My hisense television won't switch on only a red
    Problem Solver:
  • 13 Answers
COTACTEZ UN SPECIALISTE POUR VOIR SI TOUTES LES TENSIONS SONT DISPONIBLE AVANC D ACCUSER UNE PIECE QUELCONQUE
Posted on Jul 28, 2013
  • 86 Answers
SOURCE: black parts of screen looks light light is shining on it
Your LCD TV uses backlights and they can be slightly visible when viewing a letterbox movie.  However, if the light is really bleeding into the black, there could be a problem, but mosty this is common.
Posted on Mar 24, 2009
  • 4090 Answers
SOURCE: Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
Posted on May 13, 2010
toolkits
  • 1099 Answers
SOURCE: television only has a flahing red light
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement. Hope this will help...
Posted on May 27, 2010
  • 1456 Answers
SOURCE: 42pfl7403d/27. Won't turn on normally.
Hello
The symptom you describe is consistent with an overload(short) on one of the power supply output voltages.
If you hear a clicking noise,that is one of the relays ,showing that the TV power supply try to start normally,but then a short condition is detected and power supply shuts off,and all repeats again.
Now from my experience with these units,the most common cause is the power board itself or the Y sustain board.To make the exact determination,further diagnose inside of tv set is necessary(voltages and resistances readings)-a common occurance would be some defective-bulged top capacitors in this power supply you will have to replace the board.
Depending on the models,these boards cost about-$250 to $300 each.Add another $150 for labor and the repair cost will be around-$400-$450.
Posted on Jul 15, 2011
protvrepair
  • 153 Answers
SOURCE: Heard a pop , bulb blew out , replaced bulb , it
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Posted on Oct 29, 2011
I have a Hisense led tv model F39V77C.
Yeah, replace the set since it appears to be trashed. But if you have a few bucks lying around you might want to try replacing the unit's power supply to see if that resolves the many issues you have.
Jan 03, 2017 | Hisense Televison & Video
HL32V86 Hisense 32' stuck on standby wont turn on it seems screen stay black
Call the HiSense tech dept. You can find the number on line and they will tell you how to fix it or you can try using the remote and go to settings and see if you can fix it that way. Also the manual for this tv should be available online as well.
Jan 03, 2015 | Hisense Televison & Video
Hisense LED HDTV
I am no expert, but I would be looking for a replacement or warranty on that unit.
Unfortunately there is very little an every day user can do to fix a problem like this on their own.
Jan 29, 2014 | Televison & Video
Emerson flat screen won't power off and screen flashes blue ,green, red and black?
Sounds like the main board causing that type of symptom. You can get replacement main boards from www.tvrepairworld.com
Jan 10, 2013 | Televison & Video
My 42' hisense tv turns on then blinks. blue then
Take it to a servicer with proof of purchase or back to the store. You will get it repaired for free or get a new TV.
Apr 19, 2012 | Televison & Video
STOP!
May 13, 2010 | Hisense TL1700 17 in. LCD Television
Hisense tl2020 will not power on
power supply issue..may be some bad capacitors simply replace them....dada....your prob solved
happy to help
Aug 18, 2017 | Hisense TL1700 17 in. LCD Television
Black Screen
It is possible that the backplane lamps and lamp supply has failed. It is also possible that there is a failure in the power supply or on one of the circuit boards. Without doing some tests it is impossible to accurately determine the areas of fault.
Jerry G.
Aug 26, 2008 | Hisense TL1700 17 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
