Technika tv faults
Our TV has started to turn itself off, if its on, or on if its off at 12 midnight every night. Any ideas?
    Top Expert:
  • 12,223 Answers
1) test the power button for open or short and replace it
2) test the power supply for faulty, IC regulator, or bulged capacitor, or resistor, or diode.
God bless you
Posted on Jul 28, 2013
snakehead
  • 1074 Answers
SOURCE: tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Posted on Apr 04, 2007
  • 65 Answers
SOURCE: Acoustic Solutions TV Fault
I think you are looking at a power board problem. I had the same thing happen to a Vizio and I replaced the power board and it solved the problem. It could also be the input board but most likely the power board.
Thanks,
Ced
Posted on Jul 13, 2009
tvrepairbiz
  • 63 Answers
SOURCE: When I turn the TV on it clicks 10-12 times and finally turns on.
Sounds like you have bad capacitors in the power supply. If you look they will have a bulg on the top, replace them and you should be ok.
Posted on Feb 15, 2010
  • 112 Answers
SOURCE: TV randomly turns itself off and on
This issue is related to the TV's main board not seeing constant A/C power to unit so the board is turning off the TV.
When the TV's main board see A/C power back to the unit, the TV will try to turn back on.
This issue could be a loose power connection for the TV or a failing part inside the TV. Do other electrical devices work when plugged into the same wall outlet?
Try the following:
1. Remove the cord from the back of the TV and reinstall it (perhaps it's loose going into the TV and was not installed correctly).
2. Try putting the cord into a different wall outlet (perhaps it's not a good outlet).
3. Try using a new power cord for the TV. (Any matching cord will work for testing)
If the above did not resolve the issue, then it could be the switch mode power supply and or the main board inside the TV. Both items are easy to change out.
I can look up the LG part number for you.
Posted on May 02, 2010
caroldon
  • 17130 Answers
SOURCE: my 42" technika tv wont
Possible failure of the power supply in the TV. This is the SMPS type and so the failure of the driver must be checked. Please find the link below for tips.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Feb 02, 2011
A friends Technika TV turns on by itself in the middle of the night?
Some of the televisions have a "alarm setting" on them. If some person has set the alarm for a certain time it will automatically turn on and shut off after that time setting is over. Check the menu for "time settings" this might end this from happening.
Dec 11, 2017 | Televison & Video
Technika TV 3 or 4 years old turns itself on and off sometimes after seconds sometimes after minutes. Any ideas
hi it could power supply issue, usually capacitors cause this fault
thanks
shaun
Jun 11, 2017 | Televison & Video
TV less than 3 months old.No picture but still got sound.Anyone any idea what fault might be.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 20, 2016 | Televison & Video
TV programs
vision box always play up thats why i changed to sky. in one year on vision i had 5 new boxes. there seam to be a problem with the services system I.e there is a out put file so BT know what you are watching , now this system has a flaw in it. were by it thinks the system needs rebooting as it has had an update or not. as midnight it the service time for updates it will reboot at this time. now for itv3+ this is down to itv its self. its listing time don't match it signal turn off time. itv put programs on this channel not thinking of the time that has been set to turn off the station to freeview. hope this helps you.
Mar 05, 2014 | iPhone Apps
Technika tv
These blinks [flashes] are fault indication. You can get an idea about the faulty stage circuit inside the TV, by the number of these blinks. Count it carefully, by switching it ON and OFF, more than 2 times at least, so that, you can make sure about the number of these blinks. If you wish to get more details, check the site linked here. Surf the site in "MOSAIC" view.
Jan 26, 2014 | Televison & Video
Technika 22-700 standby light flashing
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 25, 2013 | Televison & Video
Technika tv
It sounds that the problem to your TV is with its DVD loading tray. A pure mechanical fault indeed. Not loads the disc properly to its seating. A motor fault, or a gear wheel fault, or a leaf switch fault could be. Anyway, you have to take the DVD mechanism out from the TV, to get the actual problem could be resolved. Really this is a semi skilled work. It will be best to contact any service technician in this case.
Sep 19, 2013 | Televison & Video
My 22" technika tv has
look through the menu for "clock" or "timer" functions...it must have a timer program activated.
Apr 13, 2011 | Televison & Video
My 42" technika tv wont
Feb 02, 2011 | Televison & Video
My TV turns itself off and on by itself.
You have a timer that has been accidently set by someone by the remote control.
If you have an instruction amnual for the tv, it will tell you how to turn off the tv's timer.
Feb 13, 2008 | RCA P52930BL 52" Rear Projection...
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
