Question about Apple MacBook Mac Notebook
Macbook a1342 problem
Hi. Help needed! I have a MacBook A1342 2009. When I boot it up the desktop apperars fine, although takes longer than usual to reach desktop. The curser moves fine with the trackerpad but when you hover over any icon/taskbar, you can't access any application/program. When I press the power button the option window appears with "shutdown, restart etc," you then can use the trackerpad to choose your option (ie) shutdown. Therefore tackerpad is ok. Tried shutting it down and doing a SMC reset but problem still not resolved. Any help would be great. Thanks
    Sergeant:
  • 396 Answers
Use a mouse to uninstall and then update the drivers for the trackpad. There may be an issue with driver corruption, or a device conflict causing the problem.
Posted on Nov 02, 2013
SOURCE: macbook start up problems
We'll that happened to me also.. i researched and found if you goto apple.com and look up support for macbook. Look for .pdf macbook repair manuel. There you'll get start up procedures. turn off power. Then load start disk, hold down "alt/opt" button and then turn power on. Wait for a min or two and then you'll see your hard drive and start disk to choose from. Choose start disk and click enter. Be sure your disk isn't scratched.. i had that problem. Then wait... it takes awhile so be patient. You'll get the whole set up again. DONT ERASE YOUR PRIOR DISK!!! Thats where i screwed up! So.... you should be able to get what you want .. if not.. its a new hard drive you'll need to buy... i'm heading to Best Buy and the Geek Squad for my help!
good luck!
Posted on Jun 01, 2008
  • 87 Answers
SOURCE: macbook restarts when i shut it down
Try going into Utilities folder and open Disk Utility and repair disk permissions. That fixes a number of bizarre issues in Mac.
Posted on Sep 09, 2009
  • 20 Answers
SOURCE: MacBook won't start up.
If you have your Mac OS X Install disc, insert it into the drive.
Restart the computer and hold down "C" while booting.
Choose your language.
Select "Disk Utility" from the "Utilities" in the menu bar.
Select your Macbook's hard drive in the left sidebar.
Click the "First Aid" tab thats along the top of the viewer window.
Click "Verify Disk" (not verify disk permissions)
If this shows errors click "Repair Disk"
Once completed close the Disk Utility window.
Restart the computer.
If this fails to fix it as well then your next option would most likely be recovering your files from the macbook either by booting into target disk mode (hold down T at startup) and transferring them via a firewire cable, or removing the hard drive and hooking it up to another Mac to get the files. Then do a clean install of Mac OS X using your installation discs.
Posted on Feb 15, 2010
  • 739 Answers
SOURCE: My MacBook is frozen and won't let me click/shut it down
Hi Meliss
Press the power button and keep it pressed for about 10 seconds.
It should shut itself down.
Posted on Jun 17, 2010
news775
  • 699 Answers
SOURCE: My Macbook Air made "beep
The bios on the machine hardware has failed to book.
You could try plugging in machine and ensure battery is charged.
Press and hold the power button for about 20 seconds.
also the other thing is to immediately after you press the power button.
hold these 4 keys at same time continuously - cmd, alt, P, R
hopefully machine will power up and down and up again if you keep holding them.
Please dont forget to vote this answer was helpful
Many thanks
Posted on Feb 17, 2011
How to boot from usb in macbook
Hi There,
Assuming that you have a bootable USB Drive of some sort, this is pretty easy to do!
Just connect the drive to one of the USB ports on your MacBook, and start/restart the laptop.
Immediately hold down the 'option' key until you see a screen come up listing the various available boot-up drives.
Then, release the 'option' key, and choose the drive you want to startup from:
-You can use the trackpad to point at the drive, and double-click on its icon; or,
-Use the 'tab' key to highlight the drive and hit 'enter' to choose it.
The MacBook should then go through the usual startup sequence, however it may take a little longer than if you were starting from the internal hard drive.
Hope this helps!
Apr 04, 2014 | Apple MacBook Pro Laptop Computer with...
Locating and enabling the gps on my macbook a1342
This model does not include a GPS built-in or otherwise. In fact, other than iphones and maybe ipads none of the Apple computers themselves come with GPS built-in. That would be a huge pain in the neck anyway . . .
Mar 20, 2014 | Apple Macbook 13 Inch A1342 2.4ghz Mac Os...
I cant track my macbook. do i need to install a gps device?
Check out LoJack to see if it can be installed on the computer. If it ever gets lost that can locate it and shut it down and even erase the hard drive if necessary
Three-finger swipe between desktops not working as expected.
I'd try adjusting your setting in
Apple menu
System Preferences
Trackpad.
Not sure what key combination can affect those settings.
If that does not help try resetting the PRAM and or the SMC.
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jun 06, 2012 | Apple MacBook Air
My MacBook A1342 slow booting
2 Gig of RAM is not really that much. You should think about upgrading that.
You might try a PRAM reset or SMC reset which will probably help you some.
Feb 14, 2012 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Flashing Folder
you are having main-board issues and possible harddrive issue.
but the mainboard can cause drive failures your info might be fine,The blue screen indicates a board error(memory usually)
Aug 09, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook Mac Notebook Logo
119 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
