SOURCE: Endless Summer Patio Heaters won't stay lit
Hi ColdinSF,
You need to remove the covers from the unit and blow out the gas lines with compressed air. If you can remove the gas lines blow out the lines and what they connect to like the pilot light and main feed line to the burner. Usually they gunk up with use and just need to be blown out with compressed air to clear the lines again. Maybe you have some dirt or foreign object from your gas tank which has clogged the line. Also check the igniter electric lines as well and make sure everything is connected properly. Especially make sure you tighten the gas lines you remove. Hope this helps.
Regards
Bryan
SOURCE: need part # 56-01-127 pilot assembly
Call this # and order 1-800-762-1142. I hope this helps.
SOURCE: Replacement regulator required for Endless Summer patio heater
These regulators can usually be purchased from Canadian Tire or Home Depot. If you are unable to locate the exact replacement, email the model number located on the regulator and I will locate one for you. I am in the GTA and can be contacted via company website. www.emshvac.com
But one question, why do you think the regulator is defective? These rarely fail.
SOURCE: outdoor patio heater won't stay lit
I have a Charmglow Patio Heater Model SRPH02, it needed a Thermocouple and searching the net was hard to find an ariginal part, but here it is, call 1-866-814-0585 $3.95 +6.00 shipping the original part.
