Question about Smeg Cooktops
What is F4 error code on induction hob.
I'm having a problem with my new induction hob. Right hand side of the hob doesn't work - F4 error code.
  • 1462 Answers
SOURCE: Only 2 hobs work
this is almost certainly a wiring issue at the mains connection block, there are links which have not been tightened down. there is usually a diagram adjacent to mains block telling you what to do. connection block is covered by a plate. take plate off and tighten all terminals making sure links have been inserted. switch of at mains of course
Posted on Jun 06, 2007
SOURCE: Neff T4344 hob, need instruction manual???
Try http://bshappliancecare.com/Neff/customercare.html
You can download a PDF manual for the T4344
Regards
Jon Morgan
Posted on Feb 06, 2009
SOURCE: Neff induction hob safety lock
safety lock is on. How can I release safety lock?
Posted on Nov 06, 2009
SOURCE: Eurokera hob - lights flashing, buttons not working
hi i have a eurokers ceramic hob and it has not worked in about a yr. it is touch screen and only 1 mth old when problem happend it was like it over heated and now when you turn it on it flashes on the dial i cnat make out it and the hob wont come on. pls help it is brand new and dont want to throw it out.HELP PLS
Posted on Dec 20, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: we got an E3 error
Sorry to read about your problem, I hope this helps you out.
stop using and call a service company, before further damage occurs.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 23, 2010
Telefunken spare parts australia
Try turning off the power for a short while to allow the p c board to re set itself turn it back on and individually turn on each elements for a few minutes. Good luck
Ray
Apr 16, 2014 | Kuppersbusch Glass ceramic induction hob...
Neff induction hob error message flashing rear left r rear front E rear and front right 2
sir pls send me the answer when we put a pot on induction.after 30 minutes igbt get short
Dec 21, 2013 | Cooktops
Induction hob not heating up. What does 5h or SH error code indicate?
if they are not steel bottomed pans they will not work with induction hob test them with a magnet
Apr 07, 2013 | Smeg Cooktops
Right hand side of hob flashing reverse 9 or p inop on t4343 other side of hob working ok
right hand side hob not working. Flashing on and off with a sign that looks like a reverse 9 or P maybe?
Feb 28, 2011 | Neff 23 in. T4343 Electric Cooktop
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
Jul 28, 2010 | Neff Cooktops
Jun 18, 2009 | Cooktops
Induction hob switching off
check that the hob is wired correctly underneath 1,2,3 should be linked together as live 4,5 as neutral and earth takes its place as earth,
if it is wired correctly then i m afraid the hob needs a new induction element it is all one complete unit on these hobs not seperate so your looking at £1000 + to fix it plus engineer call out charges
Dec 06, 2008 | Kuppersbusch K 23 in.EKE604.2 Electric...
Miele KM5753 Induction Cooktop - Error 30
I have a KM5753 with FE31 and it remains after a breaker 1 minute re-set as per instruction booklet - anyone seen that one?
Mar 01, 2008 | Cooktops
Cooktops Logo
170 people viewed this question
Top Smeg Cooktops Experts
Timllfixit
ray gallant
marlin siecinski
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
