Question about Whirlpool Dryers
Dryer vent duct
Recently bought a new dryer. When the installer arrived he refused to hook it up saying it is a fire hazard as my existing under the house 10 years old 30 feet vent duct is plastic and laden with lint. I looked up the code and it indeed says it has to be rigid metal and smooth interior wall and limit length to 14 ft. My questions: (1) I need a 30 ft duct but the limit is only 14? What do I do ? (2) I also suppose this kind of metal duct is not easily available from Home Depot. Where can I find it? Or do they have to be custom made? From where? Any idea the cost? (3) my existing dryer vent pipe is a hole on the floor. I suppose the new 30 ft rigid metal duct has to do a 45 degree turn before it can lead to the outside. How can that be done? Your answers will be most appreciated.
    New Friend:
The vent pipe codes are based on the fact that the blower in a typical gas dryer can only 'push' a certain volume of air through a certain sized duct for a certain number of feet. Reduced volume of airflow means higher temperatures thus higher risk of fire.
First option ... is your dryer anywhere near a side wall, which would allow you to shorten the total length of duct required to reach the outside to something less than the 14 ft code limit ?
Second option ... upsize the standard 4" dryer exhaust duct to 6" to compensate for the 30ft length
Either way, in the absence of an external forced draft booster fan ( a.k.a. 'power vent' fan ) you should be using metal exhaust duct not plastic.
Posted on Jul 29, 2013
Testimonial: "Thank you, Tom. Unfortunately my dryer is in the middle of the house and is a long way from the nearest wall. But I found the 4 inch galvanized 5 ft,/ 10 ft duct from a sheet metal shop. They also carry elbow joints. I study the installation Manual comes with the dryer and it clearly sates I can have up to 44 ft of ducting with 2 90 degrees turn, and that's what I am going to do. Hope nobody is coming to arrest me."
Cerfer39
  • 709 Answers
SOURCE: Question about Whirlpool Dryer venting
http://groups.msn.com/Appliantology/dryers.msnw?action=ShowPhoto&PhotoID=79
Posted on Nov 07, 2007
  • 1122 Answers
SOURCE: dryer fuse and thermistor continue to burn out
how about bypassing the thermistor,you really only need the heater box fuse and high temp. cut out thermostat-mike
Posted on Jul 17, 2009
Controlfrk
  • 304 Answers
SOURCE: How hot is the Vent temp of my new Duet?
It's not the temperature of the air that is the problem. The air is seldom over 160 Deg F. If you have a vent fire the piping needs to last long enough without melting to starve the fire of oxygen in the hopes of extinguishing. Rigid aluminum piping is best suited for this, Rigid flexible is next. The tin foil and white plastic offer little resistance to melting if a fire should begin. The melting would allow the fire to replenish oxygen and support the burning process. The main caution here is to keep your dryer and vent clean...at least annually.
If the duct inside your wall is rigid metal all the way from the dryer to the house exit you need to do nothing to it . Replace the vent between the dryer and the wall with rigid metal 4" piping or hard flexible aluminum piping. If the duct inside your wall is either of the least effective types you need a new run of vent for the dryer to avoid a fire.
You can't use white plastic or flimsy flexible aluminum that feels like aluminum foil when you touch it.
Posted on Sep 11, 2009
Testimonial: "That makes great sence. After closer inspection, plastic flex hose is below the floor. IT WILL BE REPLACED. Great answer. THANKS, Les"
  • 534 Answers
SOURCE: We have just purchased a Lg Dryer #DLE1310W which
lg driers are a 3 prong drier cord receptical he shouldn't have to purchase any other venting as long as the location of the dryer is not in an oddball place The parts included are for basic installation in an area such as the garage or room connected to the garage where the access to the outside is just through a outer wall. Mrs. Leonard good luck on your repairs and hope I helped you some.
Dave
Posted on Sep 16, 2009
jumptrout51
  • 3361 Answers
SOURCE: Have a Kenmore 796.8031 electric
Your duct run will be satisfactory.
No need to insulate it.
If or when you develop a too long drying time remember to check the duct for blockage. It will stop up eventually because of the vertical run.
Metal tape the joints and use suspension straps to stabilize every 4 feet.
Posted on Sep 13, 2010
Start up procedure
Check your vent duct, it may got clog inside there. Take off your vent duck from the rear of the dryer. Turn on the dryer again, if it is hot, your vent duct is the issue. Else, you need service man to take care of it.
Oct 07, 2013 | LG Dryers
Dtyer load and air not venting to outside vent
The blower motors on these dryers can be packed with lint. It is a fire hazard. The entire front of the dryer has to be removed.
