Question about Whirlpool Dryers
Cleaning wont heat properly
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
The heating element may be burned out.
If you don't make sure the Lint pipe to the outside world is clear these elements over heat and burn out
Posted on Jul 28, 2013
Hoover dryer lights up element heats but machine wont run keeps saying clean filter ?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Dryer Overheats and or Dryer Gets too Hot
Nov 22, 2016 | Hoover Dryers
Food now sticking to pan
Has it lost its seasoning? Look at any paperwork you may still have to find out how to re-season it and all should be well.
Mar 13, 2014 | Jml Ceracraft 10" Ceramic Frying Pan
Dryer wont heat. cleaned exhaust duct still problem exsists. Model 60 series kenmore gas
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 09, 2011 | Kenmore 600 6965 Electric Dryer
My dryer wont heat up and vent is clean. what do i check for?
heatman101
Aug 09, 2011 | Fisher and Paykel AeroSmart DG62TD1 Dryer
Our dryer wont get hot. ive cleaned out totaly for lint inside and vents
heatman101
Jul 02, 2011 | Dryers
My dryer runs fine, just wont heat, was working fine this morning, but on my second load of the day it stopped heating, cleaned all the lint from front-even pulled out and cleaned the lint from the back...
heatman101
Apr 30, 2011 | Bosch Nexxt 500 Dryer
Not cleaning properly i cleaned filter used a cleaner still wont clean dishers properly
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
zt5534
Aug 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Kitchenaid KUDS01FL -Dishwasher - "clean" light wont stop flashing; cant start a new load
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
May 20, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
We replaced the pump in our dishwasher and it has the clean button flashing and wont turn on the machine
The clean light flashes if the water is not heating properly or the control thinks it is not heating properly. Here is a link to some instructions I put together on what to look for and how to reset it so you can use it. Since you replaced the pump recently I would look for a wire that came off to the heater or temperature sensor.
Let me know if you have questions or if this works for you.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 07, 2010 | KitchenAid Dishwashers
HE4 propane dryer wont heat, how do I get the codes display?
Sounds like a clogged exhaust duct or vent. If not venting properly, most dryers will turn the heat off, for safety reasons.
Go for the easy fix first. Before removing your exhaust ducts from the dryer, look for any kinks that may cause blockage. Clean out the duct of any lint or water that may have accumulated. Check the vent on the outside of the house and make sure that its not clogged and opening properly.
Jun 05, 2009 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
27 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
