Question about Broaster 1800 Pressure Fryer
Looking for someone to service and clean 1800 broaster to resale
I have a broaster that turns on but will barely heat the oil. Does anyone know what would be causing this?
Is it made by the Broaster Company or a spin off like a Henny Penny? Is it gas or electric? If by the Broaster Company would it be a 1800 or a 1600? Give me this information and than I can tell you what the problem is. Not an expensive fix either.
May 09, 2014 | Broaster Pressure Fryer
Broaster 1800 machine is over shooting oil from top back steam valve and the valve that goes to little bucket in front
Dan,
Sorry, I am new to this site, and did not know about it until today. I am a Broaster distributor, and have the parts available. Couple questions if you have not resolved issue yet. Does your pressure guage work? If so how much does it read with about 8 pieces of chicken in a load?
Jon
jondf1@gmail.com
Dec 16, 2012 | Broaster Pressure Fryer
Pressure not building in 1800 broaster
In order to build pressure, you need to first make sure that you have enough product to generate enough steam to build pressure. In a Model 1800 you need about 5-6 pieces of chicken or the equivalent to build a sufficient amount of pressure. You also have to have enough heat to create the steam, so check the oil temperature with a thermometer to make sure the actual temperature of the oil is close to the set temperature. If you have enough product at the proper temperature but no pressure is being generated, you need to determine where the steam is escaping. If the steam is escaping around the cover, replace the cover o-ring. If the steam is escaping from the exhaust stack in the back right corner of the unit, then your pressure regulating valve needs to be cleaned or rebuilt. The pressure regulating valve is mounted to the front of the cooking well just below the countertop. If the unit is several years old you should go ahead and get the rebuild kit for it.
Apr 09, 2012 | Kitchen Appliances - Others
My Broaster 1800 timer counts down correctly but no sound comes out of the speaker, only a clicking noise. I have replaced the speaker and still same problem
If you have replaced the speaker with a new one and you still have the same problem, you will have to replace the control panel. The current P/N is 15708, but if your unit is more than 10 years old you will also need a controller conversion kit (P/N 15755 if yours is an electric unit, or 15756 for a gas unit). You can get the parts from a Broster distributor, go to www.broaster.com to find the closest one.
Jul 16, 2011 | Kitchen Ranges
Where can I find a instruction or service manual for a Broaster 1400 E ? jprettie@excel.net Thank yoiu
Hi there.
Try visiting this web for manuals.
http://www.broaster.com/fdsvceqp.htm
Regards.
Jul 05, 2011 | Kitchen Appliances - Others
I have a Broaster 1600-1800 electric model and it takes about 3 hours to heat up. The digital readout blinks on and off saying both lo and intermittently going completely blank. After it heats up the LED's...
If the digital display is going blank, but the Power On light is staying on, the problem has to lie in either the Controller Transformer or the Controller. To determine which, just check the voltage at the 2 red wires that go from the Controller Transformer to the back of the circuit card. That should read around 26VAC whenever the Power On light is on. If the voltage is still present when the Controller goes blank, then the problem lies in the Controller. Contact The Broaster Company through their website, www.broaster.com, and call the Service Department. They can easily provide a Service and Parts Manual to you, as well as help you troubleshoot your problem. Good luck and I hope this helps.
Feb 03, 2011 | Kitchen Appliances - Others
Looking for wireing schematic for a 1400E broaster and does it take 120 volts to activate the contacts
I'm looking for an owners manual for a Broaster 1400 E.
Could you tell me where I can find one?
Thank you
Nov 20, 2009 | Kitchen Appliances - Others
I need wiring diagram for a Broaster pressure fryer Model 1800E
I have a service manual for the 1600 and 1800 Broaster and it has wiring diagrams in it
Nov 03, 2009 | Kitchen Appliances - Others
Broaster 1800 Pressure Fryer Logo
22 people viewed this question
Top Broaster Garden Experts
Dennis Key
Dennis Key
john h
Are you a Broaster Garden Expert? Answer questions, earn points and help others
