It washes fine just doesn't spin or drain
Hi. For general electric. Desenchufar la lavadora por 2 minutos volver a enchufar inmediatamente realizar 6 aperturas y cierre de la tapa superior dentro de los primeros 15 segundos despu?s de haber enchufado nuevamente la lavadora. Con esto de realiza un reset. Del sistemas se borran los c?digos de error.
Posted on Aug 05, 2013
jumptrout51
  • 3361 Answers
SOURCE: spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
Posted on May 21, 2009
  • 57 Answers
SOURCE: The drum doesn;t turn during wash or spin cycle
Kindly remove the back panel of the unit and check whether the belt is properly fixed if it is ok means check the wire connection if everything is fine. kindly check the motor humming sound once the water is filled if you find the humming sound means kindly replace the motor
Posted on May 18, 2010
  • 867 Answers
SOURCE: My 7 year old Maytag Legacy washer doesn't always spin and drain. Sometimes I can move the wash setting dial and get it to drain and rinse. Sometimes it takes several attempts to get it to drai
If you can manually advance it and it works then yes the timer will be the cause of the issue.
Posted on Mar 11, 2012
Testimonial: "Thanks for the confirmation. It looks like I can rejuvenate this washer for less than $100."
kevin_getz
  • 1031 Answers
SOURCE: After washing and rinsing it doesn't spin the water out.
Check the drain lines for clogs. If that checks out ok, then you probably have a bad drain pump.
Posted on May 12, 2012
caroldon
  • 17130 Answers
SOURCE: My GE SpaceSaver Washer/dryer will wash, but when it's time to rinse and spin the machine stops. It will not drain, riinse , or spin.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Posted on Jul 28, 2012
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Will not drain and spin
see this causes:
t spins, but doesn't pump
the drain line is clogged+ some sock remain, remove with pliers,+pump defective.
It doesn't spin or pump
frozen pulley pump defective, replace
It pumps, but the water returns
improve the drain line. If drain hose reach more 4 inche cut of of excess. If lower add air/gap siphon break assembly.
see diagram
God bless you
Jul 03, 2012 | Kenmore Elite 45986 Front Load Washer
Miele honeycomb care w 1712 drain fault comes on every wash
see this possibles causes:
God bless you
attached diagrams
see line clogged and fix it.
frozen pulley
improve the drain laundry, if drain hose reaches more 4 inch cut off the excess
May 16, 2012 | Miele Washing Machines
May 11, 2012 | Miele Washing Machines
Drains but drum wont spin
see this probably causes:
see for glogged drain line
see the pump pulley frozen
slow drain, improve the drain see the attachement
May 08, 2012 | Washing Machines
Spin cycle doesn't work
bad drain pump or clogged drain line. some units have drain trap you can clean,if so you can clean it out yourself but will make a huge mess if you don't pinch close the drain hose between the tub and pump.
Nov 12, 2011 | Haier HLP21N Washer
My washer fills, agitates but will not drain
Does your washer spin? If yes, and it doesn't drain it most likely a failed/plugged pump.
If it doesn't spin it could be a belt or timer issue..
Sep 15, 2011 | Maytag MAV2755AWW Dependable Clean Top...
My washing doesn't spin, It doesn't pump or spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | Washing Machines
Water doesn't drain
heatman101
Aug 08, 2011 | Whirlpool Washing Machines
Wm2455hw will not spin
Make sure door mechanism is working at fine. So next is to check whether the motor tumbles both directions.
The spin bearing might be a problem, but normally you'd hear a problem here first. Have you heard any freight trains passing through the house in the spin cycle?
One thing to check for this problem is the spin speed switch. If the spin speed switch is bad then the control won't know how fast to spin, and so it will just not spin at all.
The drain pump must be draining all the water out. If the water doesn't drain out then the pressure switch won't read empty and that might prevent a spin cycle.
I hope this helps.
Please reply with additional details for further assistance.
Shane
Apr 22, 2011 | Washing Machines
Washing Machines Logo
128 people viewed this question
Top Washing Machines Experts
