Question about Haynes VW Jetta, Rabbit, GTI and Golf Repair Manual covering New Jetta 2005, Jetta 2006-2011, GLI 2006-2009, Rabbit 2006-2009, GTI with 2.0L engine 2006, GTI 2007-2011, and Golf 2010-2011. Does not include 2005 Jetta based on the A4 platform or 2006 1.8L GT
2011 vw jetta where is wiper relay - Haynes VW Jetta, Rabbit, GTI and Golf Repair Manual covering New Jetta 2005, Jetta 2006-2011, GLI 2006-2009, Rabbit 2006-2009, GTI with 2.0L engine 2006, GTI 2007-2011, and Golf 2010-2011. Does not include 2005 Jetta based on the A4 platform or 2006 1.8L GT
2006 vw jetta wiper problem
check in hand book for relay position
Dec 06, 2015 | 2006 Volkswagen Jetta
2006 vw jetta wiper still not working after changing the wiper motor and wiper switch ? help
Did you check the fuse? Have power at the plug? could be a bad ground.
Dec 06, 2015 | Evan Cars & Trucks
2000 vw jetta wipers move just a little bit on the window is the relay bad or is the motor bad
Sounds more like it would be the wiper motor. If it was the relay they wouldnt move at all.
Sep 07, 2011 | 2000 Volkswagen Jetta TDI
Where is the wcm relay located on a 1994 VW
ECM IS UNDER DRIP TRAY BETWEEN ENGINE AND PASSENGER WIPER.
Jun 16, 2009 | 1994 Volkswagen Jetta
Steps for replacing wiper motor for 1998 VW Jetta 4 cyl.
remove wipers. remove plastic covering by loosening plastic screws first. unplug wiper motor wires. there are about three 10mm nuts at the motor location and you also have to unscrew the big nuts that were below the wipers when you unscrewed them. replacement is reversal.
Mar 23, 2009 | 1998 Volkswagen Jetta
Signal and windshield wiper aren't working
switch in steerig console combo wiper turn?
Mar 01, 2009 | 1999 Volkswagen New Jetta
99 VW Jetta
The turn signal relay is inside the hazard switch on the dash. Get a new one (about $30) and install that and you're cured:)
Sep 02, 2008 | 1999 Volkswagen Jetta
Haynes VW Jetta, Rabbit, GTI and Golf Repair Manual covering New Jetta 2005, Jetta 2006-2011, GLI 2006-2009, Rabbit 2006-2009, GTI with 2.0L engine 2006, GTI 2007-2011, and Golf 2010-2011. Does not include 2005 Jetta based on the A4 platform or 2006 1.8L GT Logo
20 people viewed this question
Top Haynes Heating & Cooling Experts
Mike
SimplyNo
Lawrence Oravetz
Are you a Haynes Heating and Cooling Expert? Answer questions, earn points and help others
