Question about Garden
Craftsman LT 3000 pto will not disengage
The blades will not disengage when you release the handle. Model 917.276814
  • 33 Answers
SOURCE: motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Posted on May 02, 2009
  • 130 Answers
SOURCE: electric pto won't stay engaged on LT 1045
you have a shortage or your clutch is going bad
Posted on Jul 18, 2009
  • 95 Answers
SOURCE: prob with PTO on craftsman mower 917.273372
There is a idler pivot plate on the mower that must be cleaned and lubricated regularly, from the left side of the mower deck if you look in the middle of the mower deck while someone engages the mower(with the engine off) you will see the pulley try and move,there is a 3/8 bolt that comes up through a bushing that this pivots on, soak that area with wd-40 and see if that improves the movement. Be sure not to get any wd-40 on the belt or pulleys. Always try and keep that area clean and lubed.
Posted on Jul 30, 2009
  • 636 Answers
SOURCE: craftsman riding mower blades won't disengage
Sounds like the shear bolt is broken, Do you have and owners manual to show you the location of shear bolt? They are easily replaced.
Posted on Aug 15, 2009
  • 138 Answers
SOURCE: need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Posted on Aug 25, 2009
Model 917.20381 riding mower. Why don't blades disengage?
Terry, Deck full of debris around belt tensioner not allowing it to release, tension arm seized/spring broke, wrong/small belt installed.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 42 MOWER REPAIR
My mower deck will not disengage
Blade will not disengage Craftsman 917 270662
https://answers.yahoo.com/question/index?qid=20090407155731AACRvsq
Sears Craftsman 917 272481 LTX1000 Riding Mower Deck Belt Blade...
Apr 08, 2016 | Craftsman Garden
Cluch on mower doesn't turn blades when pto switch is turned on what do I look for
Craftsman Mower deck (clutch) Won't engage - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jul 1, 2006 - I can push in the PTO switch to disengage the clutch and blades and the tractor starts fine and runs. But as ... If it doesn't lock up, look further into the deck...... Hi I hope somebody can help , I have a craftsman zero turn mower. PTO switch bypass????
Sep 4, 2010
Craftsman Lawn Mower Dies after a few seconds
Jan 31, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
More results from forums2.gardenweb.com
Sep 25, 2015 | Cub Cadet Garden
Craftsman zero turn runs but blades won't engage.
if got elect. pto/ and clutch,could have a wire connector come loose
Oct 21, 2012 | Craftsman Garden
I have a Craftsman FS5500 48" lawn mower. The PTO makes a noise (squeak) for a second when I pull up on the red blade engage knob. The blades do not engage. PTO does not turn. When I push the red...
The problem is probably in the button that you pull and push to engaged and disengage the PTO... If you wiggle the button or try to pull it slowly, you may find a spot where it will work. But the button has gone bad and will need to be replaced.
If you are comfortable with wiring, you could jumper the wires and getting it working, but it would be a very temporary and possibly dangerous fix...
Jul 30, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
When i turn the key on the mower the engine turns but does not want to start
if theres a safety mech's on them make sure blades and pto are disengaged, also sometimes you have to depress clutch or have the parking brake set, just like if you are mowing and decide to stop and put it in nuetral if the blades are lowered and pto engaged when you leave the seat the motor will cut off. if that isn't it make sure your spark plug is pushed all the way on.
Jul 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blades running while the lever is disengaged
sounds like belt is to tight or the electric clutch isn't disengaging
Jun 25, 2010 | Craftsman YT 3000 42" Kohler 22 hp Gas...
I Have a Craftsman 917.256. The engine will only start with the Blades engaged( & no cutting deck on), and the clutch pedal has to be pushed down. As soon as I disengage the blage control, or release...
There is no way to guess at the problem, you'll have to use a meter and check the safety switches. Most likely there is a problem in the switch for the PTO, find the wire connector that attaches to the switch on the PTO and disconnect it.
If the unit works, then replace that switch
Nov 23, 2009 | Craftsman Garden
How do u get the blade going to cut grass
there should be a lever or switch that will make
blades turn..
Jul 02, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
