Question about Dryers
3 speed fan switch
I have a ceiling fan with 3 speed switch. I heard a small phut sound and the fan just runs on 1 speed [full]. I replaced the switch, but no change. Did the thyristor pack blow up and needs replacement?
    Genius:
  • 1,617 Answers
Check your capacitor to see if it's going bad. Also I would put the old switch back in case you got the wrong one. Just because it looks the same on the outside doesn't mean it's the same on the inside.
Posted on Jul 29, 2013
  • ushetgeri Jul 30, 2013
    Thanks
    Opened the fan and sure enough the capacitor has melted
  • 52 Answers
SOURCE: hampton bay ceiling fan
This should do the trick. Good luck and make sure the power is off.
L - Orange, 1 - Black, 2 - Yellow, 3 - Purple
Posted on Jan 29, 2008
worldvet
  • 859 Answers
SOURCE: Trying to replace 3 speed ceiling fan switch
The black goes to the L connection the others are a guess. You can do this two ways. Connect the colored wires in any sequence and then see what switch sequence give you high and lowest, the other one will be medium. Once you determine that, mark the wires with a piece of masking tape as high, medium and low. Otherwise you connect them, turn power on and use a multimeter to see which color gives you the highest voltage and which gives you lowest. Since you aren't comfortable using live wires and a meter, go with the first option and use the process of elimination to find the wires giving you the speeds you need to find the highest and lowest. Next, you need to determine how your switch sequence works. First pull has to give you highest speed. so you may end up wiring them in reverse if your first attempt is backwards. There is a reason the first pull needs to be highest, it powers up the motor so you can then chose a lower setting. A low setting first will over tax your motor and wear it out eventually as it has to work harder at first.
Let me know if you need further clarification and perhaps this is all you need to get fixed.
Regards,
Worldvet
ps I checked on the Internet of a wiring diagram and I bet you did tok all to no avail.
Posted on May 27, 2008
we have a hampton bay fan burning smell coming in didnot run
Posted on Jul 07, 2008
  • 6 Answers
SOURCE: Broken ceiling fan switch
NOT ALL SWITCHES ARE THE SAME!!!! Some are single layer and some are not!!. I think you can tell by the body color of the switch. Red and Black, Grey and Black, ETC. I figured this out after buying 3 of the wrong switches. Each one hooks up a little different. If it is an aloha brand fan like sold at WalMart it is a common issue. Just call there 800 number and they will send you a new one. You have to know the exact model number of have the bar code. Usually there is a bar code on top of the motor. Just take it down from the ceiling and look. I called them on Thursday and got a free switch and capacitor on Monday!! My fan is going great again. If you have the old switch check it or just call the fan's customer service!!
Just call 1-800-295-4448. Even the call is free.
Posted on Aug 18, 2009
SOURCE: wiring pull chain 3 way switch for ceiling fan
I am in the middle of doing this now. 1 = Yellow; 2 = Blue; 3 = White; and L = Black.
Posted on Oct 06, 2009
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution.
4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09.
How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch:
old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use:
L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black
1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray
2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown)
3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple
4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green
old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use:
2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green)
3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown
4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
Feb 18, 2013 | Hampton Bay 24750 Huntington III Ceiling...
3 speed ceiling fan switch installation
Fan is wired wrong, but you need to test using multi-meter.
Buy cheap multimet from hardware, install battery, set to read ohms or the upside down horseshoe symbol
Copy following link for testing wires:
http://waterheatertimer.org/How-to-wire-3-speed-fan-switch.html
Oct 07, 2012 | Hunter (25417) Ceiling Fan
I replaced the 3 speed fan switch on my Hunter 21834 ceiling fan/light. The fan only has 1 speed (fast). What did I do wrong? I tagged each wire to match up, but now only one speed.
What was the original reason why you changed the switch? Sounds like you got the hot wire and high speed wire swapped. The hot wire coming from the upper part of the fan should go to 'L' and then the three other wires going down to the little black boxes for the speeds should go to the corresponding 1,2,3 on the switch.
Sep 05, 2011 | Hunter 52" Ceiling Fan With Light
Replacing 3 speed 4 wire ceiling fan switch did not take note on what color wire goes L 1 2 3 wires colors are black grey brown and yellow need help to fix fan
Copy following link for 3-speed fan wiring:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Apr 27, 2011 | Solar Fan Impressions 3 Speed/4 Wire...
3 speed switch only works on full speed.
Make and model number of the fan is a good start. Ceiling fan or desk or pole or?????
Jul 28, 2010 | Hunter Ceiling Fan Control Switch
I have a 3 speed fan switch that i am replacing, b...
Hello. I really hope the 2nd grey is simply a faded purple or green. The most common configurations would be: L - Black, 1 - Grey, 2 - Brown, 3 - Purple or green. Here's a link to some troubleshooting advice: http://www.ceiling-fans-n-more.com/ceiling-fan-pullchain-replacement-and-repair.php and a link to diagrams: http://www.hurontel.on.ca/~taitg/pages/cfan.html
Hope these help clear up that nasty faded color for you, and don
May 21, 2010 | Speed Ceiling Fan 3-speed Switch By...
Hampton Bay Ceiling Fan At Slow Speed
I recently replaced my hampton bay fan for the same reason (slow at all speeds) and discovered scorched and melted capacitors and wiring inside the fan. My suggestion is to stop using fan and replace immediately.
Aug 10, 2007 | Hampton Bay 52 In. White Redington...
Dryers Logo
128 people viewed this question
Top Dryers Experts
