If it does not blow, replace the lower element with a new element.
If it does blow, Check the wiring to the lower element for continuity to the frame of the range.
If you get continuity replace the damaged wire..
Finally, check the control knob switch for continuity to ground on the frame of the oven.
Posted on Mar 20, 2009
SOURCE: De Dietrich electric oven has power but no heat
hi it is probably the timer not making the switch properly even though it looks like its on stopping power going to the thermostat
Posted on Dec 11, 2009
  • 189 Answers
SOURCE: Upper oven elements don't heat
Hello- 'Successfully' sounds like you were forewarned....  During the 'self-clean' cycle a circuit or connection to the upper elements burned out while attempting to turn stuff inside the oven to ash. Since this is a wall oven my recommendation is for service from a good tech in your area. You may have lucked out with a fried connector, but many times control board is damaged beyond repair and must be replaced. Only on-site diagnostics will confirm, and this is a very heavy unit for most owners to safely service.  - Remember- Don't use 'self clean'!! Scrape and clean with soapy water and cloth. Turn on oven to 450deg. for 30 min. Much safer. Less costly.       Please acknowledge this post if the info is helpful- Have more if needed.  Thanks-  Ed
Posted on Mar 23, 2010
The part that needs replacing is the clock timer.
FIRST: ISOLATE THE CIRCUIT.
The front fascia is held on by three clips. Take off the two knobs and gently pry away the fascia fron the left, right and top centre.
The clock timer is held in by four plastic push clips at the top and bottom about 1cm in from the end. Push them in and pull the timer out.
There are now three wires on push clips attached at the back.
Do not take the colours for granted. On my oven just repaired the Live was Black and the Neutral was Red! The black marked 'C' is the input. The side by the trip switch is the output. The Red goes on the other side.
When the timer trips it causes the circuit between the input and output to break.
You have two options now:
Read the serial number of the timer and try and order it (expensive), swap the cables over.
Carefully run an electrical cable between the push clips on both black cables making sure you leave no exposed wire. Your timer and clock however will never work, the oven just does not care about it anymore.
Note: I am not an oven engineer, I am an electrical engineer in another field and have tested voltages and current and believe this to be safe. I have done this on my own oven.
Posted on Sep 16, 2011
I have a de Dietrich double electric oven with pyrolysis. I did a clean and now the bottom oven won't heat and fan not working. Top oven is fine, thank goodness
Many times when the self clean function is used they seem to melt connections internally . call your local repair company and have it checked out
Sep 24, 2016 | De Dietrich Ovens
Unlock control panel
Function switch must be in the "O" position
Press the " /\ " button for a few seconds until it beeps.
Then use the +/- buttons to set time.
Try powering off and switching back on again if that doesn't work.
May vary between models but De Deitrich do free manuals downloads. Just google it
Nov 10, 2014 | De Dietrich Ovens
De dietrich oven clock tripping out
I already explained, you need to replace the big 1.5uF Capacitor that
is reponsible for the voltage drop from 220V to about 10V. You need to
remove the timer controler module from the oven, in the meanwhile you
can shunt the 2 wires that usually are shunt by the relay, and then
buy a new capacitor and replace it with a soldering iron.
Good luck.
Apr 11, 2013 | De Dietrich DOC310 Electric Single Oven
Fan oven not heating up have change the power board
Hi, the main problem with this fault since you have changed the power board is that the fan element has blown. This usually cannot be seen without taking the fan cover off inside the oven.
Take care
Jul 01, 2010 | De Dietrich Ovens
Why does my De Dietrich oven trip the RCD fuse?
You need to replace the oven element, as this is what is causing the prob.
Please rate my solution.
Thanks.
Nov 06, 2009 | De Dietrich DOC310 Electric Single Oven
The oven won't come on, the digital timer just flashes continuous
Hi
have you tried setting the clock as the oven wont work if the clock is not set. hope this helps
regards dan
Mar 19, 2009 | De Dietrich UMP404 Powerclean Stainless...
good luck Andy B
May 13, 2008 | De Dietrich DOC310 Electric Single Oven
De Dietrich oven not working!
I suspect that it is the oven lock that needs replacing. I bought a De Deitrich oven (pyroclean) in Sept 2007. The oven failed to heat in Aug 2009. The oven lock needed replacing which meant the unit had to be removed from the wall. It was replaced under guarantee but failed again in June 2010 and was replaced at a cost of €140 by enginneer. I am very dissappoined in the oven and expected to have no problems with it considering the DeDeitrich name. I would not recommend it to a friend. By the way the clock is easy to use if you follow the instructions exactly. Oven used by two careful owners only.
Mar 31, 2008 | Ovens
Ovens Logo
90 people viewed this question
Top De Dietrich Ovens Experts
ashburton
Shehu Pro
Shehu Pro
Electro Med Services...
Are you a De Dietrich Oven Expert? Answer questions, earn points and help others