Jul 04, 2010 | LG DLE2101 Electric Dryer
Brand new dryer. turns on, heats up, doesn't dry clothes
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Nov 25, 2009 | Maytag Centennial 7.0 Cu. Ft. Super...
The back of my dryer is getting very hot and actually tripped the breaker, also clothes taking forever to dry
Pull the exhaust vent off and check for obstructions, if there's no flow, all the heat is going to build up and also block any lint from escaping out the vent as well.
This can be a fire hazard as well. You may also need to open the dryer and clean out all the lint build up.
When you pull the pull flex hose off the back (the 4"diameter one) check in the back of the machine in the pipe and also in the flex tube. You may have to explore a little in the exhaust line to find the blockage...sounds like this is your issue...
k
Sep 16, 2009 | Dryers
Sep 10, 2009 | Whirlpool Dryers
My whirlpool duet electric dryer lets so much lint get through. A lot of lint doesn't get caught in the lint trap mesh and is going through the vent. I can tell by what is exhausted outside my house. I...
yes fire hazard ---but you need to make sure the lint trapp is seated all the way down if it doesant seat the lint will blow pass the screen ,,replacment might be nesasary if trapp is damaged less than 20 dollers at most parts stores.
Aug 10, 2009 | Dryers
Moisture inside dryer door when clothes are drying. Model number DBXR463ED2WW
If you are experiencing moisture inside the dryer drum, then you have a clog somewhere. A dryer needs proper air flow in order to dry efficiently. If you have not had your dryer exhaust vent ducting checked anytime recently, now might be a good time to do so.
HOW TO DETERMINE IF YOU HAVE A DRYER CLOG:
Remove the dryer exhaust vent hose from the back of the dryer and attempt to dry a load of clothes as you normally would. The air escaping the back of the dryer should be forceful and warm (about 140 degrees F).
If the air flow is normal and the clothes dry properly, you need to check the ventilation from the point where it leaves the dryer, to where it exits your home. Check for kinks, sags or significant bends in the vent ducting that may be causing choke points where lint can accumulate. In addition, it is strongl;y recommended that you use the semi-rigid aluminum ducting as it resists crushing and is heat resistant.
If the air flow is weak, then you have a clog INTERNAL to the dryer. The lint screens do not catch everything. Some lint, along with moist air from your clothes gets exhausted through the blower fan housing and out through the ducting. This is normal. Lint can accumulate over time, however. If allowed to restrict the air flow, the moist air cannot escape and tends to permiate the lint with moisture. Once the lint becomes moist, it sticks inside the ducting and collects more lint to the point where it starts to restrict air flow and reduce the dryer efficiency. It is highly recommended that you check your dryer blower fan housing and internal ducting about once per season to prevent this.
If gone unchecked, the dryer will actually overheat to the point of failure. Accumulations of lint is also a major fire hazard. The majority of the dryer failures I have repaired were caused by poorly installed, kinked, or clogged dryer ventilation.
If you have any questions, please let me know. I hope you find this information helpful.
Jul 28, 2009 | Dryers
My 80 Serie Kennmore dryer will not dry my
A simple test you can try is to remove the exhaust vent hose from the back of the dryer and attempt to dry a load as you normally would. With the hose removed and the dryer running, the air leaving the exhaust of the dryer should be forceful and warm (about 140 degrees). If the air flow is weak or non-existent, you have a clog INTERNAL to the dryer. You will have to inspect the air blower fan housing and ducting inside the dryer to ensure the blower fan is not obstructed in any way. If the air flow is normal and the clothes dry like they should, you have a clog somewhere in the DUCTING from the point where it leaves the dryer to where it exits your home. You will need to inspect the exhaust ventilation for any clogs or kinks.
If you can see the heating element glowing, you probably don't have a problem with the heating circuitry. If you haven't checked the dryer ventilation recently, now might be a good time to do so. Leaving a dryer in a clogged, or poorly ventilated condition can cause the dryer heating circuits to over heat to the point of failure. In addition, this can also create a fire hazard.
Good Luck!!
Thanks
Jul 08, 2009 | Kenmore Dryers
Our Kenmore 80 series gas dryer won't dry clothes. The barrel turns, and the heating element appears to be working, but when the buzzer sounds on the auto dry, the clothes are still very wet. Have...
Have you checked the entire run of the exhaust vent ducting? Cleaning the lint trap is not nearly enough to keep a dryer running efficiently.
If you have any questions, please let me know. I hope this helps you.
Jul 01, 2009 | Dryers
Burning smells
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.(this is a fire hazard)
Jun 18, 2009 | Frigidaire FEB27S5A Electric Single Oven
Dryers Logo
70 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
