Question about TP-LINK Computers & Internet
Who I can make password for my TP-LINK - TP-LINK Computers & Internet
How do i change password for tp link wr741nd
If it's the security key just login to the router and change the password. If it's the password to login to the router UI you will need to reset the router to factory settings.
Mar 07, 2015 | TP-LINK TL-WR740N 150Mbps Wireless Lite N...
Change password non computer
If you reset the router, you return to the default setting. Then you have to create a new password. All of the settings you had before will be lost, including the MAC address, and security settings.
Here is a link of a video to help you:
TP Link TL WR740N Router Manually setup and configuration
Mar 17, 2014 | TP-LINK TL-WR740N Router
I cant remember the password of our wifi pls help here's my email...tnx!
You can reset to factory default by pushing and holding the RESET button for 30 seconds or so, release, that will restore the device to the factory default settings. Connect and reconfigure the SSID and Security Code. You may want to write down the Password for future use, just a thought. For info: http://www.tp-link.com/Resources/document/TL-WR740N_741ND_User_Guide.pdf
Dec 24, 2012 | TP-LINK Computers & Internet
Ruter tp-link efb6f6 pin
Hello the homepage is here:
http://www.tp-link.com/dk/support/download/?all=1
Search for the manual by model number.
http://www.tp-link.com/en/article/?faqid=92
Type the username and password in the login window (the default username and password are both admin), then click OK.
More here:
http://www.tp-link.com/en/article/?id=85
Good luck
Nov 22, 2012 | Computers & Internet
I have set password for my TP-WR642G long time ago, but I want to change it. What can I do?
When you purchased your router, if It came with software then your going to have to use that. It should be as simple as opening the software, finding the setting and changing it. If not, your going to have to be an administrator on the network and go to network settings.
Aug 17, 2012 | TP-LINK TL-WR642G Router
TL-WR940N
Hello
I can give some details on port forwarding for TL-WR940n. You could follow this procedure given below. here is the link too. http://www.tp-link.com/en/article/?id=72
How do I open ports on my TP-LINK wireless Router?
Suitable for: 300Mbps Wireless N Routers, 150Mbps Wireless N Routers, 54Mbps Wireless G Routers
Step 1 Open the web browser and type the IP address of the router (default is 192.168.1.1 or 192.168.0.1) into the address bar and then Press Enter.
Step 2 Type the username and password in the login page, the default username and password both are admin.
Step 3 Click Forwarding->Virtual Servers on the left side, and then click Add New... button.
Step 4 Type the Service port which you want to open and the IP Address of your computer; Select Protocol to TCP, UDP or ALL; Change Status to Enabled
Step 5 Click Save button to save the settings.
Note:
If you want to open port 80 for Web server in your computer, the Management port of the router will be changed to 8080, you need to type Http://192.168.1.1:8080 to connect to you router.
TP-Link_SupportForce
TP-Link USA Corporation
Tel: +1 866-225-8139
E-Mail: steve.crow@tp-link.com
Website: www.tp-link.com/en/support/index.asp
Jun 08, 2012 | TP-LINK TPLink Tp link Tl wr940n 300mbps...
I wish make password for my wireless router my TL-link is TL-WR542G I havnt password before thak you
download the manual from here
http://www.tp-link.com/support/download.asp?a=1&m=TL-WR542G
it will tell you how to set it up for wireless security
Feb 13, 2011 | TP-LINK TL-WR542G Wireless Router
How to recover the password for 198.168.1.1
You will need to reset it then it will come to default
password. unplug power cable then while powering on press the reset button simultaneously.
ok
A user name and password prompt will appear. Type in admin (lower case) for the username and password. The username and password admin are the default username and password of TP-LINK Routers.
ok link
http://www.tp-link.com/support/showfaq.asp?id=10
Jan 07, 2010 | Computers & Internet
Computers & Internet Logo
Top TP-LINK Computers & Internet Experts
Martin Murray
alex metro
alex metro
Are you a TP-LINK Computer and Internet Expert? Answer questions, earn points and help others
