I swapped my transmission and got everything back togather and it won't start? Do I have to reset computers or sync them?
    Problem Solver:
  • 13 Answers
Yes sync them
Posted on Jul 28, 2013
I have a 2000 Dodge Durango and we got a transmission from Ebay and we got the old one out and new one in and the torch convert bolts won't line up...any suggestions?
Its the wrong transmission. You can't swap transmissions with different engine sizes. You also can't swap converters with different transmissions. Just won't work. Sorry. Pull it and send it back.
Dec 23, 2014 | 2000 Dodge Durango
Hello, I'm having problem with my corolla S 2007
Could be a lot of things but I would un hook the battery for a few minutes and then hook it back up to reset everything and then go from there.
Sep 13, 2013 | Cars & Trucks
Mac 0sx 10.5.8
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
May 28, 2013 | Apple Leopard 10.5 Osx Mac Operating...
I have an 03 grand caravan and I swap engines with an 06 grand caravan but it won't start
you will need to get a code reader and reset the ECC, remove positive cable first, then ground wait 30 min, then try. Your keys may also need re coded . Sometimes the anti-theft system will prevent it from starting, either way, A good code reader, and a reset will allow your computer codes to clear to accept the new engine. I hope this helps.
Sep 21, 2012 | Cars & Trucks
My car has all the juice but when turn it over it won't even try to start but lights and dash all light up it says security in the message box it was very rainy yesterday when the problem began
I have this same issue - I've researched it to death. I've been told it everything from the BCM (body control module aka computer) to a bad ignition switch to a loose ground. The cost to getting it fixed runs into the hundreds of dollars. Fortunately it comes and goes and is not a permanent fault on my Impala. The security indicator lights because the computer thinks the car is being stolen. I swapped keys and it does seem to help but it still crops up now and then. The easy solution is to turn the key to the off position and (this is very important) wait no less than 10 minutes. Turn the key and your vehicle should start. 10 minutes is the time it takes the system to reset. During that 10 minutes reset period don't open the doors or turn the key at all. Hope this works for you as it continues for me.
Feb 04, 2012 | 2002 Chevrolet Impala
What is the timing setting on a 2000 ford ranger 3.0 v6
The timing belt syncs everything in your motor to work at the same time, the spark plug ignites, the turns the piston, then turns the cam then turns the transmission...all have a certain timing that each one needs to take place and if that is out of whack your car won't work properly, timing belts should be changed every 50k miles. most likely won't be able to do it on your own because the engine mounts need to me removed in order to get a new belt on and you need a timing light as well. Spend the 400 - 500 bucks to have someone do it, if it breaks it could cost around 1200
Dec 14, 2011 | Ford Cars & Trucks
Can I take a motor and ****** from a 79 four wheel suburban and put it into a 84 camaro?
There were stars in your question after the word "and" but i'm guessing you meant motor and transmission. You can swap the motor but a 4X4 transmission won't work. You would have to completely disassemble it to change the tailshaft. However that style of transmission would fit as long as it was for a 2WD vehicle. My Chilton shows your body style, an "F"body coming with both a 305 and a 350 so GM parts should be available in scrap yards to make the swap easy. Hope this helps.
Sep 11, 2011 | 1984 Chevrolet Camaro
The car sat up awhile. The battery died. We replaced the battery but the car still won't start. Everything comes on. The starter was tested and it was fine. What is the problem?
THERE ARE MANY POSSIBLE CONDITIONS THAT COULD PREVENT YOURCAR FROM STARTING. 1. NUTERAL SAFETY SWITCH IF THE CAR HAS AN AUTOMATICTRANSMISSION. 2. CLUTCH POSITION SWITCH IF THE CAR HAS A MANUAL TRANSMISSION.3. BRAKE PEDAL SWITCH. MANY NEWER VEHICLES HAVE A SWITCH ON THE BRAKE PEDAL ANDIF THE PEDAL IS NOT DEPRESSED WHILE TRYING TO START THE CAR, THE CAR WON'TSTART. ANOTHER POSSIBLILITY IS THE SECURITY SYSTEM. DOES THE CAR HAVE ASECURITY CHIP IN THE KEY? THESE ARE SOME OF THE MOST COMMON REASONS THAT A CARWON'T START FOR NO APPARENT REASON. HOPE THIS HELPS.
Aug 18, 2011 | 1999 Mitsubishi Montero Sport
Can't get Router to connect to the xbox360 it is telling me that I need a wap/wap2 pass phrase. Where do I get this from. It was working fine the other night. And it dropped everything in my house....
Only option is to press button on the router ''reset''
Press and hold it for 30 seconds and release it. This will set everything back to factory settings.
Jul 29, 2011 | Linksys WRT120N Router
 Grubhead
Grubhead
