Needing to replace 7" touch screen with zforce
Follow this steps and fix it. God bless you
Turn off your tablet and turn the unit over. Use the tip of
your small Phillips screwdriver to pop the rubber pads off of the screws
on each corner of the rear of the unit.
Remove the four screws from the corners of the back of the tablet.
Insert the tip of your case opener tool in the seam where
the front and back halves of the unit meet. Work your way around the
sides, popping the internal locking clips as you go. Continue until the
two halves separate.
Unplug the screen ribbon which runs from the back of the
screen in the front half of the unit to the motherboard located in the
back half of the unit. Set the back half of the unit aside and you will
see the back of the LCD screen in the front half of the unit.
Remove the LCD screen from the housing and fit a new one in its place. Reverse the steps for reassembly.
