Pakispan punjabi tappy - Audio Players & Recorders
Why doesn't the engine turn over?
The starter is not engaging or the spark plug is missing. Try tapping (not hammering) the body of the starter with a wooden object like a hammer handle. If you use a metal object like the head of the hAMMER YOU WILL CRACK THE CASE OF THE STARTER AND RUIN IT. sorry about the caps lock, I don't feel like going back and correcting... Just a bit of tappy tapping might do the trick. Have a friend turn the ignition switch so you gat easily tappy tap the starter. Capische?
Jun 17, 2014 | 1984 Honda VF 1100 C
Punjabi jokes
What is the issue here ? Do you want a site for punjabi jokes ? http://www.punjabijokes.net/
Aug 01, 2013 | YouTube Videos
It sounds like theres a rattle in my 2001 yamaha warrior 350 as if its on the front left side of the motor. is somthing loose????
sounds like it could by the timing chain / chain tensioner
or you need to set the valve clearances if its tappy rather than rattly
Jul 17, 2011 | Yamaha Road Star Warrior Motorcycles
I would like to have my tom tom speaking in punjabi is this possible?
It is possible in theory. The voices the Tomtom machine uses can be downloaded and changed via the Tomtom HOME software. Tomtom published specifications on how to create voice files, too.
However, I am not aware of any punjabi voices supplied by Tomtom nor by user supplied content yet. You'll have to wait until somebody creates a voice file in your language, or you could write the task on your own banner.
Jan 01, 2011 | GPS
Hello sir send me the address of samsung service center in noida ...
Central Market, 14, Central Market, Ashok Vihar,, West Punjabi Bagh, Punjabi Bagh, New Delhi, Delhi 110052, India+91 11 6533 0697
Closest location that I could find.
Dec 11, 2010 | Samsung Computers & Internet
Hi, My S Reg Golf will not turn the engine over and start. When we turn the key, there is just a clicking, tappy tappy sound from around the base of the steering column. THe rapidity of the clicking...
try a jump start ,then with engine running remove neg battery terminal ,if engine stops renew the alternator if it keeps running then renew the battery
Dec 09, 2010 | 2003 Volkswagen Golf
I have a 2002 bora tdi 100 s and the engine is quite tappy and loud, is there anything i can do to quiet the engine down or stop the tapping noise??? the engine itself runs and goes fine, i have been told...
hi,the first thing to do is an engine flush,then refill with10/40 or 20/50 oil, semi sythetic,not forgeting to change the filter.this particular engine is quite loud but the noise should die down after about 15/20 secs if its tappy.i would also reccomend adding wynns or another oil additive to help the self adjusting tappets quiten down.An oil blockage would show up as a loud knock (big end rumble)and the oil warning light would show on the dash.
after you do the oil change rev the engine to 3000 for 30 secs.this will help to get the tappets right.
Aug 25, 2010 | Volkswagen Golf Cars & Trucks
16 people viewed this question
 Grubhead
Grubhead
