Question about Denon DN-C680 CD Player
Error code 104 - Denon DN-C680 CD Player
My washing machine won't power up and no lights come on.Is that an error code of 104 ? I replaced the DIsPlay Module but it is still doing the same thing. Any help out there ??
Yes error code 104 if you are counting from the left. Pushing power & start should not bring up an error code. Makes me think there is more going on than is obvious. Why did you replace the display board? If you did it just in the off chance it may fix the problem then that is the wrong thing to do. You are only wasting money buying random parts. Would be cheaper in the long run to call someone out to repair it and test it properly. You get no warranty from F&P if you fit those parts yourself.
Jul 08, 2016 | Fisher and Paykel Washing Machines
Hs error code what does it mean?
Water Temperature Sensing Error
A) Inlet water temperature sensor is reporting a temperature in excess of 104 degrees. Normal operation resumes 2 minutes after inlet water temperature sensor reports temperatures of 104 degrees or less. This error functions in both normal and remote thermostat modes.
or
B) Inlet water temperature sensor is reporting a temperature change at a rate faster than 6 degrees in 60 seconds, indicating a potentially damaging low water flow condition. Normal operation resumes when temperatures stabilize. If this condition is detected 3 times, the heater will lock-out until the electrical power is cycled off and back on.
Jun 19, 2014 | Hayward H400FDN Low NOx Natural Gas Pool...
What is error code 104
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
or click start type in event viewer press ENTER
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Nov 08, 2012 | Computers & Internet
Fix code 104
104. (01101000) See Fault Code 106
106. (01101010) Display Module to Motor Control Module Communications Error
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Action: Replace Motor Control Module.
Jan 24, 2012 | Fisher and Paykel GWL11 Top Load Washer
Denon error 104
error 104 is unable to actuate focus. Which means the laser lens assembly is most likely defective
Feb 04, 2010 | Denon DN-C680 CD Player
Code 104
Recovert code 104
would you like to recover your system?
NO
Repair disk
Format disk
P.S. pressed the OK button on the device and its telling me to
connectto your divise to my PC and install an update file DONE
then the devise reapear back to recovery code 104
Jan 14, 2009 | Archos 405 Digital Media Player
Won't play DVDs or CDs at all. Reads error code C-104.
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Dec 27, 2008 | Sansui VRDVD4005 DVD Player/VCR
Hp dv2000 error code 104- unsupported wireless network device detected system halted
The user has not described the operating system in use.
However this problem generally occurs due to incompartible hardware. in this case it is ever stated. ie. Network interface Device. I suggest you disconnect the Network devices including cables, then try to reboot.
If not descibe how far the booting process gets and type of network hardware connected and operating system to your system
Heruless
Nov 07, 2008 | HP Compaq Presario V2000 Notebook
Sansui VRDVD4005 will record DVDs provided they are DVD-R NOT DVD+R. I have one of these for 3 going on 4 years and I took it apart and cleaned the dust off the magnetic hub and that worked for awhile but (2-3 months) now I'm having trouble finalizing again. Someone on this site said it needs 8x NOT 16x disks ... 'cause it's an older unit ... I'm checking it out in the users manuel.
magicbbs
Oct 19, 2008 | Sansui VRDVD4005 DVD Player/VCR
Denon DN-C680 CD Player Logo
26 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
