Question about Garden
Craftsman c935 -35516-3
Do not know how to connect livewire to reversing switch for use with craftsman motors
2 Suggested Answers
Terry Corrow
  • 10875 Answers
SOURCE: Sears Craftsman Home Sharpener #319.190710 Correct Wiring Info or Diagram?
yes you either burned up the motor or the brushes need to be replaced
Posted on May 09, 2015
My craftsman riding mower will not go into toward to reverse vise versa while motor is running
You didn't express whether,this tractor was a manual transmission or a transaxle type. If it's a transaxle type,then there is a shift handle on right side of the tractor. The position of the shift handle operates a module reverse switch assembly,in three positions(forward,reverse and neutral) This module has a safety switch located inside. This module is in a bad place.under the fender,where it can be subjected to water,dirt and vibration. Like most safety switches installed,they have a large failure rate. This maybe your problem. The module has only two screws holding it in place,you will have to remove it,to check the safety switch. The module and the switch are all in one,if the switch is bad you will have to purchase the module. This is just one answer that could be wrong with the tractor,not moving forward or reverse. The other,the prime mover belt is bad. This belt runs from the transaxle to the bottom of the motor's upper pulley. This belt stretches,over time and will cause the tractor not to move in any direction. If this is the case,there is no adjustment that can be made. Only a new belt will solve this. Remember the little handle,in the back of the tractor has't to be in (engaged) out (disengaged) the transaxle (transmission). When the handle is out,the transmission is disengaged,used when towing or pushing the tractor by hand. I know this answer,is rather long,but important to your question. Sincerely,Brad Locke 11/23/15
Aug 09, 2015 | Craftsman Garden
Craftsman rideing lawn mower will not go in reverse
check the linkage might be out of adjustment also for the blades check the safety switches
Apr 23, 2012 | Craftsman Garden
WILL NOT START craftman LT1000 YR.2000
most likely the blades are still in the on position,but you have a seat switch, parking brake switch, and the blade switch, also the mow in reverse key switch. if mower dies once you let out the clutch in reverse with blades on and key wrong.
Apr 22, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Programme a livewire total tv remote
yes go into kitchen open bin drop in these remotes are not meant for our tv/dvd/sat etc they are for a chinese system save your hair chuck it away sorry to say I got one of these oh dear !!!!!!!!
Mar 20, 2010 | Televison & Video
How to tell whether logic board or rpm sensor is bad
Don't replace anything yet. This is a fairly common problem as the door travel limits go out of adjustment after awhile. On the side of the motor unit you will find the 'up limit' adjustment. Turn this about 2 turns in the opposite direction of the arrow printed on the cover. Make sure you put the wires back on the motor correctly.
Sep 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
I brought a livw wire usb hub 4 my comp(LIVEWIRE C) but it says c
try going to the manufacturer's website. look for a tab that says downloads/drivers. put in the name and model # of your product. you should be able to download updated drivers there... wha-la ^_^
Sep 10, 2009 | New Media LiveWire Dual Speed Networking...
Club Cart Golf Cart Reverse only
You don't have it connected right. The DC motor is 'polarity reversed' to change direction. That's what the controller does is reverse the polarity to the motor to change direction. If the motor is still working in reverse, then the controller is 'probably' okay. Recheck the connections you made.
Sep 03, 2009 | 3d Rose Londons Times Funny Cow Cartoons -...
I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Mar 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
